Question about NEC ND-3540A DVD RW Dual Layer Burner
The nd - 3540a has stopped recognising blank cds in drive.
I had been getting through a heap of LPs, using Roxio EMC 10, then, towards the end of prject, the drive stopped recognising blank cds, I tried brands of cd, but with no success. Firmware ver. 1- 01 is installed.
gerryx1
  • NEC Master
  • 19,396 Answers
Even if a recorder is supposed to work fine on both +R, -R etc. , often you find out, that due to error correction methor, a device worksd well on one or the other type.
I often get troubles with many DVD low price brands, try testing some good ones like Verbatim, TDK, Sony , Philips etc.
Hope this had been helpful, test both a good brand DVD-R and a Good brand DVD+R.
If it still has problems when finalizing the CD, then it can be the usual lens problem, Or the DVD you are writing is too big in size and your player has problem on the final phase of DVD writing. If Data nearly takes all the 4.7 Gb allowed, there won't be enough space to finalize the DVD.
Posted on Sep 10, 2008
    Master:
  • 505 Answers
Uninstall and reinstall the program try that
  • NEC Master
  • 13,433 Answers
Try a lens cleaner, also theres a newer firmware out
http://club.cdfreaks.com/f86/new-nec-nd-3540a-firmware-release-version-1-03-a-149886/
Your drive may have failed, do dvds still work?
NEC DVD_RW ND-3540A
You need to replace your DVD RW drive.
Sep 02, 2012 | Acer Computers & Internet
I bought 2nd hand NEC ND-3540A DVD-RW CD-RW DUAL LAYER REWRITER IDE for the replacement of Philips DVD R/RW Drive (DVD8631/96). However this ND-3540A will cause the ploblem of not only unworkable, but...
since you have been inside your computer and moving leads about some of these may be old and deteriotaed then any movement might
(crack break the circuit even if its slight)
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect your hard drive
Test the leads that attach to your ((hard drive from the motherboard)) or replace all the leads that attach to your hard drive including electrical extensions + IDE,SATA and the ones that attach from your ((motherboard to hard drive))
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electrical extensions or just replace them they are probably old and faulty a computer needs its connections to have an end so any faulty leads will end up with a computer error
hope this helps
Jan 10, 2011 | NEC ND-3540A DVD RW Dual Layer Burner
FILE SYSTEM RAW in cd properties and cant access blank cds,dvds
A blank disc is RAW until something is burn to it the burning program will format it to cdfs.
Jul 30, 2009 | NEC ND-6750 DVD±RW Dual Layer Burner
ROXIO Version 10 Cannot recognise a blank disc
I fixed this problem by un-installing the software and re-installing it. I have not yet added any software updates from ROXIO yet. That may affect the solution.
Jun 12, 2009 | Roxio Easy Media Creator 7
I had roxio creator software and had the drive
After working with Roxio, if you find the software you're looking for, Roxio Tech Support will not be able to give you support. Try contacting Inside Sales or a Roxio Technician and see if they can give you a copy of the software again - it will just depend on where you purchased your original version.
Mar 26, 2009 | NEC ND-3540A DVD RW Dual Layer Burner
Not working
Try unplugging it plug it back in then goto add hardware wizard if you have xp and run the wizard if that doesnt work sounds like you need a new dvd burner
Sep 12, 2008 | NEC ND-3540A DVD RW Dual Layer Burner
DVD-RW not recognising blank disk
Usually HPs are good with +R DVDs unless things have change over the last year or two.
Whats the model number on your computer?
Aug 09, 2008 | Tablets & eReaders
NEC 3540A stopped reading blank DVD+DL
Hi JonPM
Burning a dual layer disk requires a functionality of the drive that is not used in the burning of normal disks. But before we consider that the drive may have a mechanical problem, lets clean out all your temporary garbage. Click on this link and download Cleanup 4.5.2 (http://majorgeeks.com/CleanUp_d4895.html
Instal and run the program. Once it has finished, reboot your computer and give burning onto the DL disk another try. Let me know what happens.
-C
Jun 20, 2008 | NEC ND-3540A DVD RW Dual Layer Burner
Did you try a DVD firmware update? Some dvds need new firmware to reconize some DVDs
May 30, 2008 | Computers & Internet
Lite-on DVDRW SHW-160p65 DVD-RW drive
Where are you looking to recognize the disks? if it is in my computer in Windows it would most likely be because the Roxio software was what was recognizing the disks. generally Windows does not do a very good job of recognizing blank disks. I would look at the disk information in your current CD burning software and see what that says.
Nov 13, 2007 | Computers & Internet
NEC ND-3540A DVD RW Dual Layer Burner Logo
77 people viewed this question
Top NEC Computers & Internet Experts
parusdi rusdi
Level 1 Expert
Alun Cox
Are you a NEC Computer and Internet Expert? Answer questions, earn points and help others
