Unable to turn Tv on
Remote control -no response (new batteries inst) still no response When main on/off switch activated Tv clics on and then immediately clics off
    Brigadier General:
  • 3,614 Answers
Did you hear any popping sound/clicking, or any like that you think that tv still response when you try to turn it ON
Posted on Sep 10, 2008
  • micromaster
    micromaster Sep 10, 2008
    may i know what is the TV model/maker..
    this problem is very common on TV set, for a while just check for any burn resistor, a fault or problem on this part can decrease in
    value is because the wattage value was larger than the value of the
    resistor value. If it was a 1/2watt resistor and wattage goes
    above that value for a giving point of time your resistor will burn
    until it is burnt open. Look for a Elect. capacitor somewhere
    close by and check it. Check for component that could be shorted.
  • micromaster
    hope this initial info helps you..
    kindly rate my solution here.
    -or just let me know if you need more assistance.
    regards
    micro
I get a download message telling me to hit main for three seconds or skip. When I hit main nothing happens and when I hit skip the remote freezes. Cannot perform any functions and unable to change...
check your batteries to make sure they are good. if they are good you may need to default the remote and reprogram. if this doesn't fix it you will need another one
Jun 08, 2014 | Universal MX-450 Remote Control
My remote switch only turns on to fast speed and off. Iam unable to use the other speeds any more usingbthe remote switch.
This is no the fault with remote control. The main system control section circuit to your TV should be checked. Contact any service technician.
Aug 08, 2013 | Hunter Televison & Video
On my maine tv , my remote will not turn the tv on or off or adjust the volume. I have changed the batteries
Has your remote been correctly configured to work with your TV?
I have a very similar model of remote to the one pictured, as such I remember the man in charge of connecting my satellite box "activated" the remotes ability to interface with my TV.
Try hitting any button marked "TV" and then hitting your power button.
Aug 24, 2011 | DISH Network IR Remote Control
I have a hampton bay ceiling fan/light and the remote came with it. The remote model is: UC7083T. The battery died and when I installed a new battery, the remote willnot connect with the fan/light. Any...
try turning off the switch/circuit breaker at the main lighting panel. Then just turn it back on. Worked for me.
I'm guessing a capacitor in the remote is holding a charge and causing the problem. You'll probably need a new remote soon thiough.
Nov 27, 2010 | Universal Remote Control Hampton Bay...
Unable to get fan to respond to remote Hampton Bay 54
these fans must be reset as follows remove the battery from the remote manually turn off the wall power switch put the batteries back in the remote turn on the wall power switch press the remote buttons...if this doesn't work let me know
Jun 01, 2009 | Universal Remote Control Hampton Bay...
Unable to get fan to respond to remote Hampton Bay 54".
There is most likely a wall switch which you will need to ppush to the on position to send power to the fan, then the remote will do as it is supposed to do. If you find that it is not the wall switch, then I would check the electrical panel for a circuit breaker that has kicked partway off or blown fuse.
Apr 26, 2009 | Universal Remote Control Hampton Bay...
Televison & Video Logo
57 people viewed this question
Top Televison & Video Experts
