Question about Bosch Drills
Using a bosch psr18 power drill
When setting the torque how do you know what setting to what size screw or what is the general rule of thumb about using the power tools small screw what torque? long 15 inch screw what torque etc. I can never get it right
  • Anonymous Mar 21, 2014
    I loved my Dreml 1120 7.2v Driver...great little screwdriver. It just basically came apart while screwing in a screw. Has this tool been discontinued by Dreml?? Was there a recall on this item?
    Problem Solver:
  • 7 Answers
Hi, they usually list the torque to screw size ratio in the instruaction manual. If you cant locate yours many companies list their instruction manuals pn the web on their home page, or you can sneek a peak at a hard ware store on a similar drill.
The usually rule for small screws is torque 1-4 on small screws.
Otherwise practice makes perfect & different types of timber will affect when the torque kicks in.
I still believe that an impact driver is better than a drill with screws as it impacts the screw in & this gives you better control. It will actually slow the screw down & you can recess it just perfectly. The drawback is that it can snap small screws when driving into soft timber. (but you can always predrill)
cheers
Laurie
Posted on Nov 01, 2008
What is the torque setting for pressure plate on ba xr6 turbo
http://www.portlandbolt.com/technical/bolt-torque-chart
Here is a good reference, it is not manufacture spec. but a good rule of thumb per size.
Mar 25, 2016 | Cars & Trucks
I have a Bosch 14.4 driver and with full charge I han hold the chuck an prevent from spinning when on drill speed. Can I fix this?
Battery powered drills generally are much weaker thah house current drills. With that in mind, realize that they aredrills and not intended to be power screwdrivers! The less the supply voltage, the less the torque (turning power). They are suppurb at doing small jobs where torque is not an issue, like using drill bits through wood, etc!
Dec 31, 2012 | Drills
We have a bosch double oven. The screws that hold the heat shield to the oven ceiling have perished and am unable to get them out. I have new screws that I ordered on line. Is it possible to redrill new...
you will need some special tools if you want to use the proper replcement screws, you can try drilling out the existing screws with a drill bit one size smaller than the screws or you can purchase a kit called "AN EASY OUT" using this kit involves drilling a small pilot hole deep enogh to insert the proper size easy out and how it works is, it's designed to work like a left hand thread so you turn it and it grabs onto the screw material and allows you to turn out the scew, or just drill out the holes and replace with self tapping screws one size bigger than the original, hope this helps.
Sep 19, 2012 | Bosch HBL 455 Stainless Steel Electric...
What speed would i need to set my cordless drill at to put hole in wall
Your drill will drill a hole at any speed, the drill bit needs to be sharp to drill the mateirial.The type of wall material is important.Drywall is soft but a masonry bit should be used.A masonry bit has a flat bar accross the point and slower speeds are best.Wood walls / studs you need wood bits that are sharper and medium to high speeds are used.Concrete or Block walls again require Masonry bits.If very hard concrete as in foundation walls or filled block the use of a Hammer drill will work much faster.Good Luck
Jul 29, 2011 | Drills
The 14 Position adjustable torque control How to use and what it is used for and how would it help me while working with my drill.
The torque settings on a drill will stop the drill from driving the screw ( or what ever you are tightening ) when it reaches a specific "tightness" . For example; the setting "1" will only tighten a screw a very little bit, while " 14 " will tightten the heck out of it.
Note: once the screw has reached it's specific torque ( or tightness ) the drill motor will continue to turn but it will disengage the driver, making a kind of grinding sound,it's perfectly normal so don't be alarmed.
Dec 29, 2010 | Dewalt 18 Volt Compact Drill Kit
How do I know what torque to set my drill to when driving into to wood vs dry wall
Sorry, there are no rules as to what to set torque to for your job. There are too many variables like thickenss of the wood or drywall or the hardness of the material you're driving into and whether you want the screw to stop above, at or below the surface. The best thing to do is set it low and raise the torque untill it stops when you want it to. Keep in mind if you hit something like a knot it will stop the screw earlier and if you go through a softer spot in the wood it will drive in deeper.
Nov 02, 2010 | Dewalt DC727KA 3/8" 12v Cordless...
I am screing tongue tite screws into hardwood flooring using a Bosch 18v cordless drill driver. the screw heads are torx heads (Star heads) . I need to know what torque setting I should use the drill...
That will vary depending on the hardness of the wood...the main thing you want to do is get the screws seated tightly without splitting or sinking them in too far.... you just want them flush...play with the setting till you get that... you will not ruin the the head... that is the least of your worries...
heatman101
Sep 08, 2010 | Garden
How is a driver different from a drill? What
Hello, W/D here.
A very good question......A drill holds a bit and rotates it at a given speed. This speed can be variable, allowing the speed of the drill bit to be better matched to the material being drilled. The output from the drill motor goes directly to the chuck, and the power is directly applied to the drill bit. Some drills can generate a tremendous amount of direct torque, due to the nature of their gearing. Most of the better drills have planetary gears in them.
A driver rotates like a drill, but is designed to apply torque to a driving bit, and cause a fastener to be placed by the driver. The main difference between a drill and a driver is that a driver has an adjustable clutch, allowing the amount of torque being applied to a fitting to be preset. A good example of this would be for driving wood screws. You would dial in the torque setting that you want the driver to quit driving the screw. You don't want to drive the screw to China, you want to drive it flush. A maximum torque setting "locks" the clutch, and the fitting will be driven as far as it can go (This is about as close to being called a drill as a driver will ever get). A clutch setting midway might be just right for driving the same fitting into oak, and a setting at less than that might be just right for pine. The torque clutch effectively sets a kick out torque for the driver. When the torque applied matches the torque set on the driver, the clutch "slips", and no further driving action can occur.
Most modern battery powered drills incorporate a torque clutch between the motor and the chuck so that the tool can be operated as a drill (with the torque setting at "max") or as a driver (with the torque setting at less than max) some electric tools are configured as both, but usually they are different. For the money, a good battery powered drill/driver with a clutch offers more versatility, in my opinion.
Best regards, --W/D--
Aug 19, 2009 | Dewalt Home Fencing
Overtighten causes hazing,and adjusment problem
As a general rule of thumb, If you have normal Weaver-type aluminum rings, you tighten to 10 to 15 inch-pounds. If you have normal Weaver-type steel scope rings, you tighten to 15 to 20 inch-pounds. If it's something exotic and/or expensive, you're pretty much stuck contacting the manufacturer. Leupold Mark 4's require 65 in-lb, for instance.
Wiha makes two adjustable torque screwdrivers (one for lower torque, and one for up to 60 in-lb that are perfect for most any scope ring applications.
May 04, 2009 | Leupold ® Rifleman® 3-9x50 mm Scope
Drills Logo
158 people viewed this question
Top Bosch Drills Experts
Matt Olenzek
Matt Olenzek
woodzowl307
Are you a Bosch Drill Expert? Answer questions, earn points and help others
