My microwave burns fuse every second when turned on
Where is the fuse on a Jen Aire jmc7000
thanks
There is no power coming in to the microwave (yes, it is plugged in)
Replace the fuse, when I find out where the fuse is.
If it blows the fuse as soon as you hit the START button, it's almost certainly a shorted high-voltage capacitor. If it blows a few seconds after you hit the START button, it's probably the high-voltage transformer. You'll possibly also smell a faint electrical burning smell from the rear vent after you shut if off. If it blows the fuse as soon as it's plugged in, you probably have a shorted door switch, a shorted varistor, or an internally exposed wire shorting to the chassis, etc.
WARNING: Microwave ovens are the most dangerous consumer appliance to service due to up to 5,000 V at high current inside. Even with the power off, there is a HV capacitor that can produce a lethal kick. This capacitor must be discharged before touching anything in the microwave generator circuitry. DON'T remove the cover yourself unless you fully undertand the SAFETY issues involved in working inside a microwave oven. A microwave oven is possibly THE MOST DANGEROUS common consumer product to service. About the only "easy" fix would be a blown fuse, if it keeps blowing, don't go any further unless you know what you are doing. Your likely options are a blown high voltage cap, diode, or the magnetron. Good luck(but luck has nothing to do with it ;] )
my microven stops working
microwave blew a fuse after 4 years once i replaced the fuse it keeps blowing
NEED TO FIND FUSE
Hi, I have a national ne 6980 model quite a few years old but a great machine, Now it has started blowing its fuse. when you replace it and plug it in, the clock works ok, as soon as you put it on any power setting and hit start everything starts working for half a second and then it blows the fuse with a bright blue spark ( looks like heavy load ) I am thinking it could be the same sort of problem. nay ideas ?
