-   The toucj screen has become unusable after removing and replacing the battery.-   abajab
Nov 28, 2008
-   My problem is with a Palm TX & not exactly the same except that it sounds like it might be the digitizer, the sandwhich screen which when tapped touches the other side communicating whatever you've input on the screen to the PDA's motherboard.
In simple terms, shop around on the internet to get some information as to what your options are to get it repaired or order the parts & repair it yourself. My TX at one time or perhaps still does, retails new at $300 US or $180 US for a refurbished unit. I have no idea what your unit would cost new, refurbished or repaired.
Good luck.-   bertlefr
Jan 07, 2008
-   T-mobile Wing...touch screen is not working...message says "tap screen to set up window mobile based device", but I am unable to do this because the touch screen is not working. Please help...thank you!
Deborah-   mizzd44
Your digitizer might be dead, and if so the cost to repair it could buy you a whole new PDA.
But since it's fix or chuck(if you don't get any better advice), you should open it up and take a look inside. Check to see if the wires aren't loose or if some corrosion didn't occur inside.
How maximum real (uncached) write speed to both type memory card (SD and CF) ?
How maximum data...
(More)
How maximum data copy speed from CF to SD, from SD to CF ?
Maximum size SD card ? Maximum size CF card ?
I got lost my CD with soft for Toshiba E800. Where can i find ATI Presentation Pack which is...
(More)
I got lost my CD with soft for Toshiba E800. Where can i find ATI Presentation Pack which is standard one for this Pocket PC? Kind Regards Toshikar
Right, I recently got a Toshiba E800 Pocket Pc, It's was used before me so it isn't new. Ive been...
(More)
Right, I recently got a Toshiba E800 Pocket Pc, It's was used before me so it isn't new. Ive been trying to connect to the internet and having no luck at all I have Wirless LAN IEEE 802.llb thing which goes into the top and I'm guessing thats the thing used to connect to interent. It picks up my network at home and everything and says it connected but still internet won't work. I downloaded a Manual from Toshiba and checked out the Wifi apperently I should have In settings>system two programs.. 1) Wirless LAN Manager 2) Wirless Networks I don't have that at all and Im sure there needed There also a few other programs missing. Ive checked out Toshiba to see if I can download them no luck.. even if they did I actual don't know how to transfer it anyways. There also this activesync thing but Im sure thats only to do with contacts ect for all the buisness side of it. But yeh Im stuck at what to do.. any thing would help please..
