Question about Fisher and Paykel IWL12 Top Load Washer
Wont spin I have a problem where it will complete the cycle and also drain the water at the end, but will not spin dry.. it just makes a noise when it comes to spin dry and slight irregular movements?? Anone know what it could be?? I have a new pump in it too.. Greatly appreciated Michael
  • 76 Answers
By saying it makes slight movements when it comes to the spin sycle tells me only one thing. GEARBOX.
Yes your matjien got a gearbox,clutch the works,
mostly the gearbox give a problem,but if you dont know how to check this rather go to someone that does,just get it tested...
Hope this helps.
Posted on Sep 10, 2008
Water will not drain out of front Load Kenmore 44072
Kenmore front loading washing machines will give you years of service. Sometimes things do go wrong, especially after the warranty runs out. Troubleshooting a Kenmore front loading washing machine could save you a lot of money on a repair bill. Before you call a service technician to fix your machine, attempt to resolve the issue through simple fixes first.
Washer Code Messages Your Kenmore front loading washing machine has an LED display that will give you error codes.
Will Not Spin If your washing machine does not spin, check to make sure the door has latched completely. Also remember that if your machine is in the SUD cycle it will not spin until it has eliminated the suds.
Washer Is Noisy
  • If the washer is making noise or vibrating, check to make sure it is still level. If it is out of level you can change this by adjusting the feet. Metal belt buckles and buttons in your laundry could be causing the noise as well.
  • Door Stays Locked After Cycle
  • At the end of the wash cycle, the lock will disengage after about 30 seconds. If it does not, it may be because the machine still detects that the water has not completely drained. Just select "Drain" and "Spin" and let the washer go through the cycle. Your door should unlock.
Nov 03, 2011 | Washing Machines
I have a Bosch Maxx 1000 Washing machine and it seems to be stopping just before spin dry and flashing end. Door won't open so I need to turn to spin or drain to complete cycle. Today the spin cycle...
this is because the water can't evacuate . check the pump trap filter and make sure there are no blockages. you will probably find water still i the machine when this happens. There might be a blockage up in the hose pipe before the pump. Good luck
Jan 22, 2011 | Bosch Washing Machines
Washing machine wont drain keeps bleeping ERR2
It will not spin with water in.
See if you can locate a filter, and clean same.
Jan 19, 2010 | Haier Washing Machines
Loud noise, then not so loud, but now electrical burning smell and little draining
the smell is your clutch and the lack of draining is a clogged washer drain protector. see these at www.repairclinic.com drain protector is part 541811 and clutch is 2670. go there enter model number and scroll down to the red 100 click it and look for these part numbers.
Mar 02, 2009 | Whirlpool LSR5132PQ Top Load Washer
Water not draining
check if anything is blocking the way of the drain pump ...else the drain impellor would have broken...
thankyou
Dec 05, 2008 | Washing Machines
My frigidaire washer want spin
Sounds like the lid switch may have went bad. It has an independent drain pump so will still drain water. Give that a try and see. Godd Luck!!! Jim
Sep 14, 2007 | Washing Machines
Fisher and Paykel IWL12 Top Load Washer Logo
87 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Dan Webster
Dan Webster
Owen Barnes
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
