Question about Optoma H30 Multimedia Projector
Can I buy and replace a clourwheel unit for my optoma H31 myself??
  • 4,234 Answers
There is no "color wheel" in these units. These projectors use a series of LCD panels and filters to create the picture as far as I know. That optical unit will not be cheap. WHat is the rpoblem with the unit that leads you to believe this needs to be replaced?
Dan
Posted on Sep 10, 2008
Optoma h31 stopped suddenly. I replaced the bulb, but the power button isnt flashing green, and I cant turn the unit on.
The little metal plate on the projector next to the bulb housing is not fully depressed (pressed down). The plastic cover is suppose to have a plastic piece protruding from it which is to depressed the metal plate when the cover is placed back on. If the metal piece is not pressed down, the projector will not light.
Feb 10, 2011 | Optoma H31 HOME THEATER PROJECTOR...
No picture
Hi, Possibly either of 2 reasons: 1. Your player is not sending any signal to the Optima meaning it is the one in question and not the projector; or 2. Your Optima lost its input signal, go through the signal source selection menu, try manual selection & set it to where your source/player is connected. Hope this works out for you, if not pls post again . Good luck and kind regards.
Aug 03, 2007 | Optoma H31 Multimedia Projector
Where do i find the ballast unit, both inside my projector and for sale?
In the optoma hd-81 there is a lamp unit housing.It goes faulty the lamp unit housing .There is no ballast in the hd-81 projector.There is lens ,the lamp unit housing and the circuit board.In most of the cases the lamp unit housing goes faulty.In that case the lamp housing needs to be replaced.It can be replaced and replacement lamp is also available. -------------------- Buying original lamp is always advisable.But there is compatible lamp also available.The original lamp housing is costly and compatible housing is bit cheaper.In some rare cases the compatible lamp does not work.But the compatible lamps also are good. To buy original lamp.Click this link directly:--- http://www.partstore.com/Part/Optoma+Technology+Inc/Optoma/HD81/Optoma+Technology+Inc/Optoma/BLFS300B/New.aspx ------------ this is link for compatible cheaper lamp.Click this link:-- http://www.partstore.com/Part/Optoma+Technology+Inc/Optoma/HD81/DNGO/DNGO/BLFS300BRL/New.aspx --------------- The procedure to replace the lamp:--- to get this procedure.Please click on the link below:--- http://www.partstore.com/Part/Optoma+Technology+Inc/Optoma/HD81/DNGO/DNGO/BLFS300BRL/New.aspx ------------ this link is for the user manual of optoma hd-81 and the procedure to replace lamp is mentioned on page number 59.Please read the instructions before replacing lamp.----------- This will help.Thanks.Helpmech.
Feb 03, 2011 | Optoma HD81 DLP Projector
I just put a new bulb in my Optoma H31, but still get Lamp Fail
have you check that the bulb you installed is the right bulb for your unit?
have you check by replacing your bulb it correct position?try to unplug the power cord and lug it again and turn on.
Oct 09, 2009 | Canon RS-LP02 Projector Lamp for LV-X6
Optoma h31 was unable to power up
It can have two problems. One is that the lamp has gone out and needs replaced. Refer to your troubleshooting section in your manual. Also can be bad capacitors in the power supply circuitry or Voltage Reg. IC. Either should be left to competent repair individual.
Jun 24, 2009 | Optoma H31 Multimedia Projector
Optoma H31 - Turns itself off !
sounds like the projector lamp to me. the rated hours are always up to the published hours and never "this is what you will achieve." I would suggest getting a lamp as you will need one shortly by the sounds of it. In many cases the projector does this as it is programmed to protect itself from the lamp shattering inside the projector. Let me know if you would like a quotation for a lamp as we ship internationally. Regards Kevin Andreassend. http://www.iceav.co.nz iceavtech@gmail.com +64-9-4142348
Mar 28, 2009 | Optoma H31 HOME THEATER PROJECTOR...
Dell 3200 Projector color yellow is grey
Hi tweezers
NO , it will definitelly not solve the problem at all.
Usually if there is a discoloration it is either the colourwheel ( turn the Projector upside down and back again - if you hear anything loose falling around on the inside - then your clourwheel is broken) But the unit will switch off almost 98% of the time if the clourwheel was faulty.
Otherwise it is gonna be your Mainboard that needs repair or replacement. Must warn you it is a expensive part to have replaced.
Mar 21, 2008 | Dell 3200MP Multimedia Projector
Optoma H30 Multimedia Projector Logo
106 people viewed this question
Top Optoma Office Equipment & Supplies Experts
jasbo
jasbo
color wheel light...
Are you an Optoma Office Equipment and Supply Expert? Answer questions, earn points and help others
