Question about JBL LC-S960 Car Speaker
Same as before
Right i think i understand what u mean so cheerz for help so far
but i have a 300watt amp already fitted and i was thinking of switching existing rear speakers for my 6x9's cos my head unit does 4x55watt output
so, can i take the wires going into the existing peakers and just connect them to the corresponding sides of the 6x9's?
i suppose i could splice the wires together? dont have soldering iron and im sure ill get over a bodge job aslong as all wired up.
i just wasnt sure whether i could do that and just connect existing wires to new wires then connect to the 6x9's?
if doesnt make sense ill try explaining better, bit of rush atm cos gotta go out
thanks for help tho...getting a better understanding which is awesome
thanks
  • jackoby1991 Sep 15, 2008
    cheerz for help, i got them working now
    i didnt put through amp, just through same wires for old rear speakers then connected to 6x9's
    sounds so much better and i dont think it would be worth the hassle to connect to amp
    goes loud enough and the mid range is so much better
    thanks for help tho, made it loads easier :)
    Scholar:
  • 71 Answers
That is correct.  I would solder if you cant make the connectors.  they should have two diff sized spades on them.(usually)  I would definately get a crimp kit with crimpers and asst connectors to start.  Also make sure your amp has adequate gnd and large enough power wire with an inline fuse right off the source.  I can make a diagram for that too if you need.
Posted on Sep 13, 2008
  • James Mac
    James Mac Sep 23, 2008
    Good to hear it!  I just got through wiring in a 2500 watt amp 1.5 farad capacitor and two 12" Audiobahn DUBS!  It rattles my little pathy.  But it's perfect for the 1 hr commute to and back from work.
How do i fit a rear wing to a 1971 xy gt falcon
place masking tape on the area of the bootlid where the pillars/risers of the(i assume you mean)spoiler are going to be screwed,ensuring you have access to the underside where the bolts are to be fitted.You may have to juggle the fitment to get the optimum balance of accessibility(for the bolts)& cosmetics(how it looks)-leave the trailing edge overhanging the boot just until you think it looks good and the access thru the inner bootlid frame is sound(you can drill access holes thru the frame if you need to & seal/bung those holes when ur done.
right now place the spoiler & draw around the base risers onto masking tape-remove spoiler,measure carefully the bolt holes & transfer measurements onto the bootlid-lightly centre pop those marks(only after you've triple-checked your marks) & drill the holes-i start with a 2mm & work up to the final bore-allow a bit bigger than the bolts,so 8mm bolts drill at 8.5 or even 9mm;you can drill thru the frame too if u need to but just make sure you don't foul the boot aperture rubber or the guard channel gutter. Now if your measurings good you should be able to fit ur spoiler using a good sealer between bootlid/spoiler & a waterproof washer on the bolthead side-hope this is helpful,i've fitted many in my time-just take ur time & think as u go-you'll be sweet
Jan 18, 2015 | Cars & Trucks
Tip
Dell PDA Battery Cover Warning Messages & Won't Power on
This is my 1st posting on this forum although I've done a lot of reading regarding the battery cover I think this is the correct solution.
To everyone that's having problems with the back plate battery cover warning messages or problems not booting up on your Dell PDA, I think I've found the answer, I have 2 Dell's PDA's, 1 a X51v & the other a X50v, I was having problems with both of them (1 had battery cover warning messages & the other had a screen freezing) so I stripped the 2 of them down when I had both rear shells together I noticed that the small piece of sponge that Dell fit to the latching mechanism one was on the far right of the latching plate on one & the other was in the middle of the plate, I looked to see which shell belong to which PDA & the one I was having problem with battery cover warning messages the sponge far right, so I swapped the back shells around & booted it up BINGO!!!!! problem solved, I'm fairly sure the SPONGE SHOULD BE IN THE MIDDLE OF THE LATCH PLATE, if I'm right Dell engineers & executives should be shoot, such a simple fix why didn't they let owners know about this. This has got to be easier than trying to bridge the switch contacts or rip the switch off the board, give it a go guys, Please let me know if it works on your PDA. I will upload some photo should any of you guys need.
welshcob
on Nov 26, 2013 | Dell Axim X51v Pocket PC
Gamma/GT high mean I don't understand what this
I don't know how this got posted under 'Cars & Trucks', but I think you need to have a read of this page which may be of help to you.
A reading of more than 51 apparently. means it COULD be a problem. Read the page.
http://www.nlm.nih.gov/medlineplus/ency/article/003458.htm
Sep 15, 2014 | Cars & Trucks
Is this free information, to help the less knowledgeable? i'm replacing stock coils with a set of DC1-1 dyna coils (green) on a 1971 honda cb750K1, and installing an electronic ign. my question is as your...
That sounds right to me. Once you have fitted the dyna coils, check the bike runs before fitting any electronic ignition. Many people are quick to throw away the points and condensors, but if you are not covering high milage every year is it really needed? If an electronic ignition fails, you are stuck. Points can be cleaned up and reset at the side of the road and are far cheaper to replace.
Feb 12, 2011 | Honda CB 750 Motorcycles
My 90 chevy acts like the choke is closed after it warms up.changed the plugs,wires,throttle sencer&map sencer, still does it,help.
I think your truck has throttle body fuel delivery? My understanding is a temp sensor tells either computer or throttle body that engine is warm and cuts out "choke". Hope this can help you.
May 07, 2010 | 1990 Chevrolet K1500
Im not sure wich the right channel to use on my amp to bridge it to my subs, because it goes (+ + , - -) as opposed to (+ - , + -). do i use the possotive on the far left and the negative on the far right...
Hi there. It should definately be the far right and far left, no doubt. Ther should also be a awitch to drop the frequency to about 80htz. If not, the amp should drop the frequency by just connecting it the way you wanted to
May 07, 2009 | Kenwood KAC-9152D Car Audio Amplifier
Speaker installment
I would run a 250-500 watt 2 channel high input capable amp.  run the original wires to the orginal speakers and jump off the original wires to the amp to push the secondary 6X9's you have.  So my understanding is.  you want the 4 original speakers and subs and add 2 additional speakers making 6 speakers not uncluding subs..
Head units care barely push 4 decent normal size speaker.  Usually they are 30-55watt per channel.  If you have 2 non sub speakers that are 250 watt max.. that's 500 total but don't push the amp all the way...start with it at 1/4 and listen to your stereo at a higher than nominal volume slowly turning up the amp.
James Mac
Sep 09, 2008 | JBL LC-S960 Car Speaker
I got same problem as you
the player dosent realy give power to the subwolfer its more for the speakers. it should be the amplifer that is connected to the subs, also mite want to chek the settings on the amp
Jun 06, 2008 | AudioBahn AW1206T Car Subwoofer
Car audio
Does it blow the fuse if you disconnect the RCA cables and disconnect the speaker wires from the speaker terminals of the amp?
Does it only blow the fuse after the head unit is switched on (only after remote voltage is applied to the amp)?
Apr 28, 2008 | Car Audio & Video
Jensen LXA300 Amp. need to known specifications of electron. part
If you remove the clamp, there will be a part number on it. Post the numbers on the transistor and we'll go from there.
Mar 15, 2007 | Jensen LXA300 Car Audio Amplifier
JBL LC-S960 Car Speaker Logo
65 people viewed this question
Top JBL Car Audio & Video Experts
hoyzee1
Rob Beech
Mark Skinner
Are you a JBL Car Audio and Video Expert? Answer questions, earn points and help others
