Sony KP-61S65 61 in. Rear Projection Television
Problem for Sony KP-61S65 61 in. Rear Projection Television
Blue Convergence
By Kruzen on Apr 02, 2006
- TV is 7 yrs old
Everything is working fine except you see a blue double image of the screen.
I have tried to correct this through the TV setup by adjusting the blue convergence crosshairs.
I am not able to move the crosshairs left or right, I can move them up and down. Red convergence adjustments work fine.
Looking for a in house soultion.
Thanks,
Kruzen
Clarification Request
Posted by ulees on Jun 04, 2008
which STK (blue & red) we should use for his model TN55X81? where to buy? Thanks!
Same Problem
Mar 28, 2008
-   I have practically the same problem. I have a different TV, a Toshiba 42hdx82 and the problem is with the red, not the blue. I can adjust everything to line up fine, except for adjusting the red right and left. it' won't move, and the picture is almost an inch off. Looking for some kind of DIY solution.-   Atropos
Feb 14, 2008
-   I have a blue glow appearing at the bottom of my 62inch rear projection TV. Am not sure what causes this or how to get this repaired. Any suggestions for repairs would be welcomed.-   Kushilla
Feb 01, 2008
-   My projection tv has all the sudden acquired blue double shadow-ghosts. When I run the picture perfect, all colors align except the blue. Please help on what parts I may need to replace. Have only tried adjusting the color through the menu picture settings with no luck.
Thanks.
MS-   Tumor
Jan 27, 2008
-   how do you get into the screen to move the cross hair? i am having the same problem with my TV. thank you.-   mishuty
Dec 12, 2007
-   I have replaced my convergance board and now blue will not focus using the perfect focus feature. what should i do next. I'm an electrician and can troubleshoot using a multi-meter.
Eric-   too short
Best Solution
posted on Feb 29, 2008
Helpful)
dagreat1
Rank: Apprentice
Rating: 92%, 2 votes
Everywhere here in gainesville is rtying to charge me 400 dollars I call them with the exact problem above and they all say it could be a multitude of prolems and on a TV that size i'm looking at a minimum of $375
Was this helpful?
Yes
No
Solution #2
posted on Apr 02, 2006
Helpful)
silly girl
Rank: Wiz  Sony Expert
Rating: 81%, 3619 votes
If still under warranty or if you have no electronic repair experience you should take the set back to the shop or to a repair person. Some of the solutions described below can be dangerous, TV's are very hazardous to service. Even when plugged out, TV's can store very high voltages.
Check the blue horizontal convergence amp on the convergence panel.
Whether or not this is an in house solution, is up to your experience in electronic repair and specifically TVs.
Good luck
Was this helpful?
Yes
No
Solution #3
posted on Jul 11, 2006
Helpful)
DaninFuchs
Rank: Guide
Rating: 89%, 116 votes
danin... indicated that his solution for
57H81 57 in. Rear... Problem
is valid for all Projection...
Convergence problems are generally simple repairs, presuming you know how to solder and have a bit of brains about you. Eventually every projection set will have this problem - STKs are usually at fault (STK392-010/020/040, STK392-110/120/150/180, etc) and are easily aquired and replaced. Sometimes a fusible resistor is taken out in power supply circuit, sometimes a resistor will burn. Generally easy fix. Repalce STK and any fusible/blown resistor - you will need a multimeter, decent soldering equipment (NOT a 40watt iron or gun from Radio Shack, unless you're brave) and the replacement parts. But as everyone says - servicing TVs can be hazardous. Call a servicer if you're concerned, but in-shop repair should cost less than $250 - it would never exceed that at our location.
Was this helpful?
