Question about Sony RM-V310 Remote Control
Sharp LC32AV22u does not turn on
My Tv will not turn on it is a 1 year old set when i press power it does nothing the led light does not turn on or anything please help!!!
  • potebarski Sep 10, 2008
    Still need a solution for this problem?
    Try our Premium Assistance plan
  • 147 Answers
Press the on button on the remote and see it with the help of mobile phone's camera. If u did'nt see a light coming out of the remote, then your remote is faulty.And if u see light then your tv sensor is faulty.
cheers
Posted on Jun 26, 2009
No image. seems to be a led problem
POWER LIGHT FLASHES ONE SHORT AND ONE LONG FLASH.
What is the problem? THE PROBLEM IS THAT ONE OF THE LED's STRIPS IS BAD!
SHARP AQUOS LC60LE810UN RESET INSTRUCTIONS
1)Plug in TV to electric current First then wait until LED start flashing.
2)Press Volume DOWN [ - ] HOLD BUTTON.
3)Press Channel UP [ ^ ] HOLD BUTTON.
4)Press Power [ (') ] HOLD ALL three buttons until LED stops flashing and then release.
    ·This will reset the TV in order to fix the problem.
    ·THE FIX IS TO REPLACE ONE OF THE LED's. You need to open the back of the TV and you will also need to remove the front cover and panel to get to the LEDs. The TV will need to be placed facedown and on the backside. This is a 2 person job to turn the TV on its sides. Be careful with the white computer connectors (wide white strip) at the base of the TV where the TV stand sits. You will need to disconnect this in order to get to the LED's.
    Once you have the LED's exposed, you will need to unplug one by one by placing the new strip next to it until the unit turns on. You will have to use the RESET procedure above if the Power lite flashes. The Power lite MUST BE ON SOLID - no blinking in order to test the strips. The LED's will flash, but still one of them will be burned. Even if you stare and all the strip light-up, you will still need to check one-by-one!
    Once the TV lights up, your face will also light up with joy! Put everything back together and you are set. If you need the complete instructions which come from Sharp as to how to disassemble the unit, please send me an e-mail to LGTR61@YAHOO.ES. Please note I don't check this address daily, so a few days wait may take for you to receive the instructions.
    Where can you buy the LED's - try searching Yahoo.com or Google.com for resellers.
    SHARP AQUOS LC60LE810UN LCD STRIP INFORMATION
    LONG STRIP (49 LED's)
    FRONT SIDE BACK SIDE RL 94v-0
    E329419
    1029
    LFa
    Sn-Ag-Cu
    Ps-1
    K4458TP
    4458ZZ
    0921FM
    104863
    ee03A
    SHORT STRIP (30 LED's)
    RL 94v-0
    E329419
    1025 LFa
    Sn-Ag-Cu
    Ps-1
    K4459TP
    4459ZZ
    0714FM
    302213
    Mm05A
Dec 06, 2013 | Sharp LC60LE810UN 60 in. LCD TV
60" sharp aquos power indicator is flashing one short flash and one long flash and keeps repeating the sequence
    E329419
    1029
    LFa
    Sn-Ag-Cu
    Ps-1
    K4458TP
    4458ZZ
    0921FM
    104863
    ee03A
    RL 94v-0
    E329419
    1025 LFa
    Sn-Ag-Cu
    Ps-1
    K4459TP
    4459ZZ
    0714FM
    302213
    Mm05A
Apr 10, 2013 | Sharp LC60LE810UN 60 in. LCD TV
The on/off light on the bottom middle screen is blinking one solid time and then one fast time. The tv wont come on with the panel or remote.
2)Press Volume DOWN HOLD ALL three buttons until LED stops flashing and then release.
