Question about Philips Televison & Video
107cm Lcd TV - unable to switch tv On( activate ) no response from the remote control at all - stand by light is blinking and when trying to activate by side on/off button tv clics on and immediately turns Off
    Brigadier General:
  • 3,614 Answers
Did you hear sounds coming out from the tv.. or is there any instance that you got a picture...
Posted on Sep 10, 2008
  • 1 more comment
  • micromaster
    micromaster Sep 10, 2008
    the resistor burn and decrease in
    value is because the wattage value was larger than the value of the
    resistor value. If it was a 1/2watt resistor and wattage goes
    above that value for a giving point of time your resistor will burn
    until it is burnt open. Look for a Elect. capacitor somewhere
    close by and check it. Check for component that could be shorted.
  • micromaster
    ope this initial info helps you..
    kindly rate my solution here.
    -or just let me know if you need more assistance.
    regards
    micro
  • micromaster
    regards
    micro
    Master:
  • 505 Answers
Check the Fuses
  • Could i please have the Brand and model of your TV please : Viper
My tv has no power?
Let's assume your post in flat panel TV's is for an LCD TV. Since your make and model is not provided, only basic info can be provided. Most LCD TV's have a stand-by power LED that is either on or comes on when the TV switches or blinks in the event of a failure. If you don't see a light when there should be one normally, then you may have a failed stand-by power supply. The stand-by power supply provides a voltage necessary to allow you to command the tv to turn on with the remote or via the power button on the tv. If the power light is normally off and normally comes on when you use the remote to turn it on but nothing happens it can still be the stand-by power supply failed. The next level of the power control is done by a small tv micro (processor) often on a board that handles audio that tells the main power supply board to turn on. To render much technical assistance you would have to know how to take voltage readings on the PSU. If there is no SB5V you either need a PSU board or there is an issue from the AC line to the PSU. It can get complicated from there depending on the failure. I assume you know the power outlet at the wall is good and the remote battery is good and you have tried the power button on the tv to eliminate a faulty remote.
Dec 10, 2014 | Televison & Video
Unable to turn Tv on
did you hear any popping sound/clicking, or any like that you think that tv still response when you try to turn it ON
Sep 10, 2008 | Televison & Video
Need a code for a tevion lcd 32081D to activate sky remote
Hello
Check these codes.
Tevion
TV66SIL
065
Tevion
1530, 3731VT, MD3731VT
696
Sky+ Remote Control Unit Programming Procedure Follow the steps below
1. Select any channel on the TV.
2. Point your Sky+ remote control away from the TV and press the tv button.
3. Press and hold down the Select and red buttons simultaneously on the Sky+ remote control until the red light at the top of the Sky+ remote control flashes twice.
4. Input the 3 digit number from the Sky+ remote control codes then press the Select button. The red light at the top of the Sky+ remote control should flash twice.
5. Point the Sky+ remote control at the TV and try the volume button.
* If this works try the other TV functions.
* If these work then the correct code has been selected.
* It's important to note that not all TV functions will be supported by the Sky+ remote control e.g. Picture in Picture.
If all functions do not work correctly, then repeat steps 1 - 3 and work through all the relevant 3 digit numbers from the Sky+ remote control codes, until you find the code which supports all or as many of the TV functions as possible.
Please note: In order to operate both your TV and Sky+ with your Sky+ remote control, you will be required to switch modes e.g. to switch on your TV from stand-by, you would need to press "TV" followed by the "Stand-by" button. Then to change channel on your Sky+ you would need to press the "Sky" button followed by the "TV guide" button
OK.
Oct 16, 2011 | Televison & Video
My mother in law just passed away and I inherited back the Sylvania LD320SSX I bought her last year. What is the 5 digit remote code for a Comcast remote? Tried all I could find to no avail.
Comcast uses at least 11 different remote controls. I referred to the manuals listed on their remote control page for instructions on programming the three Comcast-branded remote units:
Comcast Universal Remote (Red OK/Select button)
Sylvania LCD TV codes: 20000, 20035, 20043, 20081, 20593, 21593, 21781
Procedure:
  1. Turn on the TV.
  2. Press the TV button once.
  3. Press and hold the Setup button until the TV button blinks twice, then release Setup.
  4. Enter a five-digit code from the list. If this is done correctly, the TV button will blink twice. If you enter an invalid code, the TV button will produce one long flash and the remote control will exit the program mode.
  5. Aim the remote control at the TV and press the Power button. If you have the correct code, the TV will turn off. If not, repeat steps 2-6 with a different code.
If none of the codes work, you can try the code search procedure:
  1. Turn on the TV.
  2. Press and hold TV. Press and hold Setup until the TV button light blinks twice, then release Setup.
  3. Press 9-9-1. The TV light will blink twice.
  4. Press and release the digit 1. The TV key will blink twice. Press the Power key.
  5. Aim the remote control at the TV. Press CH+ until the TV turns off. You may have to press numerous times until the remote control finds the right code in its library. Stop when the TV turns off.
