Question about Zanussi ZWF1440 Front Load Washer
Washing cycles My machine keeps stoping with the drum full of water i then have to set it to spin to get rid of the water. I have lost my manual and suspect I am using the wrong cycle. there is a 40 with no lines under a 40 with one line under and a 40 with two lines under Help (It doesnt help when my grandson keeps fiddling with the controls when he visits. ha ha
  • patstan Sep 10, 2008
    I realise this but I cant seem to select the correct programme as I have lost the manual explaining all the different settings.
    I will have to go through each programme and hope for the best ! Cheers and thanks for your help
    President:
  • 1,462 Answers
If you put machine on a delicates or wool wash, it will stop still full of water giving you the choice to only drain or drain and spin
Posted on Sep 10, 2008
Oko 72630. Why is it stuck on rinse cycle?
Could be several reasons:
- Selected the "Night cycle" program (means standing with the drum full of water, reason: too much noise in the spin cycle)
- Set to the "Rinse hold" (means standing with the drum full of water, reason: wrinkles on the clothes)
According to your description I think that this is not a failure otherwise error E20 will be appears on display.
Once the washing programme has come to an end, END illuminates on the programme progress display.
If RINSE HOLD was selected, the display beside the START/ PAUSE button flashes.
1. After a rinse hold, the water must first be pumped out:
- Either press the START/PAUSE button (the water is pumped out and the washing is spun according to the completed programme;
After the START/PAUSE button is pressed again, the spin speed can still also be changed during spinning), or
- Turn the programme selector to PUMP OUT and press the START/PAUSE button (the water is pumped out without spinning),or
- Turn the programme selector to SPIN or SHORT SPIN and press theSTART/PAUSE button (the water is pumped out and the washing is spun or gently spun).
At the end of this programme step, the END indicator will illuminate.
2. Open the door.
As soon as the DOOR indicator lights up green, the door can be opened.
Dado
Aug 15, 2015 | AEG Washing Machines
Why does the inner tub for the LG washing machine tub not spin when the tub is full?
not sure I understand you, but ur drum should or does not spin when full as it is set that way, first the drum drains most of the water then it goes into spin?
Jul 29, 2014 | LG Washing Machines
Washing machine wont drain keeps bleeping ERR2
It will not spin with water in.
See if you can locate a filter, and clean same.
Jan 19, 2010 | Haier Washing Machines
My GE profile WPDH8800J doesn't hit high speed
Your belt may be slipping and not spinning the drum to full speed to rid most of the water in clothes.
Sep 09, 2017 | General Electric WPDH8800J Front Load...
Drum will not spin
I am the new owner of a used Asko Cylinda 10504.
The last owner briefly demonstrated the washer starting a wash cycle and entering the agitation cycle of the wash before stopping and pumping the water out and spinning in a final end cycle. I bought it. I had the machine installed turned it on and cannot get it to go through the wash cycle. After starting at #1 it goes through a perpetual spin cycle of sorts--water and soap soaking the drum and laundry but not enough water to fill up half way or less. It stops at number 4 on the program knob sits on a red dot (next to the #4) and does nothing. I then manually move it to the next cycle and it repeats the spin cycle again until I have advanced the program to the end. No wash cycle no rinse cycle. Nothing. When it advances to the red dot I wait for at least 5 minutes before manually advancing the knob. The instructions say that I should get the water pumped out by turning the program knob to #7 or #9 but in both cases it just spins and does no empty or finish in the end spin cycle of several (9?) minutes. Nothing but banging and spinning. The water seems to get into the drum as well as the detergent but nothing else is happening.
No mater where I start the program it spins and sloshes soapy water, pumping almost nothing out.
Any suggestions short of putting it on the curb or paying a kings ransom to fly a tech out to look at it?
MY GUESS.
It seems that it is repeating the same brief cycle over and over. During the move to my house the electronics re set(??!?!?) and now need to be set to the normal mode after being re connected?
Can you help?
Blessings,
Douglas
May 20, 2009 | Asko Washing Machines
Hotpoint WF321 during rinse and spin, will not go into full spin as machine keeps filling with water.
you should check your pressure switch hose for a pin hole or better still just replace the hose and it should sort your problem out good luck hamstel
Nov 05, 2008 | Washing Machines
Bosch classixx 1000 washing machine - stops on spin
Washing machine stops at the spin cycle - light flashes. Have to drain water out manually. Happened last week and was then able to run an empty rinse cycle. Machine worked normally for another week. Same problem today but have had to drain water manually from the drum after trying an empty 90 wash and rinse cycle (both stopped on the Spin and flashed). Any ideas? Thanks. x
Apr 29, 2008 | Bosch Classixx WVF 240S Front Load Washer...
Washing Machine Hoover H100M fills too much water in the drum.
this is 1 of 2 solutions  2 this problem the first thing to check is the vacuum system or it is a split in the pressure switch hose
Mar 05, 2008 | Hoover AAA140 Front Load Washer
Drum full of water after wash
Lubricate the motor plate the whole motor slides back and forth to switch from spin to wash. Not a good design very problematic.
Oct 01, 2007 | Maytag Atlantis MAV6451 Top Load Washer
Zanussi ZWF1440 Front Load Washer Logo
80 people viewed this question
Top Zanussi Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
