I have recently aquired a router and a Wireless PCI Card. Although I am automatically on the internet when I boot up my Computer,I keep getting a message on screen that I have limited or no conectivity. why is this?. I have just gone over to SKY BROADBAND. As I am now using a wireless router, which wires can I safely pull out of my PC Tower Don Brooks
    President:
  • 2,961 Answers
The limited connectivity means that your router is not connected wirelessly probably because you have not entered the correct passkey, or it's still giving your lan RJ45 network cable the ip address and this is why you are still connected to the net.
If you are on a Netgear modem/router as i suppose you are if it's from sky, you should connect the RJ11 phone line cable into the router leading to a broadband filter, then connect the filter to your phone socket.
There should be no wires between your pc and the router, so take out the wire that is connected to the router (RJ45), which you should have used to set the router up coming from your onboard wired network card.
You will now be connected only via wireless connection, right click on the wireless network icon in your taskbar, click show all connections and then click on your SKY****, whatever it is and then you will need to enter the WPA-PSK security passkey which is with your Sky paperwork or on the router itself.
Posted on Sep 10, 2008
How Do I connect to internet with my desktop without Ethernet cable
To connect wireless to a network ..you need a wireless router or access to a near by one ..and you need to install a wireless card on computer if it has non ..This can be a pci card and you will install it on a pci slot inside and install its driver and after that connect to the network available ..or use a wireless card on usb ..
If you do not have a network free near by ..you can connect using the wireless card to another computer connected to the internet ..or install a wireless router on your Ethernet cable ..and a card in computer or a usb one ..
In my opinion the wireless card and router is the best way cause connecting trough another computer can be tricky and slow..
another way ..if you do not have any other means is to use a wireless modem on usb from a mobile network ISP (internet service provider )
This can be the same provider as your mobile phone one ..
Dec 18, 2011 | Dell Dimension 4500 PC Desktop
How do I change from wired hookup to wireless? Bob
Instructions
Things You'll Need
Broadband modem
Router compatible with modem
Internal or external wireless network adapter
Phillips screwdriver
Suggest Edits
  1. Prepare the Network
  • Purchase and setup a wireless broadband router by interfacing it with your wired computer. Choose a router that is compatible with your broadband modem and that supports the wireless network type you desire.
  • Enable WPA or WPA-2 security, and change your router's default password. Give your SSID or wireless network a memorable name.
  • Connect your modem to the WAN (wide area network) port on your router.
  1. Install an Internal Card
  • Purchase a wireless network card that is compatible with the router you purchased and with your computer. For example, if you bought a 802.11 b/g router, do not purchase an 802.11 n adapter.
  • Shut down your computer. Remove all cables and peripheral devices.
  • Remove the left side panel while facing the front of the case. You may need to remove screws or to manipulate latches and notches. Consult your case or computer manufacturer's documentation if you are unsure of how to remove the panel.
  • Clip the metal part of the anti-static wrist bracelet to a metal object, and ******** the bracelet.
  • Locate an available PCI or PCI-Express slot. Unscrew the screw that secures the slot cover that corresponds with the slot, then remove the slot cover.
  • Line up the wireless adapter's pins with the slot. Insert the card until it clicks into place. Do not force the card into the slot, or you may damage the card's connectors. If you feel resistance, remove the card, line up the card with the slot again, and reinsert.
  • Secure the card with the slot cover screw. Reattach the side panel, and replace any screws you removed earlier.
  • Reinsert all cables, and plug in all peripherals. Boot the computer.
  • Allow Windows the opportunity to detect the card. It should automatically install the drivers for the card. If you have updated drivers, insert the disk and install according to on-screen instructions.
  1. Install an External Card
  • Boot up your computer.
  • Insert your external wireless adapter into the appropriate slot. For example, if you purchased a USB slot, insert it into a USB port.
  • Complete Setup
  • Double-click the network icon in the task bar.
