Question about Krups Small Appliances Espresso Machine
How do you dismantle a Krups FNB2 espresso machine to replace the under steam outlet part? I cannot see how to remove the top even though I have removed the bottom and all screws.
    Brigadier General:
  • 3,614 Answers
May i know the exact model # of the coffe maker? and the part # of the steam outlet..
Posted on Sep 10, 2008
Krups Vivo 880. Steam wand is acting as a faucet
The steam valve is not closing. In such a case water finds an east exit from the machine where there is no back pressure.
Repair the steam valve.
Dec 25, 2016 | Krups Coffee Makers & Espresso Machines
Krups gusto 880 - My steam tap doen't pass the first sign to max.
Unless you are able to dismantle the unit and pull the tap to pieces to free it up you are going to be doomed. That part is part of the element assembly upper housing and it is obsolete according to Krups.
Apr 05, 2015 | Krups Coffee Makers & Espresso Machines
Steam nozzle attachment
stop looking, it works better without it!
Nov 14, 2011 | Krups Gusto 880-42 Espresso Machine
During a cleaning cycle my krupa ea8080 bean to cup machine started leaking water from underneath the machine. After trying to make a coffee once it had finished, some coffee is coming out correctly, but...
I have the same problem and have now just located where the water is coming from, it is seal within the boiler/plunger and I am now on a mission to find a service kit. It took many hours to get to this problem and unless you are feeling brave I would consider sending it off to krups!!
I will let you know my progression
Mar 26, 2011 | Krups Small Appliances Espresso Machine
I have a Krups coffee/espresso maker, with a milk steamer. It makes great coffee and espresso; however, the steamer is not working. It is not clogged; I cleaned the handle with a fine needle, and water...
There must be a blockage in that steam pipe, I think you need to dismantle the machine and remove all of the steamer parts off the boiler and look for the cause of the problem. Oftentimes it will be old hard milk that has been drawn up the pipe and gone hard from the heat. Once cleaned out prevention by blowing a large amount of extra steam through it after each use is the solution.
Apr 22, 2017 | Krups Gusto 880-42 Espresso Machine
The hot water and steam commes inside the machine KRUPS FNF1
The mashine dont pull water from the water container and it ask us to press hot water , but nothing happend when we press , anyone knows how to sole this question ?
Dec 30, 2009 | Krups Orchestro Dialog FNF2 Espresso...
Replace switch krups dual coffee / espresso 171
well, i figured it out just by poking around. there are three screws on the underside of the top part of the machine - by the espresso outlet. remove those; pop off the entire top of the machine, and you gain access to the switches. remove the wires from the paddles, push the switches out the front, take them to a repair shop for replacement, reverse the process, and you're done.
Mar 23, 2009 | Krups Coffee Makers & Espresso Machines
My Krups iron only heats up slightly. HOw do I repair?
Your question is listed under espresso machines. Are you talking about a Krups Espresso Machine? Please clareify. Does it make Coffee and Steam?
Aug 02, 2008 | Krups Orchestro Dialog FNF2 Espresso...
Message on Display
take it to krups service center the celluloid needs to be changed
May 04, 2008 | Krups Orchestro Dialog FNF2 Espresso...
Froth control problems
Your vinegar did the job: it as removed the deposits, now these deposits are clogging the four holes porcelain valve.....if the froth lever is not broken.
Remove all the screw you can see on the top and under the top of it, remove the cover, unscrew the frothing device down to the porcelain valve consisting of two 4 holes discs, clean them, and voila!
Dec 22, 2007 | Krups XP 1500 Espresso Machine & Coffee...
Krups Small Appliances Espresso Machine Logo
244 people viewed this question
Top Krups Coffee Makers & Espresso Machines Experts
Billy Mac
Ross Keen
Are you a Krups Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
