Thechnical data of greenstar 15 Ri worcester - Heating & Cooling
  • 76 Answers
Greenstar 15Ri Technical data table Technical data Title Value Height (mm) 600mm Width (mm) 390mm Depth (mm) 270mm Weight 22.6kg Output to central heating and domestic hot water 5 - 15kW (17,060 - 51,180Btu/hr) SEDBUK Value/band 90.1%/Band A Solar compatible Yes Maximum horizontal flue (100mm ø) 4,600mm (inc. terminal) Maximum vertical flue (100mm ø) 6,400mm (inc. terminal) Maximum horizontal flue (125mm ø) 13,000mm (inc terminal) Maximum vertical flue (125mm ø) 15,000mm (inc. terminal) Gas connection 22mm compression Heating flow and return connections 22mm compression Maximum flow temperature 82ºC (180ºF) Primary water content 1.1 litres NOx classification Class 5 Noise output level 42.7 dB(A)
Hope this is what you wanted..
Let me know if you need any thing els.....
Posted on Sep 10, 2008
How do you work the heating on a Worcester bosch 35cdi boiler
search for worcester bosch 35 cdi manual choose Greenstar CDI & download the pdf instructions
Dec 31, 2014 | Bosch Water Heaters
Worcester Boiler Greenstar 15Ri - The blue neon light is flashing - what does this mean?
http://www.worcester-bosch.co.uk/homeowner/literature/gas-boiler-literature/greenstar-15ri-literature. Hope this helps :)
Sep 19, 2014 | Water Heaters
The water pressure on my Greenstar 25Si Worcester Bosch combi boiler is so low that the shower won`t heat up. Can someone please tell me how to increaese the water pressure as there doesn`t seem to be an...
The boiler has a filling connection which uses a filling loop to connect the boiler to the mains supply for the initial fill and subsequent fills.
See the link below from the manual you can buy the filling loop connection online or ebay its a simple task to replenish the pressure. Worcester GREENSTAR 25Si Instruction Manual Filling The System
Feb 06, 2018 | Water Heaters
Worcester bosch greenstar junior 28i approx 2 years old. timer is not working it does not fire up at set time could it be something simple or do i need a new timer.
Hi, this is Worcester, Bosch Group.
Our technical team can help with enquiries - please call 0844 892 3366.
We look forward to helping you.
Mar 29, 2010 | Heating & Cooling
Worcester greenstar he error code c1
this could be a pcb fault call worcesters they have there own fitters who will fix this , they are good fitters and work on these all the time ,
Mar 24, 2010 | Heating & Cooling
My Worcester Bosch Greenstar 25CD1 is flashing 5E
the code is SE saying it needs a service it can be reset go to this link for a pdf file showing how to http://www.worcester-bosch.co.uk/cache/file/239/guide-to-re-setting-the--se--code-on-greenstar-cdi-boilers.pdf
Jan 24, 2009 | Audiovox Bosch 718 World Cellular Phone
Repressurizing my boiler
take your pick from video or text
How to Repressurise a Heating System with an Internal Filling Key ...
? 3:30
https://www.youtube.com/watch?v=zUsBw1ZpiKY
Oct 27, 2010 - Uploaded by Worcester, Bosch Group
This video shows you how to repressurise your heating system using your Greenstar gas boiler's internal ...
Repressurise Worcester boiler - YouTube
? 4:12
https://www.youtube.com/watch?v=K6fH4XfGgxo Nov 10, 2012 - Uploaded by Rory Macfarlane
This video demonstrates how to repressurise a Worcester combi boiler on the.
Product Troubleshooting Videos ' Worcester, Bosch Group
https://www.worcester-bosch.co.uk > Support > Troubleshooting > Videos How to repressurise a heating system with an internal filling key ... how to repressurise your heating system using your Greenstar gas boiler's internal filling key.
How to top your Worcester combi boiler up - Gas Care.
www.gascare-heating.co.uk/topping-pressure-worcester-bosch-combination-boiler/ Aug 4, 2014 - If the needle on the pressure gauge on your boiler has gone into the red or down to zero it means there is little or no pressure left in the heating system and it needs to be topped up ASAP. So here's Gas Care Swansea's guide to refilling your Worcester Bosch combination boiler through the internal filling link.
How do I re-pressurise my Worcester Bosch boiler? - My Plumber
www.my-plumber.co.uk/blog/how-do-i-re-pressurise-my-worcester-bosch-boiler/ Sep 1, 2015 - 6) Check the pressure on the pressure gauge. When it reaches between 1 and 1.5 bar, it is time to turn the white knob back to the right to close the valve. Be very careful not to over-tighten. 7) Turn the filling key to the left until the arrow lines up with the open padlock and remove the key.
May 12, 2017 | Heating & Cooling
Heating & Cooling Logo
322 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
