Question about LG Refrigerators
Have an LG LFX25960TT refrigerator with in door ice maker. The ice maker only makes 2 to 3 ice cubes at a time. (Too slow for my family's needs.) It appears like it doesn't get enough time to fill. Is there a way to change the valve timing if that is the problem? Paul
  • 1,543 Answers
Check to make sure the water supply to the refrig is good and the inlet screen where the water line connects to the refrig is clean. You can change the amount of water fill by pressing the button on the left side of the ice maker. (indicator lights above button show setting) Selecting "Ice Plus" on front of dispenser panel increases ice production for a 24 hour period. Ice maker should produce 6 cubes per cycle, aprox.. 100 to 130 cubes in 24 hours depending on freezer compartment temp, room temp, number of door openings, etc.
Posted on Sep 10, 2008
The ice maker will make at most 36 cubes of ice. this is from day 1 of owning the #$()$ thing. The manual states it should make 80-120 cubes a day. We have had the ice maker replaced three times. The...
check water filter, water valve.,what state do u live?
if wisconsin , need to check city water
i can get more infromation for u. not now. how about tomorrow.
please sent me e mail
i live wisconsin. i try my best to fix ur problem
good lock
i fix many ice maker and ice machine every year
Jan 12, 2011 | LG LFX25971ST Bottom Freezer French Door...
Ice maker over makes ice then ice cube tray cannot empty and new water comes in and overflows into ice bin. stop are does not seem to be low enough to cut off production.
WHEN THE UNIT GETS FULL YOU ARE GOING TO HAVE TO SHUT ICE MAKER OFF...
unfortunately there is no sensor to tell the ice maker to stop production so this will happen. sounds like the unit makes more ice that your family uses which normally would be a good thing... just shut the ice maker off until time to make some more and then switch back on ...
hope this helps you out.....
Jan 03, 2011 | LG LRSC26910 Side by Side Refrigerator
My LG french door ice maker won't make ice.
THE WATER LINE POSSABLY FROZE YOU MAY NEED TO REMOVE YOUR FOOD AND UNPLUG IT OVERNIGHT WITH THE DOORS OPEN.MAKE SURE TO WATCH FOR WATER ON THE FLOOR.
May 15, 2010 | Refrigerators
Ice maker stopped working. The cubes gradually got smaller until it just stopped producing cubes
Here is a tip that I wrote about the reasons why ice makers do not work.
Ice Maker Problems and Ice Maker Troubleshooting
heatman101
iot47
Oct 05, 2009 | LG LFX25960ST Stainless Steel French Door...
Water dispenser on front of refrigerator door does not dispense water. Ice Cube maker continues to make ice cubes. Defrosting doesn't fix problem.
Water dispensing solenoid is bad. You need to replace the solenoid valve. This typically is independent of the ice maker.
Jun 02, 2009 | Frigidaire FRS26R4A Side by Side...
NOT MAKEING ICE CUBES
well 9 1/2 times out of ten it is the ice maker i recommend you shop for a new ice maker... whirlpoolpartssurplus.com can get you a real good discount and free shipping...call them
Apr 27, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
LG ice maker only making two ice cubes at a time
Colenoid in the ice dispenser may be clogged or have a small amount of trash in it. Is there a filter on before the fridge (just after the ice maker shutoff)?
Mar 21, 2009 | LG LRSC26910 Side by Side Refrigerator
Ice Cube Maker
Here is a link for the srevice manual ( section 7 discusses how to troubleshoot an ice maker ) that should get you going..
http://136.166.4.200/contents/Fridge/LFX25960/LFX25960_Service_Manual.pdf
Hope this helps you...
Sep 14, 2008 | LG LFX25960ST Stainless Steel French Door...
LG ICE MAKER
Be sure that the fill tube is getting into the ice maker and that the ice maker is not blocked with ice.  If everything seems ok, you may have a leaking water valve which causes it to constantly drip water into the ice maker causing the block of ice.
May 16, 2008 | LG LFC25760 French Door Refrigerator
Have a LFX25960TT L G fridge . missing ice bucket and Auger needed to deliever ice cubes to door dispenser. Can not find a parts list of what needed service supplyer thinks that ice bucket assembly may be...
Hi, I have a lfx25960tt with a deep scratch door. Can I repair the door with some sort of metal scratch remover? Also do they sell just the door metal cover?
Mar 29, 2008 | Refrigerators
Refrigerators Logo
485 people viewed this question
Top LG Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
