Question about Goodman Heating & Cooling
I AM REPLACING A 2.5 TON a/C WITH A 4 TON A/C. WILL THE LINES FROM THE 2.5 TON HOOK UP TO THE 4 TON O.K.?
    Brigadier General:
  • 3,614 Answers
YES... you can use the previous lines
Posted on Sep 10, 2008
  • micromaster
    micromaster Sep 10, 2008
  • micromaster
    ope this initial info helps you..
    kindly rate my solution here.
    -or just let me know if you need more assistance.
    regards
    micro
Pa12NA048-d. How many tons is this unit? It's 7 years old and went out. Needs replacing.
Hi, the tonnage is a 4 ton unit. It says in the model number, the 048. There is 12,000 btu's per ton of cooling. So, on your unit 4x12=48= a 4 ton unit.
Good Luck,
Shastalaker7
A/C Contractor
Aug 27, 2011 | Carrier Heating & Cooling
EVAP COIL REPLAESMENT PART # MODEL # CK36-1B
You will want to pick up a 3 ton coil. The 36 stands for 3 ton, 42-3.5 ton, 48-4 ton and so on. When replacing coils, the biggest thing to worry about is size and diminsions
Jun 22, 2011 | Goodman Heating & Cooling
I am removing a 3 ton condenser and replacing with a 31/2 ton condenser . The evap coil is a 3 ton with an expansion valve with a 11/2 ton to a 3 ton rating. Will i have any problems. The 31/2 ton unit is...
Yes you will have problems you can go up a 1/2 half ton on the coil but not with the condenser don't do it you will regret it even with an expansion valve.
Jun 21, 2011 | Heating & Cooling
Hi there I have a model number for my carrier a/c unit. I need to find out the tonnage. 38ykc042300 Please any help I will be very greatful.
This is a 3 and 1/2 ton unit.
The 042 in the model number is the tonnage of your carrier unit.
AC tonnage is based on 12,000 btu per ton.
12,000.....1 ton
18,000.....1 and 1/2 ton
24,000.....2 ton
30,000.....2 and 1/2 ton
36,000.....3 ton
42,000.....3 and 1/2 ton
48,000.....4 ton
60,000.....5 ton.
There is no 4 and 1/2 ton unit.
Apr 09, 2011 | Heating & Cooling
2001 Ram 3500 Truck: replacing powersteering pump on 1999 dodge 1 ton 3...
it is best to remove the pwr st. pump and vaccum pump assy as a unit which is held to the front cover w/2 15mm head bolt and a support bracket on the bottom bolt next to the block @ the pwr st pump. and disconnect all lines. get the seal kit and replace them @ this time. if you don't and just replace the pump you will probably develop an oil leak where the shaft meshes w/ the adapter.
May 18, 2010 | 2001 Dodge Ram 3500 Truck
Sprak plug Wires Need To Be Installed Correctly
You have several RAM sub-models in here:
Normal 0 21 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Tabla normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} B1500 RAM Van
B2500 RAM Van
B3500 RAM Van
RAM 1500 1/2 ton 2WD
RAM 1500 1/2 ton 4WD
RAM 2500 3/4 ton 2WD
RAM 2500 3/4 ton 4WD
RAM 3500 1 ton 2WD
RAM 3500 1 ton 4WD
Chrysler Full-Size Trucks 1989-1996 Repair Guide
To avoid confusion, remove and tag the wires one at a time for replacement.
Fig. 1: 2.5L 4-cylinder Engine. Engine Firing Order: 1-3-4-2. Distributor Rotation: Clockwise
Fig. 2: 3.9L V6 Engine. Engine Firing Order: 1-6-5-4-3-2. Distributor Rotation: Clockwise
Fig. 3: 5.2L and 5.9L V8 Engines. Engine Firing Order: 1-8-4-3-6-5-7-2. Distributor Rotation: Clockwise
Fig. 4: 8.0L V10 Engine. Engine Firing Order: 1-10-9-4-3-6-5-8-7-2. Distributorless Ignition
Hope helped with this (remember rated this help) Good luck.
Nov 06, 2009 | 1996 Dodge Ram
How to put 2006 chevrolet drum brake spring on
Truck? Car? 1/2 Ton? 1 Ton?
Either way... the proper tool makes it fairly easy but can be done with a little finesse with a flathead screwdriver. Place the hook of the spring on the shaft of the screwdriver and the blade on the spring mount point, stretch spring until it slides down screwdriver shaft and onto mounting point. Unless you are dealing with a 1 Ton then the proper tool will have to be obtained
Sep 27, 2009 | 2006 Chevrolet Silverado 1500 2WD
The fuel lines pulled out of my 1978 GS550 when I was replacing the clutch cable. I need help hooking them back in the right places. I don't know which are fuel lines and which are vacuum and how they...
You will have two lines coming from the petcock on the bottom of the gas tank. the small one goes to the front of the number one carb, and the larger one plugs onto the fuel rail in the middle of the 4 carbs on the back. The lines that run between the 1 and 2 carbs and the 3and 4 carbs are just overflow lines, so they don't hook on anywhere else.
Jul 13, 2009 | 1980 Suzuki Gs 550 L
Heating & Cooling Logo
21 people viewed this question
Top Goodman Heating & Cooling Experts
Dan Webster
Dan Webster
Paul Carew
Tim Whalen
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
