Question about Canon PIXMA iP3300 InkJet Photo Printer
Cannon Incompatible Ink Cartridge Issue
Got a replacement Cannon Ink cartridge for my printer. Now just says Incompatible Ink what should i do.P.s not sure if thats the correct printer but its one of those on the cartridge box which is cannon: 008 black.
  • Anonymous Mar 17, 2014
    ink cartridge incompatible
I refilled my ink cartridge and you have to reset the chip on the cartridge,go back where you refilled your ink and ask them to reset the chip.Thats if you refilled the ink or you baught a canon one return it to the store.
Dan
Posted on Sep 24, 2008
No print
“All lights blinking and printer not responding” is indicative of serious ink cartridge issue. Usually when this happens the printer fails to goes through the motions of the printing process, kind of stands still with indicator lights just blinking away. This could be as a result of either of these scenarios.
i. Ink cartridge has developed incompatibility or is incompatible
The Solution is to try an older/another cartridge (doesn’t matter if ink is finished. You must replace cartridge one at a time). If lights stop blinking it confirms that your cartridge has become incompatible or developed incompatibility. Also if your printer is the type that can work with only one cartridge, remove one after the other (closing back the lid/cover) to determine which in the set (black or color) has become incompatible. At the instance the incompatible one is removed and you close the lid, the blinking will stop (for printers that can print with one ink cartridge only). Just replace the incompatible one and start printing again. In most cases the issue is always with one cartridge. But if both are affected, you have to replace both. Because of this type of problem, always keep used cartridges somewhere safe; they come in handy for this type of troubleshooting.
ii. The Cartridge electronic panel is dirty
The electronic panel on the cartridge that makes contact with the cartridge carrier inside the printer is dirty and needs cleaning. This electronic panel is front part of the cartridge with copper “dots”.
The Solution is to try to clean this panel with a piece of folded tissue paper soaked in a bit of methylated spirit. Also try to clean the area in the cartridge carrier/holder that makes contact with the cartridge’s electronic panel (Usually this is more difficult). If you cannot reach it with your fingers, use a stick or something with tissue wrapped around it. Allow to dry well and return the cartridges, close the cover. The blinking should stop if the electronic panel is the issue. Once the blinking stops the printer will print.
Mar 25, 2010 | Epson Stylus C88 InkJet Photo Printer
Tip
How to Resolve Printer not printing but indicator lights just blinking
on Dec 06, 2009 | Office Equipment & Supplies
Changed black ink cartridge for epson stylus d120 but not working
Mar 24, 2010 | Epson Stylus cx7450 All-In-One InkJet...
When I turn the power on only the alarm light
“Alarm lights blinking and printer not responding” is indicative of serious ink cartridge issue. Ordinarily change of cartridge resolves the problem. But try this before you do anything else. Usually when this happens the printer fails to goes through the motions of the printing process, kind of stands still with indicator lights just blinking away. This could be as a result of either of these scenarios.
Dec 20, 2009 | Canon PIXMA MP160 All-In-One InkJet...
All lights flashing on top of HP Deskjet F4235 all in one and pc will not recognize printer.
All lights blinking, Printer not printing
Dec 10, 2009 | HP Deskjet D4160 InkJet Photo Printer
Green light and red light flashing
Dec 09, 2009 | Epson Stylus Photo 1290 InkJet Printer
Will not print
Dec 09, 2009 | HP DeskJet 920c InkJet Printer
I can't print.
Dec 06, 2009 | HP Photosmart C3150 Printer
Printer wont print, computer communication error that wont send information to the printer, but the scanner will scan to the computer. Power light on the printer blinks 2 times, pause, blinks once, pause,...
“All lights blinking” is indicative of serious ink cartridge issue. Usually when this happens the printer fails to goes through the motions of the printing process, kind of stands still. If it an All-in-One it still scans though. This could be as a result of eithe of these of scenarios.
i. Ink cartridge has developed incompatibility. Solution is to try an older/another cartridge (doesn’t matter if ink is finished. You must replace cartridge one at a time). If lights stop blinking it confirms that your cartridge has become incompatible or developed incompatibility. Also if your printer is the type that can work with only one cartridge, remove one after the other (closing back the lid/cover) to determine which in the set (black or color) has become incompatible. At the instance the incompatible one is removed and you close the lid, the blinking will stop (for printers that can print with one ink cartridge only). Just replace the incompatible one and start printing again. In most cases the issue is always with one cartridge. But if both are affected, you have to replace both. Because of this problem, always keep used cartridges somewhere safe; they come in handy for this type of troubleshooting.
The electronic panel on the cartridge that makes contact with the cartridge carrier inside the printer is dirty and needs cleaning. Solution is try to clean with a piece of folded tissue paper soaked in a bit of methylated spirit. Also clean the area in the cartridge carrier/holder that makes contact with the cartridge’s electronic panel. Allow to dry well and return the cartridges, close the cover. The blinking should stop if the electronic panel is the issue.
Dec 06, 2009 | Lexmark X1150 All-In-One InkJet Printer
My red lights are both flashing and printer will not responed
Both red lights flashing? One should be for paper jam and the other for low/insufficient ink. I presume this is a deskjet/injet printer. The combination of these two lights flashing usually indicates a more serious issue rather than just low ink or paper jam. It is indicative of incompatibility of ink cartridge. After a while some cartridges just could become incompatible with the machine. All things being equal (i.e. no paper jam issue) a replacement of your ink cartridge will resolve this issue. Just get brand new ink cartridge/cartridges. It is usually ok to replace only the one that has become incompatible. But the issue is you need to troubleshoot to determine. You may not have the resources to do this, so better to replace both or replace one-by-one.
Sep 15, 2009 | Epson Stylus Photo R260 InkJet Printer
Canon PIXMA  iP3300 InkJet Photo Printer Logo
355 people viewed this question
old marine
old marine
