Question about Intel Motherboard
Mainboard shutdown i pluged my laptop over the night, only to turn it on the next day but it will not come on. it only indicated that the battery was charging with the batt charging indicator led on when it was pluged. i checked the adapter and the wall socket every thing seemed ok. i opened the my laptop and after a series of random testings using a small digital meter on the components i found one small smd(surface mounting device)fuse on the board dead. i bridged it with a tiny wire and pluged it again hoping that was the only thing wrong and pluged it again. but this time the batt charging led did'nt lit on and the led on the adapter blinked. i felt it was a back voltage something definately was stoping the current from flowing therby returning voltage to the supply adapter.i removed the wire and replaced the dead fuse things went back to how they were before i had my hands on it. then i thought that fuse was not only component dead onthat board. before now i had done little troubleshootings like removing the cpu, changing the RAM making sure it was'nt a hardware thingy. finally i resorted to change the mainboard. but i thought it a nice idea if i could fix it ratherthan buying another of those expensive mainboards. this morning i browsing and found you guys could be of great help. what do i do next?
    HARMONY NWABUISI Sep 10, 2008
    hi saigua,
    thanks for ur fast responce.
    it won't come on even with the power connected. rather it only indicated battery charging.
    thank i get ur advise never trying things at ramdom again. i meant i was checking for only fuses on the mainboard as they were likely to be the most venulrable to current.
  • 981 Answers
Never do that to fuses, search the web (especially the site of your laptop's maker) for common cures to your situation, and failing diagnosis recommending a particular cure, don't do stuff at random.  That sort of thing sort of sounds like a battery issue; won't the thing come on with no battery, but the power power connected?
Posted on Sep 10, 2008
Put acer aspire 5734z to sleep mode and wont turn on next day
First thing to try:
Remove your battery and charger, hold the power button for 10-15 seconds. Plug the laptop into mains ONLY leaving the battery out. Try powering it up.
If the laptop powers up ok, shut-down and re-insert your battery. You should find your laptop will continue to work fine for the foreseeable future, this kind of issue is a common occurrence on laptops.
If not I would then try re-seating your RAM/Memory, if that doesn't work and you have more than one stick remove one at a time to see if either one is causing the problem. If you have only one stick find a replacement to test your laptop with.
If you are still finding the same issues with the laptop I would then proceed to reseat all components of laptop, including the CPU.
If the issues continue I would then remove all non-essential components one by one, each time attempting to power the laptop. At worst you will eventually end up with just the mainboard, CPU, RAM and an external monitor plugged into the mainboard, that still doesn't function correctly. I would then conclude your mainboard needs replacing.
Mar 19, 2014 | Acer Aspire 5734Z4386 Notebook
Htc evo makes crackling noises and vibrates lights up but wont turn on all the way
you either have a defective battery or a mainboard fault inside the phone.
Mar 08, 2012 | HTC EVO 4G Smartphone
My laptop turns on, but shuts off immideately. I don't hear the fan running. A couple days ago I used compressed air to clean the fan area (not opening up, but throught the vents) what is the problem?
There's a good chance that your fan is toast, and you may need to replace it.
If the computer turns on and quickly shuts off, with the fan not running, leads me to believe that the shutdowns are caused by the system overheating.
Hope this helps.
Oct 20, 2010 | Computers & Internet
My Dell precision M90 will not turn on all the way it acts like its going to boot up and then comes to a screen that either says the battery can not support the system press F1 to shutdown (when it is not...
Seems that either the battery or the power adapter is defective. A fast check to determine whether you have a problem with the power adapter, power cord or the laptop's battery is to turn off the laptop, remove the battery, connect the power adapter, turn on the laptop & see if it works.
If the laptop works directly from the power adapter with the battery removed, then the power adapter is good. In this case we can suspect that the battery is defective.
Oct 27, 2009 | Dell Precision M90 Notebook
Laptop will not turn on, either on battery or using AC adapter. Any help would be appreciated. Dobby
A little more info may be needed to narrow the reason down. What was it doing before this occured...was it witnessed, was it upgrading, was it turned off for the night and then the next day...this, was it running all night in hibernation...etc. Have you tried getting a universal charger and trying that. Do you get power indicator lights when it is plugged in?
Aug 27, 2009 | Gateway MX7118 Notebook
Toshiba Satellite A205-S5814 laptop will not power on
clear the bios by removing the small battery on the mainboard for 10 hours.the power on
Jul 30, 2009 | Toshiba Satellite A205-S4617 Notebook
Gateway turns off
Good Day sir/maam, i had the same problem with my laptop, my compaq armada. old one, the thing sometimes turns on, then off, then sometimes not at all. im searching for a mainboard replacement. fortunately cant find one. the problem is caused by a faulty mainboard. sad to say this but you have to visit a local service center. hope this may help./ thanks
Jul 16, 2009 | Gateway 7510GX Notebook
This started last night, my battery indicator
The red or amber flashing lights indicate a bad battery. The Dell battery warranty is only for one year and the D600 has been out for a number of years. You should replace the battery. You can use the laptop as it is as long as it is connected to AC power.
There are several places to buy replacement batteries. One is If you do a search on the web you should be able to find other sources.
Good luck and I hope this helps, even if it isn't good news.
Feb 28, 2009 | Dell Latitude D600 Notebook
Problem with black screen
have you try to check your battery? try to put some colling fan to your laptop to avoid hybernation of your notebook..
Mar 26, 2008 | Computers & Internet
Intel Motherboard Logo
67 people viewed this question
Top Intel Computers & Internet Experts
Alun Cox
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
