Washing machine cold water not filling
Hi I have a Hoover Electronic 220m 5.5kg washing machine. In the last couple of weeks it has stopped being able to fill with cold water. In order to do a wash I have to remove the cold water hose from the back of the washing machine and fill the tub by putting the hose in the tub itself. When it goes to the rinse stage I have to do the same thing.
Your help would be greatly appreciated.
-Hamish
I have just bought a second hand (re conditioned) hoover top loader washing machine 220m 5.0kg and problem is that as soon as the tap connection is opened... the water immediately fills into the drum of the washing maching without the machine even being turned on! and so then to turn it off, you have to turn off the connection of the tap! help please!!!
Posted on Apr 02, 2010
  • 319 Answers
Typically this indicates that you have a water inlet valve that is not opening. Replacement of this part would be ideal, and should fix the problem.
Regards
Brian
Posted on Sep 10, 2008
Why won't my machine stop filling?
replace water level sensor
if less than 5 years old
should be able to get the part from a washing machine repairer
or hoover washing machine parts supplier
Apr 16, 2017 | Hoover Washing Machines
Cold water filling is very slow despite good water pressure and taps fully turned on
If your washing machine will not fill, only hot or cold will fill or is slow tofill then read these tips. I have covered many of the things that can happen inthese tips...
Washing Machine Problems No Water
Washing Machine Fix Washing Machine No Water
heatman101
Sep 03, 2011 | Hoover Washing Machines
Very slow filling of cold water. Hoover 5 Kg
heatman101
May 23, 2011 | Hoover Washing Machines
Washer not filling up with water?
If your washing machine will not fill, only hot or cold will fill or is slow to fill then read these tips. I have covered many of the things that can happen in these tips...
heatman101
Feb 23, 2011 | Hoover HC6 110M Front Load Washer
Water flow slow
heatman101
Dec 29, 2010 | Hoover Washing Machines
Hi, my washing machine isn't working in cold/cold mode but will work in hot/cold and warm/cold. Meaning that water will not come out at all. I even started it in warm/cold and tried to switch it over to...
My bet is that your cold water screen is plugged...
If your washing machine will not fill, only hot or cold will fill or is slow to fill then read these tips. I have covered many of the things that can happen in these tips…
heatman101
Aug 31, 2010 | Frigidaire Washing Machines
Hoover washing machine top load, model 550m.5.5kg
water leak from cold hose nothing to do with other problem. tighten hose connection and fit a new hose washer overfilling probably because air chamber blocked. remove lid. you will see a pressurestat somewhere at the top - usually round with anything from 3 to 7 wires and a small tube underneath. follow hose down and it connects to the air chamber. make sure this is free of gung and check hose for splits and has no blockage. to check the pressure stat itself, attach your own hose to the stat and while machine in fill mode, blow down this hose and you should hear a click and water intake will stop
May 04, 2007 | Hoover HTC243 Top Load Washer
Washing Machines Logo
232 people viewed this question
Top Washing Machines Experts
