Question about Indesit 24 in. IDL500 Built-In Dishwasher
Dish washer IDL 550
Hi
My dishwasher dose not drain water, and now dose not turn on the machin
Any body can help me?
many thanks
    An expert whose answer gotĀ voted for 100 times.
    Novelist:
  • 171 Answers
Hi meeey,
I'm Harvey the Master Plumber.
Your problem is: Your dishwasher dose not drain water, and now dose not turn on the machin
Any body can help you?
If the motor runs but it won't empty then the pump needs replacement. If the unit washes but the motor won't come on to empty then you have a control problem. Either way I don't recomend this repair to the average homeowner. You might consider utilizing our Repair Directory to find a repair man. If the d/w dosen't come on at all then it may be time to consider replacement.
Feel free contact me again!
Please give me a rating here at fixya.com before you sign off
Thank you,
Harvey your Master Plumber
Posted on Sep 13, 2008
Water stays in bottom of dish washer
Here is a tip that I wrote that will help you with your dishwasher not draining problem...
Dishwasher Problems - Water will not drain out
heatman101
Apr 18, 2011 | Maytag Washing Machines
Indesit IDL 40 slimline dishwasher does not drain completely
heatman101
Jan 05, 2011 | Indesit 18 in. D41 Slim-Line Free-standing...
THE DISH WASHER DON'T REALEASED THE DIRTY WATER AFTER IS DONE I HAVE TO TAKE IT OUT WITH CUP. I NEED TO KNOW WHAT IS WRONG. THANKS
heatman101
Dec 28, 2010 | Bosch 24 in. SHU43 Built-in Dishwasher
We have hard water at our home, but the new dishwasher leaves a thick film on the glasses. We use the rinse agent, but it's awful.
You have to buy a cartridge type water softener and attach it to the
inlet water line of your dish washer. In addition to this there must be
a salt compartment in the dish washer.
Refer the user guide /owners manual and locate. Fill it with the special
dish washer salt. ( Do not use kitchen salt used for food).
The dish washer salt may help to certain extent in softening the wash
tub water inside. Check the switch settings for rinse aid and salt
release settings in the machine. Refer manual!
Oct 01, 2010 | Frigidaire FGHD2471K Builtin Dishwasher
Water fill problem on Hotpoint Dish Washer Deluxe Model DF 31
Pl check the small filter fitted near the water inlet hose. Probably you may have to pull this filter as this is housed in the threaded pipe attached to the body.
Remove the hose from the machine and try flushing. see whether you get sufficinet pressure from over-head tank!
Clean the filter with tooth brush or reverse clean. Do no for get to fit rubber washer.
Mar 30, 2010 | Hotpoint 24 in. DF55 Free-standing...
Frigidaire Dish washer MODEL
hi there aaliyazaidi2.is the water clear or dirty that you find in the dishwasher?there are two ways this could be happening.1,if the water is dirty[although it dose not have to be ,but its a sure clue]its you drain line of your dishwasher.what happens is because the drain line is lower than the sink drain, when you use your sink water runs by way of gravity in to the drain hose and then fills up your dishwasher,till you drain it or wash a load...to solve this problem you need too make a loop as we repairman call it.get some zip ties ,or what ever[string] and tie your drain hose off at the top off the sink under the sink cabinet[imagin your drain hose as a roller coaster, the hose coming from the dishwasher is the start of the coaster before it goes to the top of the big hill.what you want to do is ,at the top of the roller coaster hill,tie your drain hose to what ever you can under you sink causing a hill so when your hose goes back down ,it ends up into your disposer or what ever plumbing it ends up into.[hay i hope i helped you understand what i mean their];#2,the other way is your dishwasher water valve may not be sealing well. the water would only be clear if this was the issue and could be warm water because its only hot water to the dishwasher.what happens here is because the water valve is not sealing water slowly adds to your dishwasher may be drops at a time,and over the hours gone by it accumulates and the you notice water in the tub.to solve this you replace the water valve.its[most of the time blue,but could be tan or white]under the dishwasher.the water line from your house goes to it.i hope this helps you you can email if you need more help. God bless ,tom
Feb 25, 2009 | Frigidaire 24 in. FDB510LC Free-standing...
Water backs up to the dish washer from the sink .
Check the drain hose under the sink. It should have a high loop an upside down "u" like a hill the water can't climb to get from the sink to the dishwasher. That is where I'd start. Good luck.
Jan 07, 2009 | GE 24 in. GSD6660GSS Built-in Dishwasher
Water left after finishing wash
I have a Bosch Dishwasher and the E-Nr is SGS4362EU/03. The machine is approximately 4 years old, in good condition and has been working very well. Suddenly, there is water remaining after it completes a 50 degrees C wash cycle. This is also evident with the pre wash cycle and the 65 degrees wash cycle.
I have checked and cleaned the filters. I have loosened the internal pump white cover (Torx T 20 screw) and checked for any physical blockage - none. I have also checked for any drainage hose kinks - none.
I have tried a series of empty washes and the machine drains the water during the wash cycles. The dishes are also have a dull colour and show show signs of not being properly rinsed during the wash cycle.
Please assist.
Reagrds,
Brian
Dec 27, 2008 | Bosch 24 in. SHY56A05 Stainless Steel...
Indesit IDL 50 Dishwasher
Had a similar problem (flashing lights 1 and 2). Drained the machine by diconnecting the outlet hose and using a shallow bowl on the floor. Removed and cleaned filters. Forced clean water through by using a garden hose pipe(you can only do this one way, you cannot force water down the outlet pipe). Removed and cleaned the pump (you have to do this from under the machine but easy enough). Finally ensuring the waste trap under the sink was clear. Bingo!! No parts, no expensive engineer.
Jun 04, 2008 | Indesit 24 in. DE73 Evolution...
Dishwasher dose not drane
YOU CAN TRY REMOVING THE LOWER RACK AND LIFT OFF THE SPRAYER. THE DRAINAGE WHOLE IS USUALLY VISABLE. YOU CAN FLUSH OUT THE DRAIN TO SEE IF THAT DOES IT. THERE SHOULD BE NO STANDING WATER IN THE BOTTOM OF YOUR DISH WASHER AFTER WASH CYCLE AND DRY CYCLE. HOPE I COULD HELP.
May 02, 2007 | Hotpoint 24 in. DF55 Free-standing...
Indesit 24 in. IDL500 Built-In Dishwasher Logo
368 people viewed this question
Top Indesit Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Eric Taylor
Are you an Indesit Dishwasher Expert? Answer questions, earn points and help others
