Question about Dishwashers
Whirlpool dishwasher my dishwasher turns on and i can hear the motor but there doesnt seem to be any water going in
    An expert whose answer gotĀ voted for 100 times.
    Novelist:
  • 171 Answers
Hi jamesward,
I'm Harvey the Master Plumber.
Your problem is: Your dishwasher turns on and you can hear the motor but there doesnt seem to be any water going in
This may sound stupid but first make sure no one turned the water off to the d/w. If OK then you likely have a clogged or failed solanoid valve. The d/w must be removed for replacement. I don't recomend this for the average homeowner. You might consider utilizing our Repair Directory to find a repairman.
Feel free contact me again!
Please give me a rating here at fixya.com before you sign off
Thank you,
Harvey your Master Plumber
Posted on Sep 13, 2008
I have a whirlpool Adp8540 that seems to go through the wash cycle completely but when we open it up the water has not gone through the spraying arms and the soap is a solid mass at the bottom of the...
It is likely the water circulation system is faulty. This dishwasher uses a single motor to run the water pump and the drain pump. If you hear the wash pump operate during wash cycle then it is likely there is a blockage in the water circulation manifold which distributes the water through the arms.
If you do not hear the pump operate during wash cycle then the sensor is faulty. The sensor tells dishwasher to switch to drain cycle from wash cycle.
Try following the diagrams at top of this website to get idea of parts.
Oct 13, 2011 | Dishwashers
Both spray arms of my DU943PWKQ0 do not turn or spray. The motor is moving and the it drains without problem. During the wash and rinse cycle I can hear the sound of water, however it doesn't clean at...
Try rotating the spray arms by hand. It should rotate freely. If possible clean the arm rotating place by removing them.
Arms rotate by by pump pressure only. finally check the water pump also.
May 18, 2010 | Whirlpool DU943PWK - Multiple Color...
Will not wash and water doesn't seem to be circulating freely.Tablet not dissolving
you could have a problem with the motor or capacitor do you hear a hum after the dishwasher has filled if you do its the motor
Apr 12, 2010 | Whirlpool 24 in. DU1100XTP Built-in...
GE Nautilus dishwasher. Doesnt seem like motor is working
Dishwasher (Nautilus) not draining into sink but leaks onto floor.
Nov 10, 2009 | GE Nautilus 24" Built-in Dishwasher
No water coming into dishwasher
Make sure you get water to the dishwasher. Check to see if the water shut-off valve (located under the sink) is open. If you get water to the dishwasher, but there is still no water inside during the fill cycle, the problem might be with a faulty water valve (located at the bottom of the dishwasher, behind the kick panel, on either side), in which case replace the water valve.
Jun 06, 2009 | Whirlpool Dishwashers
Smeg dishwasher sa 623 x-1wont work
The water supply may be turned off
Sep 25, 2017 | Dishwashers
Philips/whirlpool turbo silent 256 , no water through the cycle
Hi, if the motor is working then the spring arms are blocked. Pull them out and rinse them on the sink, then put them back on. Simple
Jan 17, 2009 | Whirlpool 24 in. ADP5962 Free-standing...
Whirlpool Gold model GU1200 will not start wash cycle
FYI, for anyone else with the same symptoms. I took mine apart and found that the seal on the motor shaft failed and over time corroded the motor shaft bearing causing it to failed. I ordered full motor assembly from the parts store.
Oct 09, 2008 | Whirlpool Gold 24 in. Built-In Dishwasher...
Whirlpool DU8900 XT-5 the water comes in at beginning of cycle and the heater heats the water, but the machine does not go any further. it kinda' hums but no water gets pumped and moving. at end of cycle...
if you can hear a low humming noise when it should be pumping water round, then suspect the circulating pump.
fault can be motor capacitor - low cost part
or
pump seized - see if you can turn it by hand
Sep 15, 2008 | Whirlpool Dishwashers
Dishwashers Logo
Top Dishwashers Experts
