Question about Car Audio & Video
Transforming American radio system to the European system
You found:
"To transform it to the European system, you should turn it off, press1+5+SRC until it will turn on again. And that does the job."
Do you know where I can find the remote key combination todo the same with KDC-MP538U? (To transform it to the European system) is it the same?
Where did you found the key combination to yours?
Thanks in advance!
  • 3 more comments
  • djshaker Sep 16, 2008
    I have a car stereo purchased from the US and I can’t pick up all radio stations in Europe/UK, what can I do?
    If you have purchased a car stereo from the US you will find that it
    will not pick up many European radio stations. This is due to the fact
    that US radio frequency steps are different to here in Europe.
    You may be able to set the tuner to European stations by following this procedure.
    Press and hold down the SRC button to power down the unit completely.
    While the unit is off press button 1 & 5 together, while momentarily pressing the SRC button.
    If this does not work try the following proceedure;
    Press and hold buttons 1 and 5 together, while momentarily pressing the reset button.
    If this does not work then the unit is not designed to pick up European frequency steps.
  • Anonymous Jan 15, 2009
    Hello there! I have Kenwood eXcelon KDC-X592 and I'm having the same problem - I have only a remote control with numbered buttons on it. There are no numbered buttons on the front panel of the receiver. Is there a key combination for such receivers?
    Thanks!
    Ivaylo, Bulgaria
  • ivan127 Feb 27, 2009
    Hi, I bought an AC Delco Radio Cd player from a 98 Pontiac Firebird, and I'd love to know if there is any way to transform it to the European system
  • Anonymous Apr 01, 2009
    hello there....
    i have the same problem with a 1987 Delco in a Caprice.
    is there also a number of keys to press , or any converter to the European system...?
  • Anonymous Apr 13, 2009
    American BMW Professional Navigation Radio does not pick-up all EU radio channels.
simplemitch
  • 752 Answers
SOURCE: How to turn off this blasted DEMO mode on MP235
Once in standby you have to press and hold the button to get into the menu. Once in the menu, you use the joystick control on the right to navigate to "Demo" and toggle it to "off" (can't remember off the top of my head... you either have to press the joystick in and hold it to toggle or just move it up/down...). Once done, just press Source to exit.
Posted on Sep 11, 2007
tech48
  • 624 Answers
SOURCE: CD player issues
Burned Cd's do play in these, I use them all the time when I test the one's I repair.
Yes, it is the "SCR" button you press, it stands for "source".
Since it is in your boat, it could have a small amount of water damage in it. I have seen some strange problems with car stereos put in boats.
The problem you are describing is nothing that any normal end user can fix, meaning that there is no reset that will help or anything of that nature.
If you are good at taking things apart and putting them back together and able to pay close attention to detail, you may be able to fix this yourself if the problem is not too extensive.
If it has a small amount of water damage, you could clean the main board and see if that helps.
First you take the top off, it has 1 screw on the top right in the back middle of the stereo. Take it out and then take the top off carefully so you don't bend it up removing it. You need to gently pry the sides up near the back first, then a little closer to the front as well. After the top comes off, the CD mech has only 2 screws holding it in, they are at the front of the mech at the bottom and connect into a brass post. Take them out and the mech will come out very easy, but be carefull not to damage the ribbon cable holding it in. That ribbon cable can be taken out right at the main board where it is connected. Just pull it out of the connecter, nothing special holding it in, just a tight fit.
Now you can see the main board. First remove the plastic part that holds the display, it has connectors that just need to be lifted a little to pull it off.
This may be all that needs to come off, but taking the board out all the way may be whats needed, so go ahead and remove the screw that holds the board onto the chassis. Might be just 1, maybe two. Look in the middle front of the baord for a screw and the back area also. You can always look at the bottom of the chassis to see where there are screws coming thru and remove those. Now on the sides of the chassis are screws on each side near the back to remove. After you get those, it should just pull out with the heat sink attached. Just make sure you don't force anything out, it could break the board if you missed anything. I am pretty sure that is all, but I am going off of memory and might have forgot something.
Once the board is out look it over very closely for any type of green or greyish type of corrosion. Check the pins of the IC's with a magnifier if need be. Any tiny little spot of corrosion can cause problems, even if it is not on a component.
The solder should be shiny and silver, no rings or cracks. If any of them are grainy looking they may be bad also and would need to be reflowed with a soldering iron and a touch of fresh solder.
Any of the corrosion you may find can be cleaned with an old toothbrush and some alcohol. We use flux remover in our shop, but it's unlikely you have any of that. After cleaning it off with alcohol it will leave a residue that does not look good, but don't worry about that. It won't do any harm. Just make sure all of the corrosion has been removed. Look at every little area of the board on both sides.
Once it is done, just put it all back together just the way it was taken apart. Don't forget any screws and make sure they are on tight but not so tight it may break the screw. Just good and firm.
After doing this, if it still does not work, you will need to take it in for service or just buy a new one, these models are just a little over $100 and the repair will run close to that much or more.
I hope you found this useful, if so a FixYa rating would be appreciated.
Thanks and good luck,
Dave
Posted on Jul 03, 2008
SOURCE: Problem with Demo mode turning off Kenwood KDC-WF431
Hello. Have the same problem. Have just downloaded the Manual in German. It says In Standby Mode use the small joystick up to FM or AM till it says DEMO OFF and then press the small joystick for 2 Seconds. Hope this helps.
