Question about Dryers
I have a Kenmore electric dryer model 110.63932101 with no heat. I'm a licensed electrician- I checked the limits and the thermister, all ok. I have aprroximately 65 volts between the 2 leads going to the heat elements with the leads removed and the machine running. Can you point me in the right direction? Thanks Brian
  • 958 Answers
If you put the leads back, can you still measure a voltage between the heating terminal leads?
you could just be measuring a stray voltage...
if there is still 65 volts, the heat setting could have been low and it should be heating.
if you have a current meter, you can us it to measure the current being drawn by the heating element.
tnx 4 using fixya,
let me know what happen...
drcool
Posted on Sep 10, 2008
  • francis rivero Oct 19, 2008
    hi brian,
    is your problem with your dryer already solve?
    this is just a follow up.
    keep me posted what happened.
    tnx 4 using fixya,
    drcool
My lg dryer dle3777 electric is not drying. The cooling cycle light is blinking and the air never heats up.
Check the heating element, Hi limit or any thermisters(Especially on the exhaust). The heating element should read about 40 ohms.
http://www.repairclinic.com/PartDetail/Heating-Element-Assembly/1268157
See if this helps.
Feb 22, 2011 | LG DLE3777 Electric Dryer
Heating problem with kenmore elite he4 electric dryer. drum turns, lent trap clean, heating element ohms ok, thermo coupler ohms ok, thermostat ohms ok, timer counting down. still no heat.
limit switch stuck open should be behind motor housing is a tight fit to get to but there are two there on the element one on vent tube the other is thermal switch recommend chang the two on the tube ck element limits should all read continuityif not reolace
Jan 26, 2010 | Kenmore Elite HE4 Electric Dryer
Dryer not heating
have you checke the heating element for contanuity, also the high and low limit
Apr 07, 2009 | Whirlpool LER5636P Electric Dryer
Dryer will not heat
Have a certified electrician check your outlet. The dryer requires 220VAC for the heating elements to work. If this is ok, check the heating elements it may be broken.If this is ok, check the high and low limit switches, this could be defective.
Apr 04, 2009 | Kenmore Elite HE3 Steam 8674 Dryer
Kenmore 84152 /94152
probably the heater
Jan 15, 2009 | Kenmore 63942 Dryer
Kenmore electric dryer no heat
Test for 240 vlts in the back of dryer while the dryer is running.It can heat the first time but ounce dryer is under a load it can loose the voltage. Have you tested voltage to the thermistate while dryer is running?
Jul 25, 2008 | Dryers
Kenmore dryer not heating
  • before you go any further check the outlet and make sure you are getting a full 220v
  • sometimes one side of the circuit breaker will trip causing the unit to run but with no heat.
Jun 28, 2008 | Kenmore Dryers
Kenmore dryer (electric )
NOT ELITE HE4..... Model 96595400. Replaced thermistor and Hi-Limit Stat. Probably the thermistor.
Jun 28, 2008 | Kenmore Elite HE4 Electric Dryer
Dryers Logo
Top Dryers Experts
