Question about Bush WS6671 28" TV
TV changes channels itself
Hi, My tv is fairly new and all of a sudden its changeing channels on its own, if i leave it like that after a while a red timer appears of about 1 min then the tv turns off and comes on itself and does the same thing with the channels. Ifi put it on standby after 5 seconds it turns on by itself, it seems as if a button is constantly pressed but i have taken batteries out of the remote but i have the same problem, please help.
  • 2 more comments
  • sohail akbar Apr 02, 2006
    Thanks for your reply, i have tried everything really even i opned up the tv and disconnect the cables for remote sensor then switched the tv on and it was still changing channels, even if i put the tv on standby from the remote it turns back on again.
    i have checked all buttons and they are not stuck, do you suggest i open up the actuall infrared sensor on the tv and clean it or something, thanks for your help.
  • Anonymous Sep 13, 2008
    i have sony kv-2185.  when i surfing channels, it changes some channels to
    the next below.  can you plz advise a good solution to problem.  million
    thanks in advance
  • MaryJGolden Dec 26, 2008
    I have similar problem... Toshiba 35" tube TV, volume up and channel down continuously changing (all of the sudden one day). The power button had been broken a while before.. so naturally I assumed the front panel of buttons was depressing the other buttons and causing the haywire channel and volume changes. NOPE, I took it apart and completely removed the plastic button panel so nothing could be pressing anything, and nothing inside was stuck. Still the changing problem. Where can I get a remote sensor?
  • Arthesh naik Dec 31, 2018
    My crt tv automatically channel change please help me
    President:
  • 3,130 Answers
Have you checked to see if any of the front panel buttons are depressed and stuck??? this is a big problem these days?? I have also found the infared remote sensor to be bad on some sets that do crazy things all by them selfs.. A funny storry once i had was a customer called me after her mother called some goast finders as her maggy projection set would go on all by itself andf the channels would change and the volume would go up and down all by its self. funny thing I had a set just like thast in the shop at the time with the same problem and I scoped out the output pulse from the infared reciver on the set and that was putting out noise on the data line and caused the set to eratacly do all sorts of weird stuff. get the point?? its a stck button or the remote sensor is bad.
Posted on Apr 02, 2006
    Problem Solver:
  • 5 Answers
I've had a similar problem. I was watching TV one day and all the sudden the channel changed by itself. It went down one station. Then every once in a while it would just go down one station on its own. It has done it more often recently.
It does not come on or go off by itself and it does not keep flipping channels. It just goes down one station and stays there until I push the channel button or use the remote to change the channel back.
I'm thinking that the sensor may be going bad or it could have a button stuck. The power button did break a while back, so maybe that has something to do with it. It's something within the TV itself that is causing it, like a bad sensor that is malfunctioning and causing it to flip.
It will most likely have to be taken to a TV repair shop to get checked out and to have it fixed there. Unless you know how to put in a new sensor to see if that fixes the problem. Either that or you can check to see if there are any stuck buttons.
Posted on Jul 16, 2009
4 Suggested Answers
Arpi
  • 326 Answers
SOURCE: Bush id tv
Dear Sir, unfortunately tonight you will not be able to watch this TV set. Please try with an alternative solution. This job definitely requires a professional technician Best regards, Arpi
Posted on Jun 17, 2007
SOURCE: bush lcd 27006 standby flashing
Yeah your psu needs new capacitors.
Posted on Sep 21, 2008
SOURCE: Stuck in Standby
I've just called Argos who I brought the bush tv from and they talked me though how to fix this problem, here goes
Press and hold the on/ off button
Whilst holding unplug the plug from the wall
Continue holding for 30 seconds
Plug in the plug whilst continuing to hold the on/ off button
Continue to hold for a further 30 seconds
And the screen should come back on, it's worked for me, good luck x
Posted on Mar 19, 2013
I cannot adjust volume or change channels on TV or with the remote. Do I need a new motherboard?
Unplug the TV, and leave it unplugged for abt 20 minutes,
Plug it back in, turn it on, and see if it has reset itself.
The channel and volume control memory and adjustments are on the main or motherboard
Oct 20, 2018 | LG Televison & Video
All of a sudden we can't pick up not one channel
Perhaps your tuner is bad. Have you tried reprogramming after you bought new antenna?
Feb 25, 2013 | Channel Master 3020 Large UHFVHF Antenna
Aiwa TV MODEL No. TV-A149 AGING
I have Aiwa TV MODEL No. TV-A149
The problem that I am suddenly facing is that I can't change channels or volume or use any other function. I can't even turn it off with remote control.
Its stuck randomly on a particular channel that I was watching at that point of time.
Along with that channel it now shows a message in flashing red color that reads :-
AGING
6EDEH
Now when I press ''Display'' button on remote control volume goes off and this code is shown :-
S123 K234 Y
100 000 0
The numbers in the second line can be navigated by ''CH+'' button and changed between 0 and 1 by ''Vol+'' button.
I really don't know anything about this. So, please help me out of this problem.
Sep 14, 2009 | Aiwa TV-S2011 20"
Hisense
your Tv remort Or Tv Swich service Requied
Sep 18, 2008 | Hisense LHD3204US 32 in. LCD HDTV
No picture, just an abstract pattern
it depends if its just that input or the whole tv itself if it works on other inputs it may not be to bad to fix, but if its the tv itself it depends on how old it is and how much you paid. it could wind up costing quite a bit. so take all those things into consideration. it might just be time to upgrade
Jun 05, 2008 | Sony KP-53HS10 TV
Tv switches source channel without warning
Hi Andy.
What is the samsung model number ?
http://dysonmanuals.llc.nu/
Chris...
Dec 31, 2007 | Televison & Video
42" Plasma TV Problem
same frustrating symptoms on brand new 42inch here! tv just turns itself off sometimes without warning or if changing to certain channels. leaves red light flashing for a while then red light goes away. any attempts with remote gives flashing green liht on tv. manual power off and on restarts tv but auto off again. found while manual power on keep changing channel on remote till stable picture appears. then use remote to shut down tv - solid red light indicates standby mode. then use remote to turn on again... till next time it happens. but what is technical fault??
Aug 18, 2007 | Panasonic VIERA TH-65PV500 65 in. Plasma...
TV or Satellite Box Problem?
Do you have a VCR or DVD recorder? If yes, set it to record what you are watching. After a "blackout" rewind the tape and review it. If there is a blackout on the tape, the problem is the sallite box, if not, it is the TV! QED
May 23, 2007 | Sound Ideas Twentieth Century Fox -...
TV will suddenly change channels, change volume, or go to set up screen by itself
yes and this is a common problem! First lets check out the obvious/ when theis fault starts to happen take out the batteries out of the remote control. If the problem stops then you need a new remote. If the proplem persist the remote sensor assy is bad in the tv set. Ive never heard a cable box causeing a motherboard to act up?? Wait arent mother boards in computers?? lol. believe me you need to tell the tv msn to replace the rmote sensor. Now in an extremly rare cases the microprocessor was causing the problem BUT highly unlikly. Good Luck
Jun 03, 2006 | Toshiba 32A33 32" TV
Televison & Video Logo
8,149 people viewed this question
Top Bush Televison & Video Experts
Joseph Hoffmann
Raj Patel
Are you a Bush Televison and Video Expert? Answer questions, earn points and help others
