Copies jam and won't come through the copier.
How do I keep the copier from jamming?
  • Mitch Schwartz
    Mitch Schwartz May 11, 2010
    Copier make & model? Where is it jamming?
  • 161 Answers
Try using fresh paper, shuffling the paper and keeping all the fences flush.
Posted on May 08, 2009
Fix paper feeder that keeps jamming. How to clear jam and fix on-going jamming problem
What thickness of paper are you using? Also is the paper new/fresh or are you re-using paper that has gone through the printer already?
Mar 03, 2015 | Lexmark X4550 Wireless All-in-One Photo...
My kyocera KM 1815 keeps saying "paper jam 00 open left cover and remove paper jam but there is no jam
Hi
Check all the paper movement from the tray, left or right cover, front cover, if so then remove jammed paper. Otherwise the paper sensor spring guide missing or fell off from its original position. Check carefully where the sensor locate. paper sensors detect all the paper movement in the machine during copying or printing, so locate the place in the machine which the paper usually jammed, see the screen of the machine, it will locate the place where the paper jammed mostly. Sensor not return to it original position that is why ( remove paper jam keeps blinking)
Aug 11, 2014 | Kyocera Mita Office Equipment & Supplies
Printer keeps jamming
There might be something loged between the pickup gears. I would suggest bringing it in to a qualified printer repair shop to have it looked. it might be a simple staple or lint that's jamming the gears.
May 12, 2014 | Canon PIXMA MX892 multifunction printer
Paper jam displayed but no paper jam found. Cleaned with air but this did not help. Seems like printer wants to keep resetting itself.
I had this problem and someone on Fixya solved it. Open the back cover and slide the guide slightly. If it's off center it won't work and gives you the jam message even though there's no jam. It solved it instantly.
Sep 27, 2011 | Brother MFC-7820N Printer
The photo paper keeps jamming won't even print a picture
If it is keep jamming, then there has to be a small piece of paper that you can't see it stuck, re clean and check each rollers, out good.
Jun 06, 2011 | HP Photosmart D7460 Printer
When im making copies it will run off 4-5 pages and the jam up, i keep un jamming it and it keeps happening any ideas whats wrong?
Sounds as though the feed rollers for that particular paper drawer/cassette is in need of replacement.
Mar 28, 2011 | Canon NP 6545 Copier
WHAT IS THE FUSER ASSEMBLY? hOW CAN i REMOVE PAPER JAM?
This is near the exit area right before copy exits into the tray or sorter It appiles heat and pressure to the copy as it goes between the upper and lower fuser rollers so that the toner melts into your copies and won"t rub off keeping the image from smearing Often the copies will be warm--this is normal.
Apr 21, 2010 | Canon ImageClass D660 Copier
Always paper jam
there is so many reason for that
where the jam when u try to copy 1 copy
Apr 24, 2009 | Canon ImageRUNNER 3570 Copier/Printer
jasbo
jasbo
