My Swivel Base has broken during a move and I can't seem to find a replacement part for it anywhere, I'm not sure whether I can only use a specific base for that model or whether all 37inch LG's have the same base?
Can someone help my TV is balancing at the corner of my lonuge at the moment!!
SOURCE: Swivel Base for a 42LC2D
Hi there is normally a set of 4 to 6 screws that hold the base to the tv set that you remove , you can then possibly use the same screws to attach the wall bracket to the back of the tv before mounting on the wall
hope this helps
cheers John
SOURCE: Remove Swivel Base on 42LB1DRA
If you look at the back of your TV, locate four big screw/bolts. Its the biggest screws/bolts you'll ever find at the back. 2 each side that holds the unit to its swivel base. roughly 12" from the left edge and 12" also from the right edge. remove all this four (4) screws/bolts then ask someone to help you lift from the base.
Good Luck.
SOURCE: LG swivel base
Just look at where the base goes in. There should be 4 screws that are holding it on.
SOURCE: lcd base screws
The screws on the 26" Insignia without the dvd appear to be #8 1 1/2" self threading flat head screws. Hope that helps.