Yes
No
3 people thought this was helpful
Solution #4
posted on Nov 15, 2007
Somewhat Helpful)
jonny111
Rank: Apprentice
Rating: 75%, 1 votes
I purchased a RCA 61" HDTV 15 months ago at aprox $2000.00. Ofcourse RCA making such great products and backing those products !! Will not cover parts or labor except for the tube after 12 months? I have researched and discovered i have a convergence problem related to 3 or 4 (21 pin chips) part # STK392-110 , 112 ect.... can these be replaced fairly easy or are they hard wired ) soldered in. I need to know where these are located and with me and my wife electrical back ground can we fix these ourselves if we purchase the parts. I do not have a tech manual or scematics to help locate these chips? Can you tell were they are located or were the card is located that they are on? Thanks in advance for your help and site !!!
Jon
Was this helpful?
Yes
No
Solution #5
posted on Feb 04, 2008
Not Rated)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
I am getting a blue and yellow shadow on the piture and words. If anyone could e-mail me how to fix this.
Solution #6
posted on May 24, 2007
Not Rated)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
Buy a new TV like I'm gonna do.
Solution #7
posted on Mar 18, 2007
Not Rated)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
suggest replacing BOTH ic's red aND blue
and of course depending on the make and model there will be a few other things to check....
gl
Solution #8
posted on Feb 22, 2007
Not Rated)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
I just had my Pro 200 fixed with the same problem - needed 2-STK394160 and 2- FRX 25512RO and 1 - FRX25533RO This was to fix the digital convergence assembly, definately not a DIY job.
Popular Solutions for Sony KP-61S65 61 in. Rear
Questions and Unsolved Problems for Sony KP-61S65 61 in. Rear
Do you recommend Sony KP-61S65 61 in. Rear Projection Television?
Answer
Answer
sony 52' rear projection older model, about 5yr old. For a few months has had green shadows around... (More)
Answer
The TV timer standbye light flashes but the screen does not come on
Answer
I turn the tv on and it comes on after 15 blinks of the red light and when it comes on it is... (More)
Answer
the screen is turning blue on one side but the other side is clear
Answer
i have a sony 51" rear projection. after a period of time the screen will get green wavy lines... (More)
12 Other Users Have The Same Problem - Continued
Comment by dugen, posted on Nov 24, 2007
my set was only 3 years old when this problem developed, my blue has shifted to the left severly and canot be adjusted. if you look to the upper right of the screen it actually looks bowed in to the left(blue)
Comment by 1969nova, posted on Nov 23, 2007
TV was purchased in 1996 Hitachi Ultravision picture is getting darker and has blue shadow. I had the same problem a few years ago and payed for a repairman to come to my house for service. He told me to occasionally push the magic color button but this does not fix the problem. HELP!
Comment by JCarter, posted on Nov 20, 2007
I am having the same problem the blue convergence lines will not move up or down just side to side. but everything else matches up fine I have great picture quality except for the color being yellow greenish tint is that normal since that blue is not mixing so im only getting 2 colors instead of RGB? Im a digital artist not a tv repair man thanks
Comment by Guest, posted on Nov 20, 2007
I am having the same problem with mine the red convergence line are perfect I have excellent picture quality but its like the blue is not aligned with the red and green so my picture has a yellow greenish tint could someone please e mail me and let me know if this is normal im a digital artist not an electronics expert thanks.
Comment by Pipernga, posted on Nov 15, 2007
Hello, I have the same problem as described. I replaced the STK392-110's with STK392-180's, because I read that the chips are most likely the problem. Unfortunately, it still has the same problem. I am currently working on a degree in Electronics Technology, and have minimal experience troubleshooting circuit boards. Does anyone have any idea what I need to check next?
Comment by EDAN003, posted on Nov 11, 2007
I HAVE THE SAME PROBLEM THE BLUE CONVERGENCE WILL NOT ADJUST . tHE BLUE SHADOWING ON ALL WORDS.
Comment by Guest, posted on Nov 06, 2007
I have the same issue except my blue will adjust side to side but not up and down
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Projection... Experts
Top TV Repairmen
(316) 283-8873
(316) 838-0811
Authorized Warranty On Rca,Integrity In Sales...
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
