Question about LG Televison & Video
Hi. I recently purchased an LG 37LG5010 LCD TV. I have a hearing problem and want to use the headphones. However, while the headphones do indeed work, when they are in use, the main TV speakers are muted. Is it possible to have the headphones plugged in, and have the main speakers operational at the same time. Thank you s.cannon@sisk.ie
  • horse2008 Sep 10, 2008
    OK-understand that all LCD TVs do not allow phones and speakers to work simultaneosly. Is there additional kit that would allow a favourable solution
    Brigadier General:
  • 6,966 Answers
If I understand your requirements right, they would be:
  • headphones operate; simultaneously with
  • main speakers.
However, the LG 37LG5010 LCD TV has limitations that are:
  • once headphones plugged in, the main speakers cutoff;
  • there are no line/audio output at the rear of the unit for use of standard headphone/external amplifier.
A possible solution based on your post "...Is there additional kit...":
  • use the Digital Audio output (optical digital audio outputs [Toslink] or coaxial digital audio outputs);
  • connect a Zhaolu D2.5C DAC & Headphone Amp or similar products;
  • connect your headphone to the Zhaolu D2.5C;
  • Additionally, the Zhaolu D2.5 has RCA audio output that can be connected to an external audio amplifier or home theater receiver/system
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Posted on Sep 10, 2008
  • Louie  Role
    Louie Role Sep 10, 2008
    An alternative is to use an external monitor pair (speaker/amp combo with headphone out) capable of accepting 24-bit/96kHz capable S/PDIF optical & coaxial. An example is Roland's MA-20D.
  • Louie  Role
    Louie Role Sep 16, 2008
    Hi again,
    Any updates?
  • 4,234 Answers
Unfortunately your set does not have the ability to do this without an internal modification. In the future, you should look for a set that also provides audio out jacks on the back for connection to a stereo. Those jacks are independent of the speakers and would provide you with the flexability to use an adaptive listening device.
Dan
  • LG Master
  • 19,396 Answers
It is impossible to have the headphones plugged in, and have the main speakers operational at the same time without taking the tv apart and modifying the internal wiring.
the only way to ddo that is by paying a technician to modify your TV, this will invalidate the guaranty.
  • Ginko
    Ginko Sep 10, 2008
    There is no kit, the technician will just have to cut one of the female jack wirings, and solder it on another contact, that will allow you to use headphones without excluding speakers.
  • Ginko
    Ginko Sep 10, 2008
    Another solution is buying external speakers and an audio splitte like this 3.5mm Splitter, 6 ft.
    Then buy external speaker and connect both headphones and speakers to splitter.
    Here you get external speakers 2-Way Satellite Speakers or Portable Speakers- Diamond Tower Light
  • 1,879 Answers
Check the back of the TV & look for the audio-out RCA jacks - hook it up with an audio receiver.
    Master:
  • 726 Answers
The tv will mute when u put the head phones in unless you use them by rca leads
    Brigadier General:
  • 3,614 Answers
No.. it is not ppossible.. unless you will put the headphones on the tv audio panel using an rca plug
  • micromaster
    micromaster Sep 10, 2008
    The Answer to your Question was NO..
    hope this initial info helps you..
    kindly rate my solution here.
    -or just let me know if you need more assistance.
    regards
    micro
    Master:
  • 505 Answers
No when you plug in the headphone the tv auto mutes
  • Or it also depends in the tv in settings. if you have the option of do not mute when input headphone jack - most TV's don't have this option
  • Every time u plug in the headphones it mutes now for all lcd Tv's They do not have the option of un mute when jack is plugged in
LG 55LS4500 55 in. TV has sound through speakers, no audio except a hum from headphones and the optical digital to analog output fiber lights up but no sound output What board is bad?
Hi Louis,
The audio circuitry is located in the main board. Try unplugging the TV for a while and try again if the audio comes back.
I would suggest to check all your settings in the audio section first and if everything seems OK then the main board should be replaced.
Feb 26, 2017 | LG 55LS4500 55 Inch 1080p LED LCD HDTV -...
Will tv volume and headphone work at the same time? someone can hear headphones at the same time the tv
If I understand your question correctly, you want to use headphone AND be able to play through the speakers at the same time?
Not usually. Most headphone circuits disconnect output to the speakers when you plug in headphones.
Nov 22, 2014 | Vizio XVT553SV 55 in. LCD TV
Hi I have just bought a 2nd hand lg tv 37lg5010 does anyone no how I can remove the stand please
Lay it on the bed and look up into the bottom of the stand for any mounting screws. If you locate them, remove them and there may be some clips that snap in when the base is installed and will require some applied pressure to release.
Jul 07, 2014 | Televison & Video
I bought wireless headphones, how do i connect them to the TV wirelessly
Normally the wireless headphones have a transmitter that send audio via wireless to the wireless headphones.
The transmitter needs to be plugged into the headphone outlet on the TV. This will switch off the speakers on the TV and sends the audio to the wireless headphones.
Sep 23, 2012 | LG 32LG30 32 in. LCD HDTV
When we plug in hubby's remote headphones (he has a hearing impediment), it cuts off the sound and I can't hear it.
That is normal operating mode when using the headphone jack. The only way for you to do this without cutting the sound from the speaker so you can hear the sound (if your remote headphone has the Line level input), is to use the audio line out (WHITE and RED RCA jacks) to feed the remote headphone unit.
What the make and model of the remote Headphone system that you have?
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Jun 05, 2011 | LG 32 32LK450 32 in. LCD TV
Lg lcd tv 37lc2d no headphones socket - how do i connect headphones?
You can purchase a cable to connect to the Audio Out ports on the back of the TV. It will have 2 RCA connectors on one side that plugs into the TV and a 1/4" stereo jack on the other end that you will connect your headphones to. You could even pickup a pair of wireless headphones... they will have a volume control on them! I hope this helps.
Mar 17, 2010 | LG 37LC2D Television
My LG TV and PS3 don't get along anymore!
Tries change all new HDMI cables,same prob.Tries RCA cable.
Nov 23, 2009 | LG 37LC7D 37 in. LCD HDTV
Connect headphones to lg scarlet 32inches tv
ya..you can connect your headphone to the
LCD tv.It will be available on the back of the
tv.The port will be available.
check this out..
thank u..
rate me..
Feb 24, 2009 | LG Scarlet 42LG6000 42 in. HD-Ready LCD TV
37lg5010 remote code?
0056 works for all LG as its the most modern 4 digits for LG
Nov 17, 2008 | Televison & Video
Televison & Video Logo
554 people viewed this question
Computer Repairing
Computer Repairing