Sharp LCD/LED parts web site -
Copy this link:
http://www.encompassparts.com/item/8459814/SHARP/RUNTK4459TPZZ/LEDPWBUNIT(LC-60LE810UN),_X4
E329419
1029
LFa
Sn-Ag-Cu
Ps-1
K4458TP
4458ZZ
0921FM
104863
ee03A
RL 94v-0
E329419
1025 LFa
Sn-Ag-Cu
Ps-1
K4459TP
4459ZZ
0714FM
302213
Mm05A
Dec 27, 2012 | Sharp LC60LE810UN 60 in. LCD TV
How to reset LC60LE810UN
How to perform a cold hard rest on the Sharp LC-60LE810UN TV? It won't power on and just blinks.
Apr 14, 2012 | Sharp LC60LE810UN 60 in. LCD TV
60' Sharp Aquos tv power bar flashing but TV wont turn on. Any help??
Good day!!!
please try to count the exact number of blinking lights to diagnose where the fault came from..
Also try to open the cover and look for any bulged capacitors on power supply board..
Dec 04, 2011 | Sharp LC60LE810UN 60 in. LCD TV
I have a sharp aquos lc-c4677un its not turning on at all now. When I push the power botton on the tv, the power light turns on and about 2-3sec the power and opc light start to blink and thats about it.
How are the power and opc lights blinking? Do they blink simultaneously or does one blink then the other? How many time do they blink per second? Also have you had it fixed yet? and if so what was done? I had a similar problem with my set.
Aug 06, 2011 | Sharp AQUOS LC-C4654U 46" LCD TV
I have a urc3021 and a sharp linytron television and there is only one sharp code that in the manual.what am i to do?
Last Option is to do a code search.
If your device does not respond to the remote control after trying all codes
listed for your brand, or if your brand is not listed at all, try searching for
your code.
For example, to search for a code for your TV:
1. On the remote control, press TV once.
2. Press and hold SET until the LED (red light) blinks twice,
then release SET.
3. Enter 9 - 9 - 1.The LED will blink twice.
4. Aim the remote control at the TV and slowly alternate
between pressing POWER and TV. Stop when the TV turns off
(after pressing POWER). If the device does not have a Power
key, you can substitute another function, such as digits 0 ~ 9 ,
CH-up, or PLAY).
NOTE: In the search mode, the remote control will send IR codes from
its library to the selected device, starting with the most popular code
first.
5. To lock in the code, press and release SET.The LED will
blink twice.
6. To search for the codes of your other devices, repeat steps
1 through 5, but substitute the appropriate device key for
the device you are searching for.
Feb 11, 2011 | One For All URC-3021 Remote Control
I have an aquios LC-42D64U which suddenly has the following two lights blinking power & OPC. They both blink, once together, the second blink is only the power, and repeating the sequence. I've...
Sharp LED/LCD EEP cleared Step 1 Remove Mains Plug 2 Press On/Off Switch from LED/LCD Panel 3 Press Ch Down & Input Switch together and plug in mains cord 4 LED/LCD will start 5 "K" will appier on Screen 6 Press Ch Down & Vol Down from LED/LED Panel 7 1/9 Page will appier on Screen 8 Go to 9/10 page by pressing Up & Down arrow of remote 9 Select EEP Cleared 10 Press ok button from remote 11 On Screen dispay EEP running 12 Remove Mains Plug after complete EEP Run 13 Restart LED/LCD
Feb 05, 2011 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
My Sharp LC-42-D62U won't power up. The power light blinks twice, then the power light and the OPC light blink together once. any fix to this problem?
Ur Tuner signal board have problems or dead.Ur power LED light indicator stable for a few mins before the power LED light,and the OPC LED light indicators flashes?After the POWER light and OPC light indicators flashes,just push the power button again for the power recycles again.Probally have to pushes the power button 3 or 4 for power light and opc light indicators flashes,the LCD backlght will lght up and work.Sharp tv have this problems alot,very common in Sharp LCD tvs.
Apr 17, 2010 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Sharp 46" LCD TV wont turn on (Screen)
you need your power supply repaired.
Jan 01, 2010 | Televison & Video
Sony RM-V310 Remote Control Logo
73 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
