Machine will wash but when it's time to rinse the water just sit machine stops
  • francis rivero May 11, 2010
    can i know what is the make and model of your unit please...
    tnx
    drcool
  • 5,911 Answers
If this is a TOP LOADER, the symptoms you describe are typical of a lid switch malfunction. If the lid switch is not making proper contact, the washer will fill, agitate (in some models) , then when it gets to the rinse cycle, the washer just stops. If these are your symptoms, I would recommend inspecting the lid switch to make sure it is not loose or broken. The switch should activate when opening and closing the washer lid. In many cases, all that is required is to tighten the mounting screws on the switch, and the problem will go away.
If this is a FRONT LOADER, the problem could be related to drain pump malfunction or control board, and the problem will usually have an associated error code displayed on the front panel.
As you can see, the symptoms between washer types can differ greatly. I do not know from your description, exactly what type of washer you have. That is why it is recommended that you provide as much information as possible when submitting your question(s) so it can make a diagnosis much easier. Please post back with your make and model number, so I can make a determination for you.
I hope I may assist you further.
Posted on Sep 11, 2008
    Genius:
  • 1,239 Answers
Hi sir..  please clean the base of the spinning whirl's.. there may be mud stuf int the base.. and heavy load is not suttiable for some motor.  thank u .. rate it..
Posted on Sep 10, 2008
    Novelist:
  • 166 Answers
Peace, tankduce,
ngafm At your service!
What is the make & model???????????????????
Sounds like an electronic problem?
If I were there hands on I could be definite.
Only a hands on laundry tech can make the diagnoses.
How old is the washer?
If the appliance is 10 years old or more you it may not be advisable to put good money into bad!
New appliances are so much more efficient today that they can save you a lot of money in energy!
Water,Electric and detergent! And put money back in your pocket!
The new appliance will pay for itself in only a few years!
You will be fine
Bless You ngafm
PLEASE GIVE ME A GOOD RATING BEFORE YOU SIGN OFF
Operation of machine wash, rinse, spin
at the end of the wash does it empty ok it needs to before it can move on to take on water for the rinses if it doesn't check the pump is not blocked if it does empty the issue may be water valve for cold water also on the wash cycle does the machine heat up if not it will just sit there washing forever
Mar 04, 2014 | Indesit Washing Machines
H6 error code on a NEC NFL-1065 washing machine
see this causes, and fix it. God bless you
If the washer stops mid cycle the timer might be defective. This part is often misdiagnosed, check other components before replacing this timer.
f the washer stops mid-cycle the main control board might be defective. This is not common. Check other causes first such as the lid or door switch and other components
f the washer stops mid cycle the water inlet valve cold water side may have failed. Most washers have a cold water rinse and so if they can't fill with cold water they just sit indefinitely waiting for the cold water to enter. If there is cold water to the water inlet valve and the cold water works in other parts of the cycle - or to make warm water - the valve is not the problem.
If the washer stops mid cycle the door lock assembly should be checked. The door lock can fail either mechanically or electrically. Test any switches on the door lock with an Ohm meter. The switches should have continuity according to their design
If the washer stops mid cycle the lid switch assembly might be defective. This is a very common problem. The lid switch assembly can fail either mechanically or electrically. Test any electrical switches with an Ohm meter for continuity. The switches should have continuity according to their design.
Sep 26, 2012 | Washing Machines
Washer stop in middle of rinse cycle
All content © 2000 © 2009 Washerhelp
> Home / Repairs DIY washing machine advice (part 8) Washing machine sticks or stops mid-cycle repairs-sm.gif A very common fault on washing machines is when the program timer fails to complete the cycle and stops part way through. Many people blame the program timer for this but although it is a possible cause, there are many more likely causes for this fault. The program will stick if the heater isn't working, if the thermostat fails, if it can't fill up with cold water for the rinses, if it can't empty the water etc. There are too many possible causes of this fault to be able to give anything other than rudimentary advice. However, the common causes of a washing machine sticking that can easily be fixed are filling and emptying problems.
Check that the cold water supply is available to the washing machine, which is a common cause for sticking on rinses. If the washing machine appears to stop mid-cycle and isn't filling with water on rinses then see Washing machine won't fill with water (or no water goes into washing machine) before calling an engineer. If the washing machine can't drain the water out then it will stick on the rinses, or it will abort with an error code. If you can see water still inside the washing machine then check the following advice Washing machine won't empty water
Dec 02, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Stops at rinse cycle
need more info, has the machine heated up the water during the main wash? is there a blockage in the filter?
Apr 05, 2009 | Washing Machines
My Kitchenaid washer stops on the rinse cycle...
Do you have an age of the machine and model number? Is there a "spin only" cycle? On older machines, there was a center knob you could slowly rotate, one click at a time, to advance it through its cycle. Can you do that? If the unit is agitating, I don't believe the belt is your issue. Age and model please.
Jul 31, 2017 | KitchenAid KAWS750L Top Load Washer
Machine fills and agitates, but won't drain
Please empty your machine and run the machine empty. If the washer goes through the whole cycle without any clothes. Please let me know
Jan 19, 2009 | Kenmore 24032\24036 Top Load Washer
Won,t drain on rinse cycle
Ok mc we need a timer at this point. You see the timer doing several steps different than before.
Nov 01, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Machine cant get any water.
Does the water fill to the correct level ?
Sep 09, 2007 | Fisher and Paykel Fisher Paykel Intuitive...
Washing Machines Logo
57 people viewed this question
Top Washing Machines Experts
