Increasing BTU means that the size of some parts are goiing to change, the heat exchanger or the evaporator is going to be bigger. The issue is whether or not there is enough room. They dont post sizes and you will have to contact Coleman or a representative of them .
that is a 10000 btu unit and a good rule of thumb to go by when 'sizing' a unit is 12000 btu for every 600 sq ft of cooling space (if the place is well insulated) or 400 sq ft (if not well insulated).
So, you have a 10000 btu unit which is 5/6th of 12000 btu - so - can reasonably expect that unit to cool approximately 500 sq feet.
In other words the room it's in now could be only - say - 300 sq feet (and well insulated) - in which case the AC unit is cooling it - well.
However, if you try to cool a 800 sq ft room - it will not work as well.
Hope this has helped.
This is a 3 ton unit. I go tthat from the 36 in your serial number. 36 means 36,000 btu's which equals 3 tons which cools a home 1,500 square feet to 1,700. If this help please rate me and do a testimonial.
Where do you live. A zip code is best. As long as you know the parts you need and your not going to ask how to repair your unit, parts are easy to come by. Give me your zip and I'll give you a dealer.
It looks like you have a 60,000 BTU unit or a 5 ton unit...12,000 BTU/ton is how you figure that...
The 60 in the model number indicates the nominal btu's of the unit... the exact output could be a bit more or less depending on the air handler...
This sounds like the unit is low on freon. From the model plate you have a 24,000 btu unit. This is the minimum needed for 1100 sq ft not accounting for windows and doors. Other factors have to be looked at for a good cooling AC, where is the unit located? In the basement is good. in the attic is bad. look at all the duct work is it all metal and insulated (good) is it plastic tubing (bad). The more insulation on the duct and the better it is sealed the better. You could use more btu's but you would have to replaced the whole system inside and out. You might look for a good 12,000 btu window unit or 2 - 3 8000 btus in different rooms. Now back to the problem I think you unit is low on freon. Should be using R22, unless you have a brother-in-law in the HVAC business you will have to call a local AC company to check out and add freon. Repost if you find other problems.
COLEMAN R.V. AIR CONDITIONER SERVICE AND REPAIR QUESTIONS
COLEMAN R.V. PRODUCTS
GO TO rvcomfort.com
Click on RVP (RV PRODUCTS)
Click on type of AC, if you can’t find the information you want there,
then click on contact us on the Green Bar.
You can get Service Support or Email address and Phone numbers.
