message appears failed to start control center the required registry information is missing please re-install the multi-function suite 9cc3-001-00001970 have attempted to reinstall disc several times have vista premium as installing several messages indicate that correct loading is not happening. downloaded drivers from site
New installation but can't start Control Center 3. Get following notice. Failed to start the Control Center. The required registry information is missing. Please re-install the Multi-Function Suite.(CC3-001-00001904)
Useing Windows Vista Premium with Service pack1.
Try reinstalling the printer driver -
You candownload the Brother printer drivers from their support WEB site. Please clickon this link and select your model printer to download :-http://www.brother.com.au/ProductsSolutions.aspx
Did you disable the User Account Control and tried installing the Software completely?? You will have to uninstall all the previous version Applications and then disable the UAC and install the application,.
...so re-install the software like it says, or try a system restore to a few days ago when it was still working: in XP: "Start" "Programs" "Accessories" "System Tools" "System restore" "Restore My computer to an earlier time".....
Vista: Type "Restore" into the "start menu search box", select it, and follow the prompts.
Right-click the system default printer and click Properties
On the General
tab, right-click the default printer and click Copy
Click Cancel
to exit.
Click Start
and then click Run
In the Run
dialog box, type regedit
and click OK
WARNING:
Using Registry Editor incorrectly can cause serious
problems that may require you to reinstall your operating system.
Hewlett-Packard cannot guarantee that problems resulting from the
incorrect use of the Registry Editor can be solved. Use Registry Editor
at your own risk. It is strongly recommended that you make a backup
copy of the Registry before you edit it. For information about how to
edit the Registry, view the "Changing Keys And Values" help topic in
Registry Editor (Regedit.exe) or the "Add and Delete Information in the
Registry" and "Edit Registry Data" help topics in Regedit32.exe.
In the Registry Editor window, click Edit
, then click Find...
, and search for the following key: HKEY_CURRENT_USER\Software\Hewlett-Packard\DigitalImaging\hpfccopy
Double-click Printer
in the right pane.
In the Edit String window, paste the printer name as it appears in the Registry under Value data
(for example, hp photosmart 8400 series) .
Click OK
and close the Registry Editor.
Press Copy
on the scanner. The default printer connected to the system should normally print the scanned document.
Cause
This issue occurs when the default printer or the list of printers is not recognized on the hpfccopy
function in the Current User section of the Registry.
Ok. i have seen this before. Your driver may be corupt, and the systems applet may actually be missing. Uninstall the printer completely. Run a search at the start menu and type in your printer name to make sure no corrupted files have been left behind. You need to run good antispyware, antivirus (i recomment avg free for both) then run regcure or similar to correct any bad registry errors. My neighbours did this and we fixed it with this solution. Now, once all clean and all registry cleaned, go to your manufacturers (canon) site and download a new driver, there may be an updated one too. Now install printer with new driver. Good luck!!!
a lad of anrs
failed to start controlcenter the required registry information is missing
