Question about Sony FD Trinitron WEGA KV-36FS120 36" TV
No volume and channel display
I messed up in service mode, how can I get the volume and display back up?
  • 10,594 Answers
You should have its service manual to perform adjustments. let me know do you have it? also mention what data of adjustments you disturbed so resulted lost sound and display back-up.
Regards,
Posted on Sep 10, 2008
What is standby mode and how to take off TV will not turn on
It means that something in the power section has failed,and the system goes into standby (safety) mode.Could be a fuse,resistor,or IC.Does it blink? On your remote you could press display,channel,5,volume - (minus),then power,for the diagnostics,.....for service mode press display,channel,5,volume + (plus) then power,press 8 then enter
Mar 08, 2010 | Sony FD Trinitron WEGA KV-32FS120 32" TV
My kv34hs510 will not power up and the standby light flashes 6 times and then repeats.What is wrong? Ron....
There is a power issue,tv goes into standby (safety) mode. For self-diagnostics, press Display,channel,5,volume - minus not plus,then press power. You have no horizontal output,check IC206,C516,C515....for service mode press Display,Channel,5,volume + plus,then power,press8,then enter......hope this helps....
Mar 08, 2010 | Sony FD Trinitron WEGA KV-34HS510 34" TV
The volume of sony wega kv-sw29m61 set always to maximum when it turned on
On your remote control (with tv off)
1. press Display, channel 5, Volume Up and then Power
this brings up the service mode (you will see some green text on your screen)
2. Press channel 2 to scroll through options until you see "Micro" in the upper left of your screen
(channel 2 cycles up through the options, channel 5 cycles down)
3. Press channel 1 to scroll through suboptions until you see "DIOF" appear under "Micro"
(channel 1 cycles up through the suboptions, channel 4 cycles down)
4. Press channel six until the default value (12:60) changes to 12:40
(channel 3 increases the value, channel 6 decreases the value)
5. Once the value has been changed to 12:40, press Muting and you should see red text in the upper right hand corner that says "Write"
6. Simply turn the power off and back on for the change to take effect. Your volume problems should now be fixed.
Jan 16, 2010 | Televison & Video
How do i reset the lamp life for sony KDF-E42A10 ?
1) In standby mode, press the buttons on the Remote Commander sequentially, in rapid succession:
[Display] , Channel [5] , Sound Volume [+] , Power [ON]
2)To enter BE-micro service mode menu, press JUMP 2 times.
3) To display the lamp time, press Channel[4]
The screen displays:
“ Total lamp time is 14 hours”
4) To display the lamp time clear, press Channel[5]
7 times and Channel[1].
To reset the lamp time press Channel[3] > [MUTE] > [ENTER].
WRITE (Character color is red) is momentarily displayed and the lamp time is reset to “0”.
This worsk for other Somy retroprojection TVs as well, eg. KDF-E50A10 , KDF-E50A11 etc.
If you goto eserviceinfo.com you'll get the whole service manual
HTH!
zioanza
Dec 01, 2009 | Sony KDF-E42A10 42 in. LCD Television
Need a service code for TCL TV model DP29E10C
Hi, tcl dp29e10c model
The TV's horizontal display is messed up and I need the service mode code to be able to do this
Aug 20, 2009 | Tvone TV-207 Television
Sony kde 50 xbr 950 blinking code
turn tv off, the use the code afore mentioned and it will turn on in service mode. You best know what you are doing. You can really mess tv up in there
Nov 13, 2017 | Sony Televison & Video
Black box when tv is on and going through channels
This worked on my tv...give it a try:
go into your menu and find closed caption, someone has accidently set the closed caption mode to text, when the on screen display of channel or volume goes away the box appears. turn off the closed caption feature or switch it to something other than "text" mode, and your box will go away.
Apr 10, 2009 | JVC AV-36S33 36" TV
Sony FD Trinitron WEGA TV Model Number KD27FS170 volume problem
my sony trinitron is blinking six blinks and I cannot turn it on, please help
Nov 22, 2008 | Sony FD Trinitron WEGA KV-36XBR800 36" TV
Toshiba 42h82
1. ENTERING TO SERVICE MODE
MUTE
S
(Service mode display)
3) While pressing the MUTE button,
press MENU button on TV set.
2) Press MUTE button
again to keep pressing.
1) Press MUTE button twice
on Remote Control.
2. DISPLAYING THE ADJUSTMENT MENU
1) Press MENU button on TV.
Adjustment mode
Press
Press
Service mode
Item
S Data
3. KEY FUNCTION IN THE SERVICE MODE
The following key entry during display of adjustment menu provides special functions.
Screen adjustment mode ON/OFF: TV (ANT)/VIDEO button (on TV)
Selection of the adjustment items : Channel s/t (on TV or Remote)
Change of the data value : Volume s/t (on TV or Remote)
Adjustment menu mode ON/OFF : MENU button (on TV)
Initialization of the memory (QA02) : RECALL+Channel button on TV (s)
Initialization of the self diagnostic data: RECALL+Channel button on TV (t)
“RCUT” selection : 1 button
“GCUT” selection : 2 button
“BCUT” selection : 3 button
“SCNT” selection : 4 button
“SCOL” selection : 5 button
“TNTC” selection : 6 button
Convergence adj : 7 button
Self diagnostic display : 9 button
Oct 21, 2008 | Televison & Video
In this situation as I don't know what adjustment item has been changed, go to service mode and press 5 and 0 on remote. This will reset all adjustments data on factory default. press mute and zero to write on memory. I want to inform you that after above procedure, you will have to adjust Horizontal, Vertical picture size and pin amp adjustments to get normal picture.
Good luck.
Sep 10, 2008 | Sony FD Trinitron WEGA KV-21CL10 21" TV
Sony FD Trinitron WEGA KV-36FS120 36" TV Logo
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
