Question about JVC AV-27432 27" TV
Re; Model # AV27765
IC 101 will not produce horizontal drive. Screen is rotating to right. Can you tell me which pin and waht voltage should be on the IC 101 circuit?
    President:
  • 3,130 Answers
Wait one second here if the ic wasent producing horiz drive you wouldny be getting any picture.. Your saying the set is floating the picture side ways?? your gonna need a scope to see where your losing the horizotal sync pulse from my friend.. No insult intended but if you have no horizontal drive there would be no High voltage therefore no picture.
Posted on Apr 02, 2006
Where is horizontal scan out put section?
Hi Majid
Just contact any service technician to repair your TV. It will be best for you.
Gopakumar Gopalan Google
Feb 01, 2015 | Televison & Video
Toshiba 24af45 horizontal
If rolling in a right to left and not up down it is a sync problem--horizontal sync comes from one of two places in general---a pulse off the high voltage transformer or directly off of what is called in the trade the Jungle IC.
That is not a joke--Most of these sets use a large IC (63 pins or more not unusual) that contains: color, video, vertical drive, ABL and much more---so much is crammed into that chip it decades ago was named the Jungle for clear reasons.
A schematic and or scope may be needed to trace and find what is bad.
if off the high voltage transformer (more common in old sets than new ones) it will be a open resistor.
If at the jungle you would have to go to the pin with the sync and follow it out to see if none at source or if lost somewhere down the stream.
May 29, 2012 | Toshiba 24AF45 24" TV
When we try to turn on the tv (toshiba model 32A43) it makes the sound of turning on then off and the screen stays black and a red light by the power button keeps binking
You're either losing high voltage or power supply is not producing the horizontal drive signal, Check for 130v on the collector of the horizontal output transistor, if you're missing your voltage, you have a power supply problem. If voltage is too high you have something open in the power supply such as a low value resistor. If its low, something is shorted in power supply, possibly voltage regulator ic.
Jul 31, 2011 | Toshiba 32A43 32" TV
Model LN32B360C5DX2A My screen seems to be shifted to the right. the left part of the picture is on the right side of the screen. Is this something that I can adjust or does it need to be sent out to be...
Your TV suffers from horizontal phase shift. It may be due to the Ic fault or horizontal output sync: signal from the LOT not reaches to the respective pin of that Ic. Check first whether the horizontal sync: signal from one pin of the LOT reaches to the sync: pin of the Ic. If you have a frequency meter the thing should be easy.
Most common is IC fault.
Oct 15, 2010 | Samsung Televison & Video
My Toshiba television Model 13A23 is not working. There is no horizontal signal from Video Chroma Ic but the B+ voltage is present. Can you tell what can be cause of this problem?
pls check the jungle IC it genarate the horizontal signal croma ic used that signal may be failure in horizontal oscllator section
Aug 24, 2010 | Toshiba 13A23 13" TV
TV has a line across middle from left to right
It depends what part was damaged in Horizontal section. Here in Philippines labor costs for this size of TV is ranging from $50 to $150.
Feb 27, 2010 | Televison & Video
Sony tv no picture only horizontal line
The probable defective part is the vertical IC. If changing that does not resolve the problem, check the capacitors in the same circuit. Also, check for the proper voltages at the vertical IC. If the IC is not being fed its power, it won't work either. I don't have a listing for your specific model. If you can post the vertical IC part number (LA7837 for example), I can list the voltages per pin.
Dan
Apr 09, 2008 | Televison & Video
Sony tv there is sound but no picture only horizontal line
hi there, one horizontal line means a vertical section prob., check some resistor with low value and a defective diode, possible ic part is defective. do some test and check up. ty
Feb 25, 2008 | Sharp 27C-240 27" TV
Please help me.
checked the horizontal output,a big transistor near the flyback trnsformer, if it is shorted replace it,,,,
Feb 13, 2008 | Sampo AlphaScan 411 Monitor
ABOUT PHILIPS TELEVISION
The 8V at pin 36 won't show unless there is oscillation, the primary voltage pin is pin 10, 8v. Don't mind me asking, you have checked the B+, right? Because the blinking LED is often because of power supply problems. And if that's okay, desolder the horizontal driver output legs and connect an LED to find if it is oscillating, if it does, forget the ic part and move on with the FBT and things. Good luck.
Jan 31, 2008 | Televison & Video
JVC AV-27432 27" TV Logo
87 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
