Question about Sony KV-32S65 32" TV
TV screen comes in and out when first turned on.
The screen is coming on and off more during viewing. I does this for at least the first 10 to 15 minutes when you first turn the set on. Thanks, Todd Morgan
  • Todd Morgan Apr 03, 2006
    Hi, the video is going in and out sound is there. Is this something I may be able to fix? Is there some diagram I can get to show where the problem is? If so will it be fairly evident on how to make the fix? I really appreciate your time and input on this issue.
    Todd
    President:
  • 3,130 Answers
Is the video going in and out or is the whole set with the sound going off as well. If the sound stays its a cold solder connection on the vert output device or the B+ line feeding the ic or if the whole set is going on or off its a cold solder connection on the Horizontal driver transformer. Without more info its hard to tell.
Posted on Apr 02, 2006
  • Larry  Dillon
    Larry Dillon Apr 09, 2006
    I wish there was a book or manual that would point ya to a fix!! That would be great. Even with 1000s of dollars in fancy test equipment your still gonna need to know how to read a schematic diagram and that my friend is a cuirut blueprint and where it all conncts. Even with a diagram its not going to point you in the right direction as you the tech have to do certain diagnostic steps to localize a fault and then finally to the defective part or parts.. Sorry i couldnt help ya more.
SOURCE:
My vizio 60' flat screen tv audio captioning for the blind will not turn off? A voice comes on during all prime time shows describing visual actions for the blind...help?
Go to your Menu options, and look around for a RESET option. You want to basically do a factory reset on your TV. (I'm assuming you turned off the setting, the system confirmed it, but it never turned off?)
Jan 31, 2013 | Televison & Video
No Video Signal - Black screen with Blue Bar that reads "No Video Signal". Eversince we got a new HD reciver to view our new Toshiba 40" tv in HD, we have been having this issue! Lately it...
One of the things an HDMI connection does is allow the TV and equipment to talk back and forth to each other. When you turn the TV off it ends this connection but when you turn it back on, it doesn't communicate correctly. The analog inputs don't do this that's why when you change inputs and go back to HDMI it works, because the TV reestablishes that connection. You didn't list the model of the TV but go to "http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/home.jsp" and click download. Enter the TV you have and click "GO". A list of downloads comes up and your TV may have a firmware update for it. There is instructions on how to do it. Even if this doesn't fix this problem, it is still good to do to avoid other problems. Another solution is to use component (Red/Blue/Green) cables. The highest resolution they support is 1080i, HDMI is 1080p. Depending on the model of your TV and what your watching though, you might not see a difference. TV2 will never have this problem because it is not connected through HDMI.
Apr 19, 2011 | Televison & Video
I just bought the HD50LPW42 from someone he said it needs a color wheel. When I turn the TV on the green light comes on but I don't get any picture. What is a color wheel and is it needed to just watch the...
Most DLP TVs have a color wheel. This allows the TV to be manufactured with a single chip to control the color for each spot on the screen and a white light source. As the wheel rotates, the desired color light gets transmitted to the screen. This happens so fast that most people do not see the screen refreshing each color.
Here is one source for a color wheel for your TV: http://chaparral.shopjimmy.com/catalog/product/view/id/200632/s/rca-color-wheel-212184/ . This is a part reclaimed from a TV that was damaged in shipping so it was only used during factory testing. The part number is RCA 212184.
Usually the symptom of a failing color wheel is the TV being very noisy on startup (a whining sound) followed by it shutting down. Although other problems can be involved - for example a power problem going into the assembly with the wheel (there is a motor that turns the wheel).
I hope this helps.
Sep 29, 2010 | RCA HD50LPW42 50" Rear Projection HDTV
Sony kf 50e200a screen goes black and sound turns off for min...
TV has gone into "protect mode" to do just that to protect against the damaging failure that has been detected, you will need a servicer to diagnose the failure. Good luck and Merry Christmas!
Dec 25, 2009 | Televison & Video
Pioneer Elite Pro 620 HD TV on several occasions the screen has gone black but sound continues and the power green libht remains on. After shutting down for 10-15 minutes picture comes back.
Pioneer Elite Pro rear projection 620HD - Picture is still there but brightness and "white" have faded over years allowing for mediocre viewing when room is dark only. During the daylight picture is visible if viewed straight on and within 15 feet from set. Any suggestions?
Oct 16, 2009 | Televison & Video
Phillps tv problem
42" Plasma Flat screen TV - recently problem started with a solid black background over top half of screen during viewing (comes & goes). A few days ago, when TV was turned on, green light came on then changed to flashing red light in 4 signal flashing pattern, but no audio or video. Phoned Philps Cust Serv and was told to download system upgrade on USB but it did not work. Philips referred us to Service Repairs who charged $85 for coming to home and without even opening the TV, said it will cost approx $1000 for "boards" plus his service, and he could not guarantee the TV would work.
Aug 07, 2008 | Philips Televison & Video
Panasonic plasma
go in to your tv's menu and go in to picture settings , you either have the zoom function on or its been set on 4:3. check these and if zooms on turn it off or if 4:3 is on switch to 16:9
Nov 28, 2007 | Panasonic TH-42PWD7UY 42 in. EDTV-Ready...
Picture failure
Do not have a clue without a model number and make. Are we to be fortune tellers here too?
Oct 04, 2007 | Televison & Video
Screen tuns black after 15 seconds and comes back after about 15 minuts
The solder joints on the vertical output IC have cracked. This is a very common problem on those sets.
Nov 14, 2006 | Panasonic CT-27G34 27" TV
Sony KV-32S65 32" TV Logo
175 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