Paul
Posted on Aug 18, 2010
audiozone1
  • 6 Answers
SOURCE: I have a stereo kenwood model kdc-mp538u not turn
Please traslate this; quita el modulo de radiofrecuencia (Radio module) ahi es en donde se guarda el codigo de seguridad y de protecion. quitalo y volvera a funcionar. see ya!
Posted on Oct 09, 2010
jannersdave
  • 116 Answers
SOURCE: I have a kdc mp538u
You can enter a 4-digit security code as an option after purchase of the unit. If you do so, make sure it is noted down somewhere. If you did select a code (or the previous owner has done so) this must be used when the unit is removed from the vehicle, or the constant power source is disconnected from the unit. When constant power is restored to the unit, the security code must be entered before the unit becomes operational. If the code is lost or forgotten I am afraid the unit has to be re-coded by a Kenwood dealer.
Hope this helps, Good luck with it.
However here is a link for a tip as posted by robotek, therefore all credit should go to him, Regards.
http://www.fixya.com/support/r538828-security_unlock_code_kenwood_most_models
Posted on Apr 16, 2011
Can Singer 7258 Stylist be used in a Country like India with 220 - 240 voltage? Is there any UK model for the same?
the machine comes in two versions european {220-240v}
or american {110v}
you need to use a transformer to give 110-240v
the current this machine uses is less than 3amps
so a 3amp 110-240v converter is easily found on ebay for $10
Mar 12, 2015 | Singer 7258 Sewing Machine
II bought a blue hat toy company transforming radio controlled car model #1635151. I placed batteries into the remote, however the car does not work. I wonder if maybe the car is also supposed to have...
first check
are the batteries in correctly--negative to the spring
If you do not know where to put the batteries in the car , give it to a child and he will be able to show you where and how
Aug 05, 2017 | Toys
Convert US 220V to European 220V
all you need to do is to purchase a power converter also known as transformer that converts the European 220v to110 v, so that American appliances will operate on European current.
Dec 01, 2011 | Miele W1926A Front Load Washer
How to adapt the grand Cherokee 2007 audio to European frequency
Contact Jeep and ask if they have a European radio option. The Grand Cherokee radio opening in the dash is not generic, so an over the counter European radio may not fit right.
As far as the CB, American and European CB radios are different. But they are often available on ebay.
Feb 25, 2011 | Cherokee Radio Communications
Will this radio for the IPOD work in the UK?
No it will not. This radio is designed for American Electrical systems. 120 volts 60 HZ.
United Kingdom uses the European Union Standard which is 230 Volts 50 HZ.
You should be able to purchase a Device called a matching transformer that converts 240 volts to 120 volts. They are common in the US and probably so in the UK.
Here is a link to the Manual for your Radion
http://www.crosleyradio.com/Manuals/CR221_Manual.pdf
Good luck.
Best, Mark
Dec 28, 2010 | Crosley CR221 FM/AM Radio
Where is the battery compartmment for the transforming robot car from Blue Hat toy company?
The rear end has a plastic lever (with screw in center)...twist it down and flip up the piece it was blocking. And remember to turn on the switch on the fender (below the spoiler).
Dec 29, 2009 | Vacuums
Is there a recall on the triple fun learning center?
You probably know this already, but yes, there is a recall for the end caps you use when transforming it to stage 3. One of them can fall off easily and cause a tripping hazard.
Here is evenflo's page on it: http://safety.evenflo.com/cs/sc/cssc99_RD.phtml?rid=EFR23&src=WEB
The model number, 6231711, and manufactured date can be found on a white sticker on the inside of the upper blue ring.
Feb 23, 2009 | Evenflo Exersaucer Triple Fun Active...
Transforming XP to Vista platform
Leave Vista Transformation Pack on it's place and use "Windows Vista Mizer". It is the best software to convert windows Xp into Vista you can convert to any edition of vista and also make bootable vista disc,
try this download link for Windows Vista mizer
http://www.softpedia.com/progDownload/VistaMizer-Download-74379.html
Oct 12, 2008 | Microsoft Windows Vista Ultimate Edition
Region problem
Try this for the tuner fix. Turn unit on.Hold down (volume down and SRC )buttons and unit will power off.Keeping them in also press and then release the reset button(bottom right hand side) .Release the other 2 buttons and unit should now restart with 50khz fm spacing and 9khz am spacing.If you find out how to change region code,Post It
Jun 09, 2008 | Kenwood DNX7100 Car Video Player
I have a lightly used Haier portable dvd player and the battery will not charge and when i plug the AC adapter into the player itself it will not even turn on
I will need an exact model number on that one to be sure, but Haier produces European and American versions of their products. If you are in the US and purchased a European variant, then the AC Adapter will not work in US because we use a 5V system and the rest of the world uses a 110V system. You will either need to get it replaced for a US variant, or buy a transformer - tell Radio Shack, Circuit City or some KNOWLEDGEABLE store (aka, not wal-Mart) that you need a 110V to 5V transformer.
On the other hand, your variant could be for the right country, and the thing is just broke - return it now while you still can.
May 23, 2008 | Televison & Video
Car Audio & Video Logo
937 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