  • Highlight your wireless network. Windows will display the name you entered when setting up your router
  • Click the "Connect" button.
  • Enter and verify the security key you created when setting up the router. Click on "Connect."
If you have further query then try to let me know. Thanks for using FixYa.
Aug 27, 2011 | Cisco Linksys Wirelessn Router Black...
Can i connect wireless internet on my Dell Latitude?
if it's a tower... you'll need a linksys pci wireless card... and a linksys router... install the drivers first... then... with the computer off... follow instructions for installing the card... connect the antenna... and then turn on. wiat for the computer to boot... it should automatically find the card... now... on the back of the cable modem... disconnect the wire that was going to the computer... and put it in the connection on the router that says "internet", now... disconnect the cable modem... wait 30 seconds... then plug it back in... wait 1 min. for everything to come up... now... connect the power to the router... and wait 1 min... go to the linksys icon in the taskbar... and double click on it... survey the site... when you find the wireless networks that are avil... choose the one that's got the strongest signal... and click connect. now... open the internet broser... and go to tools... internet options... then connections, down at the bottom... you'll see lan... click on it... you should see a box that says automatically detect settings... make sure this is checked...then click apply... then on o.k... and exit the internet.... then go back in... you should have internet...
Apr 03, 2010 | Dell Latitude Cp, Cpi, Cpx, C600, C800,...
Dont have a wireless card on one of my desk tops can i get the net with a usb stick
You can install a PCI wireless card in the desktop computer or you can use an USB wireless device. Both of these devices can connect to your wireless router, but they need to be configured with the router's wireless settings.
If you do not have a wireless router, then you can get an USB wireless modem device that connects to the Internet that uses the 3G mobile network. The advantage of this, you can connect to the Internet anywhere you get mobile coverage with that Internet Service provider.
Mar 07, 2010 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Linksys wireless adapter won't auto connect to 2Wire router
Go into the wireless adapter settings and make your connection "default" and then it should connect automatically .. and if not then look for a "connect automatically setting
May 29, 2009 | 2wire HomePortal® 1800HW Router...
Which will be good to me????
wee if you do not have the wireless card you have to connect your desktop with wired connection in order to make it online but is you have the router in a different room you can also go for the wireless pci card that you can connect in your computer to use your desktop computer wirelessly...ok
Apr 29, 2009 | Acer Aspire 2100 (91.AB675.D02) PC Desktop
No ethernet port on older Dell desktop
Yes, all you need is a PCI ethernet card. You can pick them up rather cheap. Here is one. You basically plug it into an available PCI port on the inside of your computer. If XP doesn't automatically install it, just insert the included CD with the drivers on it and XP will do the rest. And remember to please give this answer a good rating of fixya. Thanks.
Dec 26, 2008 | Dell Dimension 2400 PC Desktop
WRT54G
check the cables. the cable coming from the modem should be connected to the internet port of the router.
power cycle. turn off all the devices then turn on the modem first. wait for the modem to boot up before turning on the router and the computers.
if you are using a wireless computer, make sure that you are connected to the signal coming from your router. customize (change ssid, wireless channel) your wireless settings if still set to default and try to connect again
hope this'll help you
ciao
Sep 28, 2008 | Linksys Wireless-G WRT54G Router
I cannot connect my laptop computor to my main computor
Bluetooth is not WiFi,   they are two seperate technologies.
you need a Wireless adapter 802.11b/g for your laptop,
you would connect the two to each other using an adhoc connection,
If you had a wireless router for your internet you could connect directly to the router, (and then you would not have to have your main computer on for you to access the internet.
BTW if your Main machine is near your phone point (for internet connection) you would not need a wireless card for your pc, as you could connect via LAN cable to the wireless router (make sure you get one with lan ports)
Oct 15, 2007 | NetGear - WG311 - 54Mbps 802.11g/b...
Computers & Internet Logo
142 people viewed this question
David Payne
David Payne
