you need to turn off main power to frig...wait 5 mins..plug back in...if does it again replace sensor by condnser coil you cleaned..please ,on the side you cleaned flash a bright light thur it if you see no light, its plugged...then take compressed air an blow thur it...will be a little dust...vaccum up...hope it will help...michael,doctor airr appl.repair..843-384-8474...call if need more assistance..good luck...
The vacuum condenser indicator keeps flashing on and off. I did vacuum the unit, the the indicator lights keeps flashing on and off. How can I reset it and keep it off?
Thanks,
Rob
Subzero uses two compressors so the freezer is a separate system. The first thing to do is clean the condenser. You can find instructions on how in the owners manual or at subzero.com. They even have videos. If that doesn't take care of it you could have a bad condenser fan motor a sealed system issue or a temperature sensor issue. Also I have seen if you put something tall enough to push up on the light cover on the top shelf that can stop the evaporator fan at the top of the refrigerator section.
I have seen this many times and have fixed the problem many times. You may notice a ball of frost or ice build up in the fresh food compartment, This is because you have a leak in your evaporator coil and it needs to be replaced. It is a pretty costly repair but well worth it in consideration to what you paid for this unit or what the cost of a new one would be. Because it has less freon in it is why the compressor is running longer and causing message to pop up. Have the evaporator replaced in the section that is giving the issue and this will solve your problem with the unit.
Just posted this elsewhere and it sounds like the same problem:
As you probably know, the recommended temperature range is between 35-45 F so if your control will not allow you to set this, the sensor or associated regulator has failed. This seems to be an issue with Sub-Zero.
First check the condenser up top behind the grille and on the right side. If it is clogged with dirt, shut it down and use a vacuum to remove the dust. If tis clean then look at the display. Does it read "service" or "vacuum condenser" Also, whhat temp does the freezer read on the display? Lastly is it saying anything like "EC40"? These may be clues as to the problem. Let me know about this and I can give you more help if necessary. Good luck!
