Istalling windows xp
The computer is saying setup cannot copy the file p3.sys
    President:
  • 2,961 Answers
Is this a genuine copy of windows?, if not just press Esc to skip the fille
Posted on Sep 10, 2008
System32 drivers ntfs sys
To resolve this problem, replace the missing or corrupted Ntfs.sys file:
  1. Use the Windows XP startup disks or the Windows XP CD to restart your computer.
  2. When the "Welcome to Setup" screen appears, press R to select the To repair a Windows XP installation using Recovery Console, press R option.
  3. Type the number of the Windows installation that you want to access from the Recovery Console, and then press ENTER.
  4. Type the administrator password when you are prompted, and then press ENTER. If no administrator password exists, just press ENTER.
  5. At the command prompt, type the following commands (press ENTER after each command):
  6. --->cd \windows\system32\drivers
    --->ren ntfs.sys ntfs.old
    Note This step renames the corrupted Ntfs.sys file to Ntfs.old. If the Ntfs.sys file is not found, the file is missing.
  7. At the command prompt, type the following command, and then press ENTER:copy cd:\i386\ntfs.sys drive:\windows\system32\drivers
    Where cd is the drive letter for the CD-ROM drive that contains the Windows XP CD, and drive is the drive where you installed Windows XP.
  8. Remove the Windows XP CD from your CD-ROM drive, type quit at a command prompt, and then press ENTER to quit the Recovery Console.
  9. Restart the computer.
May 17, 2014 | eMachines Computers & Internet
My daughters Asus eee pc MK90H notebook says windows could not start because system 32 is missing or corrupt. It says to use the original CD Rom, which obviously we dont have. Help what do we do?
To restore a missing or corrupt ntfs.sys file you must have the Windows XP CD and follow the below steps.
Insert the Windows XP CD into the computer and restart the computer.
As the computer is starting make sure to press a key to boot from the CD.
In the Windows XP setup screen press the 'R' key to run the Windows Recovery Console.
If prompted enter the number of Windows installation you're repairing.
At the command prompt type the below command.
copy x:\i386\ntfs.sys c:\windows\system32\drivers
* In the above example you would replace x: with the letter of your CD-ROM drive. Many computers have the CD-ROM drive configured as the D: drive.
If ntfs.sys is still on the computer you'll be prompted if you wish to overwrite the file. If prompted, press the Y key for Yes to overwrite the file.
Once the file has been successfully copied remove the CD and reboot your computer.
Do NOT use an OEM "Recovery Disc". Only a valid Windows XP media will work or a disc from the OEM that says "Operating System" may sometimes work depending on how the manufacturer labeled the CD.
Hope this helps. Let me know if you need more information Thanks
May 11, 2011 | ASUS Eee PC 1000HE Netbook
Windows did not start ,drivers missing
  5. At the command prompt, type the following commands (press ENTER after each command): cd \windows\system32\drivers
    ren ntfs.sys ntfs.oldNote This step renames the corrupted Ntfs.sys file to Ntfs.old. If the Ntfs.sys file is not found, the file is missing.
  6. At the command prompt, type the following command, and then press ENTER: copy cd:\i386\ntfs.sys drive:\windows\system32\driversWhere cd is the drive letter for the CD-ROM drive that contains the Windows XP CD, and drive is the drive where you installed Windows XP.
  7. Remove the Windows XP CD from your CD-ROM drive, type quit at a command prompt, and then press ENTER to quit the Recovery Console.
  8. Restart the computer
Mar 03, 2011 | Computers & Internet
Windows won't start
When you put in the XP CD and it boots off the cd, the XP setup files copy across, and at the 1st screen, you should be able to choose Repair. Press r, and this will start the Recovery Console.
When you are in the recovery console, choose your Windows installation (You will see what I mean when you follow the instructions.)
When you are sitting at the command line(C:\>Windows), access your CDROM drive by typing the letter followed by a colon, eg "D:". It may also be E:, F:, or G:.
When you have changed to the CDROM drive, type the following:
cd\ <enter>
cd\i386 <enter>
expand pci.sy_ C:\pci.sys <enter>
C: <enter>
cd\ <enter>
copy pci.sys C:\windows\system32\drivers <enter>
If it asks to replace, confirm.
Then restart the computer.
Regards
Riztech
Jul 17, 2010 | HP Compaq Presario SR1538X (PX799AA) PC...
I am having trouble running setup on my desktop
  8. Restart the computer.
Aug 28, 2009 | Computers & Internet
Setup cannot copy the file:p3.sys
This has to be a problem with your installation disc itself make sure it is not scratched. If it is a backup copy the files may have gotten corrupted. You will need to a get a new copy of the installation disc to be able to install.
Feb 09, 2009 | E-Machines etower 400i PC Desktop
Missing or corrupted file C:\windows\himem.sys
If you are running Windows 95, Windows 98, type:
copy himem.sys c:\windows <press enter>
If when typing any of the above commands you receive a prompt that the file already exists, ensure to overwrite it.
Reboot the computer; if the issue continues to occur, verify that the config.sys is properly setup. The line himem.sys should read:
DEVICE=C:\Windows\HIMEM.SYS
or
DEVICE=C:\DOS\HIMEM.SYS
Additional information and examples of the config.sys can be found on our autoexec.bat / config.sys page.
Dec 27, 2008 | Compaq Presario Notebook
Pc945gz7mc-k52h
Put your hard disk to another computer format all drives unallocate the drives and aloocate in newly again..then istall the OS newly then put back in your system and check whether it works...
Sep 26, 2008 | Computers & Internet
Im trying to install win xp on a used computer
Are you useing the windows xp cd?
Enter the xp setup when asked "press any key to start from cd.." (press a key here so you get into the blue windows installer)
And follow the steps, do you get problems there?
Jun 05, 2008 | E-Machines eMachines Desktop PC
Windows installation issues
Either you have a defective CD, or a defective Hard Drive, or defective memory. Firstly is this a clean install? Try reformatting the drive and running chkdsk or a manufacturers disk utility. Then remove fingerprints and other marks from CD by wiping from the centre outwards. Let me know how you get on.
Apr 27, 2008 | HP Compaq dx2000 Microtower PC Desktop
Computers & Internet Logo
63 people viewed this question
David Payne
David Payne
