Question about Kenmore Elite HE4 Electric Dryer
Very loud after stacking.
I've had my washer/dryer combo for a few years sitting on pedistals. I just stacked them last night, and when I put a load in the dryer this morning, it runs, but it's extremely loud. It's making a grinding sound, medium to high pitch, with a little bit of stutter as you turn it off.
  • drsgirls Sep 12, 2008
    The kit from Sears came with sticky rubber pads. I checked that the set was balanced with a level, and even took off the lower front panel to look for something rubbing inside. However, when I put a few shims under the front of the dryer the sound lessened significantly and at times it is non existant. So... I'm sure that mine is a temporary solution, but I don't know what else to do other than call a Sears tech and dish out a small fortune. Any other suggestions are welcome!! :)
    Novelist:
    Champion:
  • 261 Answers
I assume you used the kit for stacking and removing the top of the washer and installing the plates?
You might need some sticky rubber pads to stop metal to metal contact and some duct tape around the vent exiting the dryer where it meets its back panel. This is common, you could go specific or browse ace hardware and find a compatible source.
Posted on Sep 12, 2008
Washer Dryer Stacked Combo won't start and didn't drain properly.
Hello Joshua, thank you for your post!
From my understanding your Frigidaire laundry center is not starting and did not drain properly. It is possible that this could be a miscommunication within the laundry center and a reset may help clear that out for you. In order to reset your laundry center you would need to disconnect power from it for at least ten minutes. If that does not help your laundry center you may need to seek assistance from a professional technician for proper repairs. I hope this is helpful and if you should need further assistance please feel free to reconnect. -Matt
Apr 11, 2016 | Frigidaire Washing Machines
I have a stacked Frigidaire FEZ831CA washer/dryer combo and when running the dryer it makes a very high pitched (AND LOUD) screeching sound. Any ideas as to what might be the problem? Thanks, Sean
screeching sound
Sean, Bad felt gasket body to drum, if belt drive on dryer, it could be worn and slipping, making a screech, or if not the belt, the drum may have a worn bearing on its hub allowing it to run crooked and rub where it should not.
Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Disassembling reassembling stacked clothes dryer
Frigidaire Stacked Laundry with Noisy Dryer
How to Replace an Electric Laundry Center Dryer Drive Belt Kenmore...
Mar 29, 2016 | Frigidaire Washing Machines
Want to know if I can stack a kenmore elit gas dryer on a kenmore elite washer and on top of a 10 inch pedistal or will it be too tall?
The appliances were not designed to be stacked so I would not attempt it if anything I would build a shelf (ledge) to put the dryer on, then bracket it to the wall but be careful of the height especially with a gas dryer and be sure to have plenty of space for airflow. Good luck
Mar 27, 2014 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Can an frigidaire X091307954 dryer be stacked on a Amana NFW7200TW 3.5 Cu. Ft. Front Load Washer?
this is possible, youll need a kit that sets on top of the washer,check back where you bought the washer and dryer, they make a washer and dryer combo thats one peice, they are smaller however
Jul 13, 2013 | Amana NFW7200TW 3.5 Cu. Ft. Front Load...
Fridgidaire fex831fs1 washer/dryer stack unit: how is washer timer function knob removed from timer shaft ?
i have a frigidare washer dryer combo model fex831fs approximately 6 mo old . turned on a load and water gushing out from underneath, checked hot and cold hoses not leaking, water coming from underneath
Mar 03, 2010 | Frigidaire FEX831CS Top Load Stacked...
Fills with water and that's it
ck the water pump, only if it agitates but doesnt drain. If it completely stops after filling, ck lid switch(should here clicking noise from sw.)
Oct 21, 2008 | Frigidaire FEX831CS Top Load Stacked...
Stacked washer dryer
It sounds like the belt or a pulley!
Anything more and it's not worth fixing if it's 10 years old .
Then better off replacing it with a newer machine which will be much more efficient!
Not worth the money to fix!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Try You should call service.:
A&E Factory Service
1-800-905-9505
Nation wide / 7days/24 hours
Good work
Please give me a "Solution Solved Rating", in this site!
Thank You
Neil
Jul 27, 2008 | Frigidaire FEX831CS Top Load Stacked...
Kenmore washer/dryer combo
I Can give you a few things to check if your mechanically inclined, but if you dont feel comfortable digging into the machine I would suggest a technician visit..   if you feel like digging into it send me an email at bigtexan1000@yahoo.com and we can begin
May 30, 2008 | Kenmore 88752 Top Load Stacked Washer /...
Clothes getting caught on inside of dryer
There are a couple of guide wheels in the back of the dryer. when they get worn out the tub will have excessive play and will trap clothes inside. Just remove the front cover loosen the belt and remove the drum. the worn wheels will be easy to spot. It is an easy and cheap fix.
Nov 02, 2007 | Kenmore 98702 Stacked Washer/Dryer
Stackable Washer will not drain.
check if there is a low humming noise when on drain. if so there may be a foreign object trapped in pump. otherwise have you checked filter?
Apr 02, 2007 | Whirlpool LTG6234D Front Load Stacked...
Kenmore Elite HE4 Electric Dryer Logo
203 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De GO PATS
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
