Question about Dishwashers
Washer wont empty water - Dishwashers
  • edsox317 Sep 10, 2008
    water wont empty
    An expert whose answer gotĀ voted for 100 times.
    Novelist:
  • 171 Answers
Hi meeey,
I'm Harvey the Master Plumber.
Your problem is: washer wont empty water
If the motor runs but it won't empty then the pump needs replacement. If the unit washes but the motor won't come on to empty then you have a control problem. Either way I don't recomend this repair to the average homeowner. You might consider utilizing our Repair Directory to find a repair man.
Feel free contact me again!
Please give me a rating here at fixya.com before you sign off
Thank you,
Harvey your Master Plumber
Posted on Sep 13, 2008
My washer has slow drain and won't spin out completely. What might be the problem?
Repairing a Washer That Won't Drain or Spin ' ThriftyFun
www.thriftyfun.com/Repairing-a-Washer-That-Wont-Drain-or-Spin.html
Did everything look at everything that has to do with slow water draining. ReplyWas ... My washer washes fine, but it won't drain the water out or spin on any cycle. The guy who .... My Kenmore 417 washer will not completely empty and spin.
my washer won't spin and empty? ' Yahoo Answers
https://answers.yahoo.com/question/index?qid...
Jan 15, 2008 - If your washer spins but doesn't pump the water out, the drain line is probably clogged. In many washers, a small sock or other piece of clothing ... My Whirlpool washing machine won't empty all of the water after ...
Mar 21, 2013
Clothes washer won't spin clothes to drain water out?
Jun 11, 2008
More results from answers.yahoo.com
Why won't my washer spin or drain? - Kenmore 110 Series ...
https://www.ifixit.com/.../Why+won't+my+washer+spin+or+drain
iFixitMar 16, 2014 - Belt, Water Pump If the washer won't drain the pump belt might havebroken or might have worn ... It will fill with water but won't spin or drain on its own. ... Keep in mind that any water in the washer will pour out of the hoses when removed. ... I would have had to take apart entire washer to fix clogged pump.
My washing machine won't drain - LaundryDoc.com
www.laundrydoc.com/Washing-Machine.../My-washing-machine-wont-...
If your washing machine will spin but it won't pump water out, then the drain line is probably clogged up. In most washing machines, a small sock or small piece ..
Jan 05, 2016 | Washing Machines
Washer wont pump out the water and wont shut off if not unplugged
Heres a great website: Go there and investigate the videos
http://www.repairclinic.com/Shop-For-Parts?SearchText=Maytag%2520Neptune%2520FAV6800AW
Feb 18, 2015 | Maytag Neptune FAV6800AW Top Load Washer
Washer will not aggitate or empty
You have a bad lid switch. Here is that part to order.
There is also a video on that same page to show you how to make the repair.
Nov 15, 2013 | Amana NTW5400TQ Top Load Washer
My Amana Washer wont lock
Here's a video darrell r waggoner suggested as a solution to your problem from YouTube:
Drain Hose (Pump to Back Panel) Replacement (part #W10358149) - Whirlpool/Kenmore Washer Repair
Feb 24, 2013 | Amana 3.2 cu. ft. Top-Load Washer
The water wont empty out and thgere was a smell of burning..how can i empty the washer ???
If the drain outlet hose comes out at the bottom of the washer, then lay the hose down into a bucket or similar, and let the water run out until it is empty.
Possibly the pump is jammed or faulty.
Feb 08, 2010 | Hotpoint Washing Machines
The washer fills and empties but no spin or agitate
I assume by empties you mean it pumps the water out.
That being the case you will need a way to make sure the timer is sending power to the motor. If it is emptying by itself then you have a siphon problem and need to raise the drain hose exit above the top of the washer or install a siphon break.
Eric
Jun 08, 2009 | Kenmore 23012 Top Load Washer
Water wont spin out
open washer and check the DRAIN MOTOR PUMP , it could be clogged , inspect , remove any debris , replace and try again , AJ
May 20, 2009 | Candy AQ130 Front Load Washer
Whirlpool washer AWM 5145/5 water wont drain/stops on B
I had same problem twice, the first time there was a sock in the filter at the front adjoining the pump, the second time a sock had got in the pipe under the drum which is more awkward to get to but is possible if you have the tools to remove the back plate and are ok at diy, there is a spring tension clip on the pipe which comes off quite easily with a pair of pliers.
Jan 14, 2009 | Whirlpool AWM5145/2 Front Load Washer
Fills washes rinses but wont spin properly or empty out washer, ends cycle half done, wont pump water out or spin out. i can hear the machine hum while trying to do so. Please any ideas. THanks
its likely the pump is blocked (hence the humming) with a coin or some foreign object. To check, lower the outlet hose to ground level to allow the water to empty. Tip machine back & lean against a wall, remove the pump & remove object if there is one! Reassemble & try machine again
Oct 19, 2007 | Hotpoint Aquarius WF215 Front Load Washer
Dishwashers Logo
299 people viewed this question
Top Dishwashers Experts
