Question about Sharp Aquos LC-15B4U-s 15 in. EDTV-Ready LCD Television
Sharp auous lcd tv
The tv fell and the screen was damaged, is there a repair for this problem? We have no picture, just a black screen with color lines on half of the screen.
    New Friend:
No picture blak screen
Posted on Jan 24, 2016
Don't buy sharp! ordered a lc-46d62u lcd tv online. It worked one full day. the next day when i turned it on all i got was a spiderweb effect screen. Sharp claims i damaged it and refuses to repair it. The tv was never dropped or mishandled by me. there is not a mark on it. Sharp says their warranty does not cover lcd screens. I learned a $2000 lesson- don't buy online and don't buy sharp.
Posted on Oct 04, 2007
    President:
  • 3,130 Answers
Sounds like you broke the lcd and Im so sorry to be the barrer of bvad news BUT YOU asked ITs trashed! by a new set!! Or call the manufacturer and see what a new display cost?? bet ya its twice what you paid for the set???
Posted on Apr 02, 2006
SOURCE:
Why does picture have lines of different colors?
Common easy LCD TV fix: bad picture screen rainbow colors
? 4:04
https://www.youtube.com/watch?v=KWIWeESmXC0
Aug 10, 2014 - Uploaded by Tampatec
Common easy lcd tv service repair fix, TV's distorted rainbowpicture screen fixed by ... Common easy LCD TV fix: bad picture screen rainbow colors ... Need to report the video? ... Sanyo LCD with Distorted Half Picture Lines Waves Distortion Distorted ...Duration: 11:36. by Do It With Dave 316,733 views.
LCD Display Symptoms and causes. - YouTube
? 2:01
https://www.youtube.com/watch?v=DedJvyNm_s4
Mar 1, 2011 - Uploaded by Grants Pass TV Repair
With LCD TVs you can have the same display problems fordifferent ... Fix for Samsung lcd TV colour display problem - Duration: 1:26. by alwaysafix 462,823 views. 1:26. Sanyo LCD with Distorted Half Picture Lines Waves Distortion ... HOW TO FIX LED TV VERTICAL LINES ON SCREEN 55" MODEL LG ...
How To Fix A Broken Flat Screen LCD LED TV With Lines or ...
Dec 11, 2015 | Sharp Televison & Video
What is causing vertical colored lines on the left 25% of my Sharp Aquos display?
Bad TCON board or Damaged screen. You can try and replace the TCON "Timing Control Board" and see if that helps. Replacing the Screen itself is very expensive and normally about half of what the unit cost new. Here is a video to give you a clue on how to do so, it is pretty easy when you know which board to replace.
LCD TV Repair Tutorial Con Board Common Symptoms Solutions How to Replace...
Jan 01, 2015 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
Black cloud like fogged on Sharp Aquos 37"tv
If your LCD TV or monitor has stopped working, or is displaying one of the following symptoms, then it's a candidate for some new capacitors
- Flickering screen
- Screen image disappears after several seconds
- Dim screen
- Slow start
- Power LED on, but no picture
- Unusual colors and/or lines
The primary cause of LCD TV and monitor failure is caused by faulty capacitors. You can examine the capacitors in your LCD TV or monitor and actually see if they are bad.
If they appear bulged on top, then they need to be replaced.
New capacitors will solve a host of problems in LCD monitors and TV's and will extend the life of your monitor or TV by several years.
Check the cables, connectors and connections.
Take it to a repair shop.
Apr 13, 2014 | Sharp Aquos LC-37GD6U 37 in. LCD HDTV
1/4 of my sharp aqous tv has lines in it
This lines are in colors or black vertical lining in shaping?Yes?These lines are not causes by u or causes by an object by using forces hitting the LCD screen panel itself to causes these problems?Yes than the LCD screen panel are dying and leaking radiation can't be repair only by replacing new LCD screen panel not worth replacing and reparing if require a new LCD screen panel only.If these vertical lines are in colors or black are showing up and causes by the tv itself?Yes.Than the tv have a dying board that call the T-CON board and this board only job are docoding any pictures pixels before it showing up to the tv LCD screen panel.This T-CON board sit at the bottom in the middle of the tv LCD screen panel.Tries websites like Shopjmmy.com,Ebay.com to buy a refurbish T-CON board for the replacement.
Aug 26, 2011 | Sharp LC-52D62U 52 in. LCD HDTV
IT FELL ONTO A CHAIR THE SCREEN WENT BLACK YOU
You have either permanently damaged the LCD display or the inverter board ( which is repairable )
The display will be almost the cost of a new set.
Oct 01, 2009 | Sony BRAVIA KDL-40S2010 40 in. LCD...
My (sharp aquos lc 52d62u) tv fell to the ground. Image of broken glass and colored lines appear
Unfortunately the panel is cracked internally can't can't be repaired the whole panel has to be replaced. most times the panel will cost as much as you paid for the set. My son cracked ours when it was only 3 weeks old it doesn't take much force to ruin one.
Rustym62
http://www.the-tv-dude.typepad.com
Apr 26, 2009 | Sharp LC-52D62U 52 in. LCD HDTV
Sharp Aquos 15 LCD TV
Maybe. Unplug the unit and disassembly it. Look for damaged parts or cracked circuit boards. You may also find the buttons you push to turn it on and activate the menu ect. may be damaged. In most cases the board can be repaired but because that would be time consuming and the repair man charges 60 bucks an hour it is usully not cost effective. You might get lucky and find a wire that fell off in the fall. Good luck.
Apr 20, 2008 | Sharp 15" AQUOS LCD Flat-Panel LC15B4US...
LCD TV Screen repair
I have a Sharp LC52XD1E TV , It has a crack on the screen needs a new screen can it be fixed and is it worth the repair?
Feb 25, 2008 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Sharp LCD HDTV Facedown Damaged
not sure i laid over a lcd for a couple mintues. that belong to my comapny, once i stood it back up the screen was cracked. i like to have fell over, the replacement part is 12266.00 i guess your out of luck. as i am.
Oct 13, 2007 | Sharp Aquos LC-37HV6U 37 in. HD-Ready LCD...
Sharp Aquos LC-15B4U-s 15 in. EDTV-Ready LCD Television Logo
399 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
