Panasonic KV S2026C Path-Through Scanner Logo
Posted on Aug 30, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Problem with the Panasonic KV S2026C \r\nScans fine, but adds and extra page and puts a black line down the left side of the blank pages. The line is not on the scanned pages just the extra ones that are added.
Anonymous
Level 1:
New Friend:
  • Contributor 2 Answers
  • Posted on Jan 26, 2012
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
Helped
1332
Points
On the CD that came with the scanner is a directory called "Shading Utility". Copy this folder to your PC. Put a blank piece of copy paper into your scanner. Open up the Shading Utility folder and then double-click on the shadingutility.exe. The password is "GOSHADING" without the quotes. This process will take a few minutes but it will re-align the lens in the scanner which has gotten out of alignment through vibration. This is what is causing the vertical black line on the left side of the page.
Mohan Sriraman
Level 2:
  • Expert 490 Answers
  • Posted on Aug 31, 2011
Mohan Sriraman
Expert
Level 2:
Answers
490
Questions
0
Helped
246946
Points
823
Pls check if you have selected 'duplex' scanning. The extra page could be back side image! Clean the glass images without lines.
S. Mohan, India. Chennai
When I scan two-sided to pdf, the back page has a large black vertical streak down left side.
If that is the last page that has the streak use a blank page in the original scan as the last page and then the dark line wont cover the image.
1helpful
2answers
My panasonic kv-s2026c has a black line running down the left side when I scan my documents. I have cleaned the rollers, used air canister to see if anything is stuck in there. That didn't help
Line in scanned document
Its dirt! It takes just one tiny speck of dirt on the lens to make a vertical line.
We have some scanner maintenance videos;you want to clean the CIS front sensor.
Regards,
MyEfact
Blank line down left side of outgoing fax or feeder copy
The most common cause of blank (void) lines on a scanned document is from whiteout on the glass where the page is scanned when using the document feeder.
If there is a clear mylar sheet on the bottom of the document feeder, the whiteout may be there instead.
If there was dirt or a dark smudge on the glass (or mylar), it would show up as a black line, but whiteout is white, and shows up as a void (blank) line.
1helpful
When I scan the pages it has a black line..
Try to peek into the scanner while scanning, you probably have a burned out LED element.
2answers
Streak down the middle of each scan
Make sure the scanner glass is clean and there are no foreign objects.
If the streak is a white line then it could be a ink cartridge problem.
1helpful
Roller fell of on the inside of panasonic kv-s2026c
yes normal. thier are 2 black rollers. they are spring loaded so when the door is closed the correct tension is applied to them.
Bboss
4helpful
3answers
Black vertical line
There is a User Shading Utility on the original product CD. Browse to the CD drive and open the folder named ShadingUtility. Run the program ShadingUtility.exe the password is GOSHADING (all caps, no spaces). Put a clean, white sheet of paper in the scanner (or glossy photo paper works really well), then click the Shading button.
Top Panasonic Office Equipment & Supplies Experts
Norman Weimar
Norman Weimar
ZJ Limited
ZJ Limited
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
