Question about Smeg 24 in. STX2 Built-in Dishwasher
Smeg Dishwasher STA945.1, flashing lights
When you select a program and then press the program selector button. The dishwasher starts and pumps out the water then stops. There are are five program lights. When you open the door the first three lights from the left flash and the far right one is static. Then I close the door it beeps and then the 2 lights on the far right flash. I'm stumped, as it does not give a troubleshooting code that matches.
  • Mitch108 Sep 11, 2008
    Hi Chris
    I have cleaned the filters, but no go with suggestion. The three lights on the left are still flashing and the far right is still static.
    Regards
    Scott
    Master:
  • 505 Answers
Have you check the pipe's for blockage
Posted on Sep 11, 2008
  • Also make sure the door to the washer is shut properly. and try holding down the reset button for 12 seconds
    Master:
  • 726 Answers
Ill find a solution ill be a few mins ok
  • 1 more comment
  • chris07551 Sep 11, 2008
    ok there is something like that sorta here have you changed and cleaned the filters?
    is any hoses blocked or leaking?
    take them off and try and see for a blockage and clean down them
    hi scott i had a look at a site and couldnot find any thing so i rang smeg and told them about the lights and they said it will have a converyance board problem and it will need a service and the board will have to be looked and fixed or replaced the price he quoated was 120 if you take it in or to a repair center or 210 if some one comes out thats the best i can do for you
I have a Smeg DI 112-1 intergrated dishwasher, when i switch on, light 5 flashes continuously and pressing the program selection button does nothing,
i have had success with dishwashers that have a (frozen) motor this involves
1 turn off electrical supply and or remove plug from receptacle.
2 turn off water supply, usually under sink, hot water side.
3 remove the mounting screws that you can see under the lip of the ledge when dishwasher door is open,once these are removed
4 carefully pull dishwasher out mindful of the hot water supply line that is attached.
5 visually locate the main shaft, use vise-grips to determine if shaft spins freely if not use v_grips to turn shaft two turns or so, check by closing the appliance door and turning power / water back on then try running unit.
this technique will work for some, and only if a (frozen) motor is the problem. this is a temp fix but it is better than nothing.
thanx good luck.
Apr 05, 2018 | Smeg Dishwashers
When I turn on the dishwasher, the light on program 6 flashes but the program will not start.
Pull the power plug or turn off the circuit breaker for about 30 seconds, plug it back in or turn the breaker on and the diswasher brain should have reset. Good Luck.
Dec 14, 2017 | Smeg 24 in. DWI612 Built-in Dishwasher
Lost manual book dishwasher smeg df612se
The program will not move when you press the button.
May 23, 2009 | Smeg 24 in. DWF612SS Free-standing...
The program light goes off and the BF162 doesn't start...
When you keep the button pressed for a few seconds the lights go off, this resets the dishwasher. Then press the p button again to the program you want 1st light is heavy soil 2nd light is normal soil, 3rd light is eco wash, 4th light is rinse. At the end of the cycle the program light you have selected will flash.
Apr 24, 2009 | Hotpoint 23 in. BFI62 Built-in Dishwasher
Smeg Dishwasher ST 663 sometimes won't work
My dish washer stops after i5 minutes, don't know what the problem is, water is going in but just suddenly stops, i changed the hose but still the same. Any help welcome
Feb 22, 2009 | Smeg 24 in. DWD1SSE-1 Built-in Dishwasher
Smeg DI 612 C Domestic Dishwasher
I was told by a SMEG engineer that I needed to replace the detergent dispencer. Just waiting for him to get back with a new one.
Aug 15, 2008 | Smeg 24 in. DWI612 Built-in Dishwasher
Smeg Dishwasher
replace the timer/control board
May 26, 2008 | Dishwashers
Error code. F14.
Check the motor circulation impeller, if you not maintain the unit is gonna be clog by impeller. it need to be clean.
Jan 11, 2008 | Miele Premier-Plus Built-in Dishwasher
Smeg 24 in. STX2 Built-in Dishwasher Logo
1,110 people viewed this question
Top Smeg Dishwashers Experts
Starnley Johnwells
Starnley Johnwells
Are you a Smeg Dishwasher Expert? Answer questions, earn points and help others