  6. When the TV turns off, press Setup once to lock in the code set. The TV light will blink twice.
Comcast Universal Remote (Grey OK/Select button)
Sylvania LCD TV codes: 0000, 0035, 0043, 0081, 1781
Procedure:
  1. Turn on the TV.
  4. Enter a four-digit code from the list. If this is done correctly, the TV button will blink twice. If you enter an invalid code, the TV button will produce one long flash and the remote control will exit the program mode.
  1. Turn on the TV.
  4. Aim the remote control at the TV. Slowly Press Power and TV alternately until the TV turns off. You may have to press numerous times until the remote control finds the right code in its library. Stop when the TV turns off.
  5. When the TV turns off, press Setup once to lock in the code set. The TV light will blink twice.
Comcast Digital Transport Adapter (DTA)
Jan 22, 2011 | Sylvania LD320SSX LCD TV
My tv won't turn on anymore. The power light and the opc light blink twice at the same time and then the opc blinks once and it keeps doing that. Please help!
Hi
Make sure the AC cord is not loose or disconnected. Check to ensure the cord is firmly plugged into the outlet at one end, and firmly connected to your television at the other end. The AC cord connects to the television about midway across the back of the set, near the bottom of the back panel. The hole for the AC connection is shaped like a figure eight. Try powering up the TV with the cords firmly connected.
Check the "Main Power" to ensure it is on. Locate the button on the top of the television among the "Volume" and "Channel" buttons. Press the button to switch the television on. If the "Main Power" button is off the remote will not turn on the television. Wait to see if pressing "Main Power" will activate the TV.
Press "TV Power" on the remote control to power up the TV from stand-by mode. If the power light on the front of the television glows red when you press "TV Power" on the remote, press the "Main Power" button on top of the television to remove the TV from stand-by. If the TV is accidentally in stand-by mode it may not come on when pressing certain buttons.
Check the circuit board. If your set still won't turn on and you hear a clicking noise when you plug it in, you most likely have a defective circuit board.
Oct 23, 2010 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
Hallo. I have a Prosonic TV type LC-27M65 that will not switch on. The red control light for remote is on. The yellow light indicator for current is off. Although TV is connected to net for power, the...
It is possible that your TV has encountered a fault in the power section possible a short in the drive power section. hence on powering the power sully working OK is switching the secondary power to the main board but this short is taking in more current than specified. the feedback of this is read by the SM unit to shut off the power to protect the supply. Hence you will have to probe into the sections to find this short, perhaps a HT drive transistor or the HT transformer or capacitors. If will be easier to check the continuity with a meter. Please attemptt only if familiar otherwise take help. Disconnection of the shorting section will switch the power, replace teh component in question. Hope you try. Good day
Aug 16, 2010 | Prosonic Televison & Video
The tv's green "on" light continues to blink on and off. when we turn it on at the remote or at the on/off switch on the side, it won't turn on. we have unplugged it and the light continues to blink. We...
Try pressing and holding the remotes "Power on" switch as it may be a child lock that is activated. Otherwise try holding the tv "Power on" switch. Hope this helps.
Jun 19, 2010 | LG 42LC2D 42 in. LCD HDTV
Need code for Audiovox LCD TV (Model LCD1900W) for COMCAST DTA
If none of the the codes work try following these steps:
1.manually turn on the t.v.
2.press and hold the setup button.
3. press and release the tv button the light will blink once and then stay on.
4.press the channel button repeatedly up to 300 times until the device changes channels. the light will blink and then stay lit.
5. press and release the mute button to store the code the light will go off
Aug 28, 2009 | Televison & Video
32PFL5232D/37
The code is 0081 and this is how you do it.
'4 digit' or 'Brand Set' method
1. Turn on your TV.
2. Press TV on your Sky remote control.
3. Hold down select and the red button together for about two seconds, until the red light on the Sky remote control blinks twice.
4. Press TV on your Sky remote control again.
5. Key in the Brand Set code for your brand of TV. The light on the Sky remote control blinks twice.
If the light blinks once only, re check the code for your TV and start again at step 1.
6. Press the on/off button (power-top right button on your Sky remote control).
If your TV switched off, press select . The light on the Sky remote control blinks twice.
If your TV did not switch off, press TV , then press the on/off button. Repeat this (press TV , then on/off) until your TV turns off, then press select.
If the light on your Sky remote control blinks three times, your Sky digibox has checked all the possible settings for the code you used. Check that you have the right 4 digit code and start again at step 1.
7. Press TV guide .
If you see the TV Guide screen, the remote control setup process is complete.
If you did not see the TV Guide, you must now set the TV Guide function as follows:
8. Press TV on your Sky remote control.
9. Hold down select and the green button together for about two seconds, until the red light on the Sky remote control blinks twice. The remote control setup process is complete.
Mar 11, 2008 | Philips 32PF5320 32 in. HD-Ready LCD...
Televison & Video Logo
37 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
