Question about Hitachi SSF420TR 20 in. TV/VCR/DVD Combo
No red color on screen
My red color does not appear on the screen. I have removed the case and looked for loose wires but found nothing out of place. The red went out of the screen after the TV fell. Perfect piture other than wild color combinations. I tested a DVD with a red tractor and it shows as a blue tractor on this TV. The color problem is the same in the game mode, TV mode and DVD.
  • Anonymous Feb 18, 2008
    Same is the case with mine
  • Anonymous Sep 22, 2008
    red color from tv screen has disappered in place of red dark blue or black how this problem can be fixed plz help me with the diagram of tv circuit borad where the problem is solved my email id is sjignesh@rediffmail.com
    My television set is BPL FHR 21 from india
    President:
  • 3,130 Answers
Sounds like you cracked the printed cuircut board on the crt drive board or in the video cuircut.. If you know how to solder look very carfully with thw set unpluged for crack on the crt pcb or the main board then scratch off the paint on the little pc traces on both sides of the crack and solder a wire across the trace
Posted on Apr 02, 2006
SOURCE:
I replaced ECG cable for **** jiang machine ,new have different colors of limb lead ,white for RA,black for LA,green for RL,red for LL , so previous lead red forRA ,yellow for LA green for RL ,black for LL...
First off wires are wires so the color bear no significance to their performance. The color coding is solely for the user to place the wires in the proper place.
What appears to have happened is your old wires were based off the European Colour Code and your new lead wires are American Color Code.
For American color coding remember clouds (RA - white) over grass (RL - green) and smoke (LA - black) is over fire (LL - red).
Feb 27, 2014 | Medical
I have lenovo g550...my screen flickers in every 5minutes...
Failing Inverter An inverter, typically found inside a laptop computer, consists of a small board, which has impregnated electronic circuits stamped on it. Inverters look like thin boards about the of two sticks of chewing gum. The inverter and its bulb control the intensity of the liquid crystal display, which lights the screen monitor. The computer can control the output voltage of the inverter and either lighten or darken the screen. A special type of inverter can adjust the brightness of the screen by using an internal sensor to judge the room brightness, and then adjust the screen accordingly. Failing inverters give off some specific warning signs, which can be recognized by observing different screen characteristics.
Short Intermittent Display Upon turning on the laptop, the screen flashes on in the normal mode for a short period and then blinks to black. A very faint image appears in a dark background, which will be very hard to see almost invisible. After shutting off the laptop and restarting, the same mode occurs, where the screen appears normal for a few seconds then fades to black. This condition points to a failed inverter. To confirm this, plug in an operational external monitor; if the external monitor functions, the inverter has failed. b> Total Blackout with Ghost image b> The laptop turns on, as indicated by the power supply button, but the screen comes up black. The screen comes up black after restart. You might be able to detect a very dim or ghost-like image on the monitor. When you plug in a known functioning external monitor, the external monitor operates normally. This mode of display indicates a failed inverter. b> Long Term Periodic Operation b> With this failure mode, the laptop screen illuminates normally upon start-up and remains that way after several minutes, hours or even days, until it goes very dark again. Brightness controls or restoration attempts do not work. Most often, the screen will function normally with a computer restart, but will eventually return to black. Faint ghost images might appear, as seen in the total blackout mode. b> Dark With Color Variation b> Upon computer start-up, the monitor shows black or dark gray, accompanied by very faint images. The screen might have an intermittent color change, or remain on with a non-standard color variation, like pink or red. b> Auto Control Switch b> If the screen appears black, with no faint or ghost images, look for the lid switch near the back hinge. The switch, when depressed with a closed lid, shuts off the computer and monitor functions. Sometimes the switch becomes stuck in the closed position, disallowing the computer and monitor to turn on when opened. Pushing the switch manually several times can often free it up. If the switch tab has broken or jammed inside the case, it needs replacing. b> Loose Connection In this mode, the display looks normal upon start-up, but tapping the side case of the computer turns the screen black. More tapping results in the screen functioning normally then cutting out again. This condition points to a loose wire connection from the inverter to the LCD backlight lamp, or the video cable. The connectors can be accessed by removing the monitor bezel screws and pulling the plastic retainer off. Both connectors can be cleaned and refitted.
Feb 10, 2013 | Lenovo G550 PC Notebook
Television is a Tosiba DLP 72HM195
your tv needs a y-load board its like a grafix card as computers have due to overheating the board components are affected this is a manufacturing fault it tends to happen with samsung aswell
Feb 22, 2012 | Toshiba 72HM195 72" HDTV
Hello, I replaced a light fixture on my existing Emerson ceiling fan. The light worked right away but the blades didn't turn. I could hear power going to the motor so I went back into the switch cup and...
