TV colors distorted
I recently bought this 25inch TV with a DVD/VCR combo (side by side, not stacked) and recently had to fish out a tape, well, after fishing it out, non-violently, the colors became horribly distorted... like when I used to hold a powerful magnet to the screen and warp the colors for a few hours, this however has gone on for days. I can't think of how this could have happened, because there aren't any magnets in this house powerful enough to do that, and the speaker magnets in the tv just don't seem to have the strength to do this. The view is like looking at the tv with bad colors in the center (sorta circular in shape), and the corners are darkened in, you can still see detail, but it's not great. I've tried fixing the colors with very weak refrigerator magnets, and at about an inch, they do fix the local colors, but the fix doesn't stay. Do I need a more powerful magnet or should I try and return it? Thanks in advance. I have an Akai 21" CRT TV six years old, Suddenly last week its colors got distorted from corners like a magnet does. I changed the position but no help earlier the blue back screen appeared green and now it has turned red ie blue color is appearing red. Any Help how to fix it
Make a degosing coil or try to look for a website how to make it in the phillipine we only make it coz we can't buy or its not available in the marker ok thanks that is the only solution you can do k
about akai tv may be it just coldsolder in crt socket try to solder it thanks inform me
Posted on Sep 10, 2008
Can a Go Video 3140 make a dvd disk copy from vcr tapes
Yes,read ur manual intructional book how to hook up the tv, VCR/DVD sides togother so it all link up.Play a VCR tape one side and record a DVD disc another side.
Nov 08, 2010 | GoVideo Go Video DVD/VCR Combo
VHS to DVD recording
Yes, just turn off the tv.
Walt
Apr 08, 2008 | GoVideo VR3845 DVD Recorder/VCR
I recently bought a new DVD/VCR machine. The VCR is the problem, tapes are jumpy, many lines across the screen and close captions are distorted. EVen just watching TV without tape or DVD, close captions...
Hi Carrie
Not to worry, son-in-laws are good!
Assuming the machine is working correctly, there is only one reason why the picture will be distorted and that is interference.
Here are a couple of things your son-in-law may be able to check for you.
Firstly, make sure that the DVD/VCR is connected to the television using a scart lead. The DVD/VCR was probably supplied with one. It is a short cable with a large rectangular connector at each end.
If a scart lead is already being used, there may be other units connected to the tv that are causing interference. Try removing all the other units like cable tv, satellite receivers etc and see if the DVD/VCR is any better when it is the only unit connected to the tv. If it is, you will need to use a scart selector box so you can switch each unit connected to the tv separately. (Sorry I know it's getting confusing now!)
If it still isn't any better, ask you son-in-law to check through the menu on the DVD/VCR and look for a setting for Video Format. This should be set to PAL Format unless you are in North America in which case it should be set to NTSC Format.
Hope this helps, please feel free to ask me for more info if you still have problems.
Regards
Helen
Mar 13, 2008 | Televison & Video
Dvd/vcr sylvania combo
did a few google searches and suggestions were made to buy a**ther vcr...** way to fix the vcr heads. thanks anyways!
Mar 08, 2008 | Sylvania (SRDD495) DVD Player/VCR
Recording VHS from TV/VCR combo onto DVD
This machine does not support DVD recording. Are you trying to make a tape from a DVD, by some chance?...accordianman
Jan 21, 2008 | Panasonic DMRES15 DVD Recorder
VCR kicks out cassettes
Sounds as if something got bent in the loading mechanism when you freed the stuck tape. Careful examination of the loading operation with the cover off may reveal the problem, but you may require a service shop, as there are hazardous voltages present inside, even when switched off.
Jul 13, 2007 | Toshiba MW24F52 24" TV/VCR/DVD Combo
HELP! I can't figure out how to Connect my Sylvania DVD/VCR Combo to my older TV
Even if you do get it connected you cannot copy from vhs to dvd as you have bought a vcr recorder with dvd player, not a dvd recorder. You can only record to the vcr tape from a dvd, in the players controls.
Feb 08, 2007 | Sylvania (SRDD495) DVD Player/VCR
Vcr trouble
this combo unit as far as i know has only one power source which is in the vcr unit. if the vcr has a problem it affects the tv likewise. i beleive u did removed the tape, but unfortunately you misaligned the mechanism of the vcr which will in turn sense an error causing the automatic shuts off of the vcr and likewise the tv. u need to bring it to a qualified service technician if u dont know anything about this.
Jan 05, 2007 | Emerson EWC27T3 27 in. TV/VCR/DVD Combo
TV colors distorted
maybe UFO around.. just kidding the mask in your picture tube may be damaged if that set is drop by any chance if not deagausing coil circuit ..
Dec 03, 2006 | Philips Magnavox MS2530C 25" TV
Televison & Video Logo
188 people viewed this question
Top Televison & Video Experts
Electro Med Services...
