Question about Toshiba SD-3960 DVD Player
My Toshiba SD-3960 sound does not work.
My Toshiba SD-3960 DVD Player sound will not work everytime I plug it in to my TV it will play the DVD and video but the audio or sound will not work does anyone know how to fix this or do you think I should just buy a new DVD Player???
  • Anonymous Mar 23, 2014
    Toshiba SD-5000 digital Cinema progressive HDMI audio cuts in and out
My Toshiba DVD Player does not work. I can not watch online movies. What I ca do? Please send me if you have any suggestion.
Thank you.
Posted on Aug 30, 2008
    President:
  • 3,130 Answers
First thing before a landfill is to go into the units menu and see if something in the audio got turned off if not then inspect the connectors on the back for breakage. Good Luck
Posted on Apr 02, 2006
4 Suggested Answers
SOURCE: Toshiba SD 3960 DVD player
Sounds like an inverter problem. If the power supply is internal replace the capacitors coming out of the voltage regulators. These are usually 1000mf and/or 470mf. If that doesn't do the trick look up the numbers on the 8-pin chips that drive the secondary transformers on the inverter to see if they are getting the right voltages.
Good Luck!
Posted on Feb 20, 2008
  • 630 Answers
SOURCE: toshiba sd-k970 dvd player sound but no video.
I presume that you've selected the correct inputs on the TV? Go for HDMI if you have it on your TV. If not use the yellow (composite) and ensure you have nothing in the S-Video (Toshs don't like using composite and S-video at the same time).
Posted on Aug 30, 2009
  • 324 Answers
SOURCE: my Toshiba SD-P91S DVD player is not working
thats odd... maybe your drivers got changed, see if you can updtae or roll back the driver on it
Posted on Sep 18, 2010
Dvd will not read disc
cleaning the DVD player will help it read the disc, because a DVD player does get dusty. also it might be the disc, some DVD players will not accept some disc.
Aug 14, 2012 | Toshiba SD-3960 DVD Player
I'm tryna program my toshiba sd 3960 but I can't find the manufactures code... can any one help I would extremely appreciate it thank you...
Here is a possible hack for TOSHIBA SD 3960.
Press 'hold' for a few seconds.
Release.
Pres 7,8,9,OK,0. (or possible ENTER button)
In the left corner you should see a 0.
That is it
OR the following steps
1. Press the Open button on your remote control to open the drive tray
2. Press the 2 button on your remote control
3. Press the 4 button on your remote control
4. Press the 0 button on your remote control
5. Press the 3 button on your remote control
6. Press the 9 button on your remote control
7. Press the 6 button on your remote control
8. Press the 0 button on your remote control
9. Press the Enter button on your remote control to change the region to 1 for region 1, 2 for region 2, and so on, or 9 for multi-region playback
10. Press the Open button on your remote control to close the drive tray
11. Power off the DVD player
12. Power on the DVD player
Nov 13, 2010 | Toshiba SD-3960 DVD Player
I have a Toshiba DVD Video Player Model SD 260. I
Hello, The problem could be dirt on the surface of the lens, you can clean this by removing the cover of the dvd player . Gently use a dry cotton bud to clean the lens because the lens is fragile. Insert the disc plate into the dvd player and press play, if it does not play try the second method. Ensure the cover of the player is open, connect the power plug to the mains socket and observe the lens if it beam a red light, Also check the ribbon cable use to connect the lens to the printed circuit board, then gently clean the lens with a dry cotton bud , insert the disc plate and press play to see if it play. If it does not play the disc, then this require a change of the lens
May 20, 2010 | Televison & Video
Toshiba 3960 dvd player no sound
The most common causes,
1, bent or broken pins in scart lead.
2, faulty scart lead(internal wires broke)
3, mis-connected( audio out from dvd to audio out on tv.)
Just go through the list and if you have a known good scart lead, swap over to test.
Sep 04, 2009 | Toshiba HD-A20
We hooked out Toshiba SD-V291 up to our Sony TV through a Direct TV Cable box. We get the sound when we play a DVD but no Video. We hooked it up with an SVideo cable and input/output cables. What are we...
I just had the same problem, and I am using rca blue, red and green cables for video. I unplugged them and plugged them back in again a couple times and it finally worked. I have had this problem before with another dvd player, don't know why. Hope this helps.
Chris
Dec 27, 2008 | Toshiba SD-V291 DVD Player/VCR
Toshiba TV/VCR/DVD combo MW24F12
You did not say if you have connected the video out on the surround system to the video in on the tv. If not connect it and select that input on the tv.
Aug 27, 2008 | Toshiba SD-V392 DVD Player/VCR
Good Luck!
Feb 20, 2008 | Toshiba SD-3960 DVD Player
Toshiba SD-3960 DVD Player Logo
613 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
