Question about 3Com Computers & Internet
/3com 4400 switch power on self test
Yellow steady, for a while after flashing all ports etc.
5 Suggested Answers
  • 35 Answers
SOURCE: 3com 3300 TM - all Ethernet port not working, power led flashing
A blinking power LED means that the switch is either downloading software, or is initializing which also includes running the Power On Self Test. You may have firmware issues with the switch and/or the switch is stuck in initialization mode. You may have to contact 3com regarding a warranty issue. Hope this helps. Good luck.
Posted on Jun 21, 2007
  • 71 Answers
SOURCE: Anyone seen ths before?i
when it flashes it usily means its connected if it dosent work at all you should get a new hub
Posted on Aug 12, 2007
  • 47 Answers
SOURCE: 3COM 4400 has block my entire LAN ...
Sounds like they are daisy chained together and this glicth locked the system.  How are the switches routed through your network.  Do you connect via T1 or Fiber?
Posted on Oct 27, 2007
computerAid
  • 25 Answers
SOURCE: Problem with SW 4400 - restarting....
switch dont restart by themselves without command, first remove the switch from the network, disconnect from internet, make sure you hadn't fired anybody recently it sounds like a hack. reduce network traffic to local area only and priortise important internet traffic. now got back to the switch and troubleshoot make to check the reboot command on error or when error is found, if the problem stops when the switch is remove somebody is messing with the network.or the darn switch is faulty install a new one.
Posted on Jun 03, 2008
I have a old dell and the yellow light stays on, what's wrong?
A steady or Amber (Yellow) blinking power button indicates a low voltage problem. This can be caused by a defective power supply or a defective motherboard. Just to make sure that nothing else is causing the problem, remove any PCI cards like modem, video card, sound card, etc... Remove the memory modules and disconnect cables to CD/DVD drives. Look at the USB ports to see if any are damaged.
Apr 25, 2014 | Compaq Presario 5000 PC Desktop
Yellow blinking light on power button
A steady or Amber blinking power button indicates a low voltage problem. This can be caused by a defective power supply or a defective motherboard. Just to make sure that nothing else is causing the problem, remove any PCI cards like modem, video card, sound card, etc... Remove the memory modules and disconnect cables to CD/DVD drives. Look at the USB ports to see if any are damaged.
Apr 15, 2014 | Dell Studio XPS Desktop Computer
Why does my desktop DELL Optiplex 1700L just flash YELLOW and refuse to come on, motherboard light is on
An Amber (Yellow) blinking power button indicates a low voltage problem. This can be caused by a defective power supply or a defective motherboard. Just to make sure that nothing else is causing the problem, remove any PCI cards like modem, video card, sound card, etc... Remove the memory modules and disconnect cables to CD/DVD drives. Look at the USB ports to see if any are damaged.
Apr 01, 2014 | Dell Optiplex 755 Desktop Desktop Computer...
Dell dimension 5100 ethernet port flashing orange
If the port works, it should be steady yellow. Flashing means that your Ethernet circuit on your motherboard has a problem.
Jan 19, 2012 | Dell Dimension 5100 (D51L1) PC Desktop
My computer won't start up and is blinking yellow. How do I fix it?
An steady or Amber blinking power button indicates a low voltage problem. This can be caused by a defective power supply or a defective motherboard. Just to make sure that nothing else is causing the problem, remove any PCI cards like modem, video card, sound card, etc... Remove the memory modules and disconnect cables to CD/DVD drives. Look at the USB ports to see if any are damaged.
Nov 16, 2011 | Dell Inspiron One 19 All-in-One Desktop PC...
Hi, the lights on my circiut board are flashing the one on the left is on all the time and the one to the right of it flashes two times and then waits and then flashes two times again
Error Codes
A green LED indicates system faults
Steady On: System OK
Steady OFF: Board control fault or no power applied
1 Flash: Ignition failure (control in one-hour lockout)
2 Flashes: Pressure switch fault, fails open (switch is
stuck open)
3 Flashes: Limit switch open (main or auxiliary)
4 Flashes: Pressure switch fault, fails closed (switch is
stuck closed)
A yellow LED indicates flame status
Steady on: Normal flame is sensed
Flashes: As flame weakens, frequency of LED flashes
increases
hope this is helpful.
Dec 21, 2010 | Ruud Central System Air Conditioner
Meaning of rudd furnace trouble codes
Error Codes
stuck open)
stuck closed)
increases
Dec 12, 2009 | Heating & Cooling
Turned the power button on turned yellow and flaSHED RED
You will need to have the motherboard reflowed. The processors have probably come unseated from overheating.
Oct 07, 2009 | Video Game Consoles & Games
Yellow flashing light on dimension 5051
An Amber blinking power button indicates a low voltage problem. This can be caused by a defective power supply or a defective motherboard. Just to make sure that nothing else is causing the problem, remove any PCI cards like modem, video card, sound card, etc... Remove the memory modules and disconnect cables to CD/DVD drives. Look at the USB ports to see if any are damaged.
Your responses are intended to improve the level of service provided. Please show your appreciation by rating your experience.
Thank You.
Nov 20, 2008 | Dell Dimension 5150 (DIM515MIN) PC Desktop
Computers & Internet Logo
526 people viewed this question
Top 3Com Computers & Internet Experts
micky dee
didi2005
Are you a 3Com Computer and Internet Expert? Answer questions, earn points and help others
