Help! Have you any solutions to bring back the TV's On ...After your tv shutdown state ?? Thx!
  • 125 Answers
The shutdown on your tv is because there is a component shorted out; maybe the flyback, the ic regulator,a diode or the horizontal transistor, you will be able to replace or to find out what is the cause only if you have some knowledge about electronics. at this point I think you will have to hire a technician.
sorry for not been of good help for your solution
Posted on Sep 10, 2008
When I turn my tv on it shuts off right away then flashes orange green orange green
Shutdown can be caused by just about every board in the TV. What is the model number of the TV? If you need a replacement part, I have always found Tri-State Module helpful. You can talk to their technicians to help you diagnose the problem further too.
Nov 04, 2013 | Televison & Video
Power light is flasing and tv wont turn on. if I push the power button twice it will stay on for a few seconds but then starts blinking again
Your TV is going into shutdown mode. The most common cause is a problem in the convergence IC's. Both chips will have to be replaced and at a cost of around $350 for most shops. Thx
Bill W
integrityhomeworx.com
Mar 08, 2011 | Toshiba TN50X81 50" Rear Projection...
Shut off itself
sounds like you might have an auto overvoltage shutdown circuit kicking in. The hivoltage goes to high and the monitoring circuit auto shuts down. More than likely trouble is in hivoltage circuitry. If you have a transformer that will allow you to bring up the set slowly without shutting down and you can look to see what's happening.
Feb 16, 2009 | Sharp 25R-S100 25" TV
Problem with tv turning on and off
Does the green light begin to flash when the picture disappears? If so, you have a weak lamp causing your TV to shutdown the picture. Replace the lamp with an original Sony lamp as the aftermarket lamps are known to have problems such as early failure and low brightness. Please be sure to rate this solution. Thanks!
Nov 18, 2008 | Sony Grand WEGA KDF-42WE655 42" Rear...
My mitsubishi big screen tv has a green flashing light on the front and it seem to spark when you try to plug it in, I call the tv place where it was purchased and they told me to unplug it for 1 hour and...
is the green led on the front of the tv blinking only, if this is the case the tv is in shutdown state
you will need a tech in your house to find out if there is any short
Sep 15, 2008 | Televison & Video
Picture in Picture
cuse it only avb on these with seprate source ok llike dvd in one pip other tv ok not tv tv ok thx for using fix ya thx nick
Feb 04, 2008 | Samsung SPN4235 42 in. Plasma HDTV
Big screen tv repair
There is a short in this TV set somewhere. The TV set is trying to come on but because of the short, the power supply shuts down. No if it is not the over current shutdown, it could also be the main power supply with an over voltage shutdown protection mode. These are solid state TV sets and should only be worked on by trained techs. Good Luck
Sep 28, 2007 | JVC AV-56WP74 56" Rear Projection...
Toshiba tv model 32A443
hi sir, it is quiet clear you have a dried up capaciters in the power supply board and the capacitors of the feeding volts 115v 12v 24v please refer to qualified person to replace them all and evrey thing will come to regular state please don't forget to rate and remember i am here just for help thx
May 08, 2007 | Toshiba 32A43 32" TV
Televison & Video Logo
43 people viewed this question
Top Televison & Video Experts
