Question about Pioneer DJM-600 Silver Professional DJ Mixer with Auto Beat Cou Home Equalizer
Djm 600 got a djm 600 mixer, it works fine but the channel one, very low sound, do i have to replace the fader or the connections
  • 682 Answers
Start with connections and try to clean fader with lubricant contact cleaner from radio shack or any electronics store.
Posted on Sep 23, 2008
Pioneer DJM 600 Master Out 2 Left Side Doesnt Work. any help please?
it could be a few problems,
1 - the left master connection to the board has come away (you would have to open up the mixer to detect this.)
2 - the master fader is faulty (you can tell this by checking your master level indicators are both on whilst music is playing, or tapping the fader.)
My advice would be to have it serviced or if under warranty speak to the store you bought it from. But if you feel confident and know what your doing u can find replacement parts on ebay etc.
Hope this helps a little
Jul 17, 2012 | Pioneer DJM-600 Silver Professional DJ...
Volume control of system output is not stable with sudden high volume output bursts. Any ideas?
Sounds like a faulty / worn fader. If it does it on all channels then look at the master fader 1st.
A good source of parts is available here :-
http://stores.ebay.co.uk/methleykev
Jul 01, 2010 | Pioneer DJM-600 Silver Professional DJ...
When moving the bottom knob on channel 1 and 2 of the pioneer djm 600 mixer there is a slight interference sound coming through the speakers. Channel 3 and 4 are fine
That sounds like you could have some dust built-up on your sliders. Get yourself some dust repellant spray or silicone spray normally found at you nearest computer store. That will definately sort your problem
May 21, 2010 | Pioneer DJM-600 Silver Professional DJ...
Djm 500 mixer cf missing and does not turn on does it need the cf to turn on?
no and you can use channel fader of each channel to control the channel without cross fading.
Dec 18, 2009 | Pioneer DJM-600 Silver Professional DJ...
Pioneer djm 800 will only play through 2 channels on mono??
try to clean your fader with contact cleaner and move it many times after cleaning -check your connection plugs(buy it from radio shack near you.
Apr 11, 2009 | Audio Players & Recorders
Pioneer DJM-600 Bad feedback when i turn up the master volume
It's not your ground wire with the issue, but your RCA cables. Try disconnecting both turntables, and connect 1 at a time, and do the same test, this way you can isolate the problem. Once you've isolated the problem, then you'll need to have the RCA cables replaced on your turntable.
You might also want to check the Cartridges as well. Sometimes a bad cartridge or headshell connection will cause this issue. Worst case scenario, its your tonearm, but that should be test last.
Also, on the rear of your mixer, there is a gain volume pot, make sure this is not maxed out. Keep it about 3/4 of they up. Again, this is on the rear of your mixer where you connect everything.
- OPTiC
http://djproaudio.com
http://djprolab.com
Dec 04, 2008 | Pioneer DJM-600 Silver Professional DJ...
Djm 600 - fader panel not working
i would recommend checking a fuse somthing with such good quality would less liky need a replace ment unless the power cut really damaged it internily
Oct 06, 2008 | Pioneer DJM-600 Silver Professional DJ...
Pioneer djm 600
There is a master gain volume control on the rear of the mixer, where you connect everything. Make sure it's not down.
If it's fine, then maybe them being outside caused an issue. How cold is cold? If your talking freezing, then maybe there is some issues with the solder on the pc boards. You'll have to take it to a service center at this point.
I would say, try connecting a CD player to all the channels, and try from there. If it's still the same, then you need professional help.
- OPTiC
DJ Equipment Repair & Service
A DJ Pro Audio Co.
Oct 02, 2008 | Pioneer DJM-600 Silver Professional DJ...
399 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
