Question about Vivitar 285HV Flash
Vivitar 285 flash
What is the trigger voltage of a vivitar 285 flash
    Champion:
    Scholar:
  • 216 Answers
Do you have a DVM?
atdlee@netzero.com
Posted on Nov 19, 2008
  • 66 Answers
285 HV has 6V
but old model 285 has more than 255v
Posted on Mar 04, 2010
Prfghgh
Posted on Sep 10, 2008
Just need to know if the following flashes can be used with the nikon d 3100 digital slr. 1) vivitar 285 hv 2) Metz 45cl 1
Both flashes have trigger voltages at the high end of the safe range for digital SLRs, according to the list at http://botzilla.com/photo/strobeVolts.html
I wouldn't use either on my Nikon DLSR without something like the Wein Safe Sync:
http://www.weinproducts.com/safesyncs.htm
Jun 29, 2011 | Cameras
I dont have any problem with Vivitar Flash.. I am currently a Nikon D3000 user and I need an external flash for shooting in low lights and portraits in my garrage-made studio..I searched ebay and found...
The Vivitar 285 HV is specified to have a trigger voltage of 12V. The Nikon DSLRs are specified to be safe up to 12V. This puts the combination right at the fuzzy point. It should be safe, but if the flash goes a little high while the camera goes a little low, you might run into trouble.
The 285 (no HV) is definitely a no-go.
Jan 18, 2011 | Vivitar Cameras
Can you use a vivitar 285 flash with a nikon D90 , if so do they still sell the cord that connects to the camera for off camera flash??
You can use the 285 with the D90, just don't do it without something isolating the two to prevent the trigger voltage from frying the D90. You can use something like the Wein Safe Sync
( http://www.weinproducts.com/safesyncs.htm ) for this.
As for an off-camera cord, you can use something like the Nikon
SC-29 ( http://shop.nikonusa.com/store/nikonusa/en_US/pd/productID.213505500 )
Sep 23, 2010 | Vivitar Cameras
What is the diff between a vivitar 285 and a vivitar 285hv?
285 has high trigger voltage(+250v) ,where as 285 HV has less than 5.5 volts trigger voltage (which is safe to be used for any digital SLR2_bing.gif). 285 HV has a Thyristor circuitory.
Mar 31, 2010 | Cameras
Need help with Vivitar 285 voltage
You should not put AC voltage into DC circuits.
A better directions:
Open open the 285 and solder two wires(red = positive; black = negative) then snake it out to AC connector(this needs to be removed).
Buy 7.2V plug set from Radio Shack or remote control car stores.
Buy 7.2V Battery and Charger.
This will be better than buying the Quantum & cable battery.
It will also wake up the flash faster than using the Quantum.
The total cost should be less than $85.00.
The battery is about 5X stronger than those 4 AA and they do last longer.
eltroman
atdlee@netzero.com
Jan 02, 2009 | Vivitar 285HV Flash
Switch from film to digital cameras.
I also own a Vivitar 285 that i used with my Canon F1 manual 35mm camera. Most older cameras before the advent of digital, had a hot shoe on top of the camera, or like in my case, the hot shoe went over the rewind knob. I also had to plug in a power cord from the 285 flash foot and the cameras PC connection in order for the flash to work on some other cameras. The Canon Rebel XTi has a TTL (through the lens) hot shoe usable with Canon's own EX flash units. You can buy a "hot shoe to PC connector" if the TTL camera hot shoe doesn't work, but be extremely careful, the only problem that exists with the older manual flash units was the trigger voltage is as high as 200+volts which would fry digital camera hot shoes. I tried my unit with a Wein flash trigger device on the PC cord of the flash and my Canon D60 with it's own flash. All shots were overexposed and washed out highlights.  Here's a copy of the hot-shoe review:h The EOS 400D's hot-shoe can be used with Canon and third party flashes (although sync only on most third party units). The hot-shoe is E-TTL II compatible. Compatible flashes include Speedlite 220EX, 380EX, 420EX, 430EX, 550EX, 580EX, Macro-Ring Lite, MR-14EX, Macro Twin Lite MT-24EX and Speedlite Transmitter ST-E2.  The Canon Rebel XTi doesn't have a PC socket to plug in a manual flash trigger cord which common sense tells me there is no provision to step up the voltage to trigger manual flashes - so my answer is this combination is not a good idea on a Canon Rebel XTi. Hope this helps.
Dec 12, 2008 | Vivitar 283 Flash
Will a Vivitar 285HV fry my Canon EOS 40D? I'd like to experiment with a Vivitar 285HV as an on-camera hot shoe flash. However, I'm reluctant to proceed because of conflicting reports about voltage...
Personally, I would not try it. While the Canon has a protection system built into the camera, the trigger voltage on the Vivitar is pretty high. I have had good results using a 283 on a slave shoe, you will have to stop down more with the extra light
Jan 08, 2008 | Vivitar 285HV Flash
Vivitar 283 flash will not work on camera.
To test everything except the camera, just short the contacts on the Wein protector. If the flash fires, the problem is in your camera, and maybe the protector did not do its job as good as expected.
Good luck
Aug 29, 2007 | Cameras
Vivitar 285HV Flash Logo
229 people viewed this question
Top Vivitar Cameras Experts
Tony
Are you a Vivitar Camera Expert? Answer questions, earn points and help others
