Panasonic rear projection tv. loud pop, power off to tv
  • Joseph Klar Sep 11, 2008
    Model is Panasonic TX51GF85H
    Can't be the lamp because there is no sound or any power to the unit. Has to be either the power board or a fuse.
    Novelist:
    Champion:
  • 203 Answers
What is the model number? If it is a lcd rear projection then you may have a bad lamp. But im just guessing without a model #.
Tim
Posted on Sep 11, 2008
  • experttv
    experttv Sep 11, 2008
    Sorry my friend, thats a CRT based TV no lamp in there, like I said just guessing....Do you know how to use a meter to check some things? You say theres no power light on the front at all when you try and turn it on?
I hear a noise in the back of my Panasonic PT-43LC14
COUNT THE NUMBER OF FLASHES AND CONTACT PANASONIC TECH SUPPORT
Feb 03, 2014 | Panasonic PT-43LC14 43" Rear Projection...
Loud pop
Check the lamp.
Pull it out and look at it.
More than likely the lamp has shattered inside the set and needs replaced.
Bulb replacement is made for consumers and can easily be replaced.
Need any more information, respond to this post and I will reply.
Dec 30, 2007 | Panasonic PT-45LC12 45" Rear Projection...
Own a 52" panasonic rear projection tv. Heard a loud pop, and tv went out. Will not turn back on.
Power supply board is dead.Replaced power supply will solved this problem.Tries websites Shopjimmy.com,Ebay.com to buy a refurbish power supply board to replaced.
Feb 25, 2010 | Panasonic PT-53TW53 53" Rear Projection...
The tv will not stay on after u press the power button
Does this go off straight away? Any loud pops with this, or anything on the screen? How old is this set?
Sep 12, 2009 | Panasonic PT-50LC13 50" Rear Projection...
No Picture, Power light Blinking 3 times then repeats
3 times blink shows lamp cover is removed or not installed properly on TV.
Please take out lamp inside TV and check, seems its broken as you heard loud pop.
Thanks.
Aug 28, 2009 | Sony Grand WEGA KDF-55WF655 36" Rear...
TV popped when turned on
My sons tv did the same thing, 3 trips by the repairman before they finally replaced the "brain" Works fine now
Dec 25, 2007 | Hitachi 50UX26B/27K 50" Rear Projection...
Panasonic PT-53WX54 What is that popping noise?
A loud popping noise, like a sharp "snap!", is usually caused by high voltage arcing. Somewhere in the high voltage system an insulator may be cracked or loose, such as the plastic around the flyback transformer or one of the rubber cups on a picture tube. When the high voltage arcs, it momentarily drops and the picture could go out for a split second. High voltage is dangerous in projection sets so allow a qualified tech to service it for you.
Sep 07, 2007 | Panasonic PT-53WX54 53" Rear Projection...
Dead tv
Sounds like a power supply problem. I am sure that the pop is the fuse blown. If the fuse is blown, this means that there is a short somewhere. Rear projection TV are like LCD projectors. And all of them use Switch mode power supply. If you are lucky, there is a chance that a protection device (like a varistor) is sorted. This means that removing this, even without replacing will bring your TV to life, however... Most probably the power supply is defective.
May 22, 2007 | Panasonic PT-50LC14 50" Rear Projection...
Sony KP-53N74 Rear Projection TV won't power up
how was the picture before ? nice and bright if was ok it may worth fixing probable just power board get the hit ..
May 16, 2007 | Sony KP-53S35 53" Rear Projection...
Televison & Video Logo
107 people viewed this question
Top Televison & Video Experts
Electro Med Services...