Signs of a bad capacitor in a ceiling fan include:
  • Fan runs slowly or not at all on all speeds
  • Fan will not start but will spin if started by hand
  • Certain speeds are slow or do not work
  • The motor hums and turns freely by hand but will not spin
    The capacitor is usually a black box inside the switch housing of the fan. If this box appears burnt or melted in any way, that is also the sign of a bad capacitor and it should be replaced.
    have a good day !!
  • Feb 17, 2011 | Emerson Fans CF705AW 52" Northwind Ceiling
    When turning on Dell laptop, lcd screen turns gray
    Maybe you have wrongly pressed the keys for turning down the brightness of Dell inspiron 1545 under a careless.Just back to the normal setting. Good luck!
    Feb 17, 2011 | Dell Inspiron 1545 Notebook
    Colorful "speckles" on screen
    Could be the screen burn from watching T.V. on a show and the thing burnt in (in this case the colors, yes it can burn colors.) and there's nothing you can do. The insides of the T.V.'s have plasma gases which can flow out of control.
    Jan 14, 2009 | LG DU-42PX12XC 42 in. Plasma HDTV
    Convergence toshiba 50a62
    Projection TV sets have several common problems listed below.
    Problem #1) Convergence
    Symptoms:
    • Screen Looks 3-D
    • Colors wont align
    • Screen may look distorted
    • No Audio/Video - makes a chirping sound.
    Example Photo:
    Problem #2 CRT Fluid has clouded over.
    Symptoms
    • Dull Video, Washed out
    • White/Bright looking video
    • Halos around objects
    • Red/Orange looking
    Example Photo:
    You can see more examples and find a fix here...
    bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
    Nov 20, 2008 | Apex Digital GB5108 51" Rear Projection...
    Sennheiser SK 100 Bodypack Transmitter won't power up.
    Hello. I Am Not Familiar With This Exact Model, But I Have And Still Do Own A Number Of Wireless Units. There Are A Number Of Things That Can Go Wrong, But If The Unit Wont Power Up, I Would First Check The Battery Compartment For Loose Battery Connections. Over Time They Can Weaken Or Just Get Bent The Wrong Way. Then I Would Look For Loose/Unsoldered Wiring. I Have Encountered Many Cases Where The Battery Compartment Contacts Become Loose , Or The Wiring Going To It. Good Luck
    Nov 06, 2008 | Audio Players & Recorders
    ECS 755 A2 motherboard problems
    Make sure you have the correct front panel header connected correctly to the case wires. Open you're manual to page 12 under the English section. There you'll find a picture of the front panel header & how to connect the case's LED's to the motherboard.
    If you no longer have the manual you can download it from ECS at this link.
    http://www.ecs.com.tw/ECSWebSite/Products/ProductsDetail.aspx?detailid=381&DetailName=Manual&MenuID=1&LanID=0
    Chances are you may have the wire's connect backwards. (Positive + connected to the negative - ECT).
    Example, pin 1 is the + for hard disk drive & pin 3 is - for the hard disk drive. Cases vary on wire colors, normally if each connector has a common colored wire (solid color) that common wire would be the negative. Stripped wires are negative. Other cases use white colored wires as negative & colored wires as positive. As far as you not receiving any display. Try removing the AGP card & clean the copper contacts. Clean with alcohol.
    Place a couple drops onto a cotton swab & clean the copper, both sides. Blow out the AGP slot with canned air. Re-check all connections, power & data cables before closing the case. Power on the system & check the front led's for operation.
    If you still fail to get display, re-check the connection from the monitor to the case. Try you're monitor on another system. If good than you're video card could be bad. You're motherboard can run an 8x/4x speed AGP 1.5volt (only) graphics card.
    Good luck zeratu_l !
    Need more help? Post within this link.
    Mike
    Jul 28, 2008 | Computers & Internet
    Screen Gone "Yellowish" Colour, Appears that Blue colour is not working
    your problem is in blue color cathode circuit. as you say that it becomes ok tha5t means 1 cable wire is loose from computer to monitor. 2 crt base loose. 3 loose contact in blue video ckt. 4 signal processor cable to crt board connector loose.(blue wire)
    Oct 14, 2006 | LG Flatron F700B 17" CRT Monitor
    Hitachi SSF420TR 20 in. TV/VCR/DVD Combo Logo
    1,265 people viewed this question
    Top Hitachi Televison & Video Experts
    Jaime Hernandez
    Steve Allison
    Steve Allison
    Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
