Question about Neff B1641 Single circotherm super Electric Oven
NEFF B1542 oven has 2 retractable buttons to regulate oven setttings and temperature settings, which will not engage when pressed? also the temperature/settings backplate of both selector switch a and b rotate when attempting to select either temperature or cooking option
barkencoa
  • 3463 Answers
SOURCE: Neff faulty Fan
Hi.
I would not think that both fan and element are faulty, although it is possible.
if it has a timer make sure that it is on manual and not on auto, as this would stop the oven working.
Other possible fault is faulty main oven selector switch.
Hope this helps. Please do not for get feedback .
Thanks.
Posted on Nov 25, 2008
barkencoa
  • 3463 Answers
SOURCE: Unable to remove the backplate off Neff oven
If there are no screws at the rear of the oven compartment that you can see to remove, then you will have remove the oven from the housing, and remove outer rear panel of oven to access the element.
Check the 4 fixings again, because on some ovens , they are not using coventional screws, they are are using what are called Torx screws, and you need a torx screwdriver or key to undo them.
Plz rate my solution.
Thanks.
Posted on Jan 07, 2009
  • 134 Answers
SOURCE: How do you change the language on Neff B1664 Oven?
Hi
go here and enter your number
https://portal.bsh-partner.com/portal(bD1kZSZjPTAwOQ==)/PORTALFRAME.HTM
Posted on Feb 14, 2009
SOURCE: Neff oven B1641
Turn the right hand button onto the ECS symbol. This is the cleaning cycle. Make sure you put some soapy water in the 'well' at the bottom of the oven. The oven is then steam cleaned.
Posted on Mar 08, 2009
  • 57 Answers
SOURCE: neff u1421 bottom oven fan is working t/stat
Can only be either element or thermostat. I suggest you check element and connections
Posted on Aug 26, 2009
Changing the time on a Neff oven B47CR32NOB
Press the select button until the clock flashes ( you do this by looking at the time displayed and pressing the select button as required) Use the timer set button by rotating to correct time. Once the time is displayed wait 2 seconds for it to set.
Oct 29, 2016 | Neff Ovens
How do I set clock?
Hi dear,
You need to set the time before the oven can work.
Try pressing the first 2 buttons on the left and at the same time press either the + or - button to set the time.
regards
REGARDSR
Aug 27, 2015 | Neff Ovens
I have a new Neff U15E52N3GB oven and I have to reprogram the clock each time I want to use it. Am I missing something on the original set up or is it a Naff Neff?
you are, that sounds like your setting the timer for cooking not the clock.....switch the hole thing off at the wall then put it back on, the clock should flash, then set it, check the manual for button config.
infact i just read it, & its on page 10 2nd paragraph on right hand side...........
You can only change the clock when no other clock function is
active.
ie switch it off & back on at the wall.
1.Press the < > clock function button repeatedly until
the< > O(pic of a clock) and symbols light up.
2. Set the clock using the rotary selector.
The setting is applied automatically
Dec 12, 2014 | Neff Ovens
B1542 child lock
Can you check Enr and repost, model number is not recognised
Feb 22, 2013 | Neff Ovens
What is rhe best temperature for cooking bread in the Neff 1451 oven?
On circotherm at around 210 in a preheated oven for first ten minute, then drop to 190 until finished. For a 2-2.5lb loaf that would be 10mins followed by 20-30mins depending how dark you want it. On the neff ovens down the left side the shelfs are numbered 4 at the top down to 1 at the bottom... you should use the shelf set on 1 or 3 (**NEVER IN POSITION 2**). Good Luck. Hope this helps.ps you can prove the bread in the oven by setting the selector to 'fan' but with no temp, the heat from the lamp will create enough heat (obviously the bulb/lamp need to be working!!)
Sep 14, 2011 | Neff B1451 Single circotherm plus Electric...
I have no main heat on neff oven and i think it
Make sure the oven is set for 'manual' start cooking as opposed to 'automatic'. Usually you have to press a button on the timer.
Dec 24, 2009 | Ovens
How to set the timer
1. Set the oven to the required
temperature.
2. Press the g button.
3. Set the total cooking time with the +
button (see the example in the
illustration right, showing 1 hour and
30 minutes).
4. Press the h button.
5. Set the cooking finish time with the +
button (the example in the illustration
shows 12.30 hrs.).
After setting the display shows the
time of day and indicates »AUTO«.
The oven cooling fan will start
immediatley.
At the pre-set time, the oven will be
automatically switched ON.
The settings can be corrected at any
time.
When the pre-set cooking finish time
is reached, a signal sounds and the
oven is automatically switched OFF.
To turn the signal off, briefly press the
h button.
6. Turn the oven selector switch to the
0 position.
7. The »AUTO« symbol blinks.
Important: It must be switched OFF
by pressing the E button.
Also here is the manual.
Good Luck
Jan 20, 2009 | Neff U1721 Double circotherm Electric Oven
Neff series 1 oven
press the two arrow buttons in at the same time as turning the pop out knob
Aug 04, 2008 | Neff B1421 Electric Single Oven
Clock setting
Press the fourth button from the left (that looks like a tick) then turnthe knob to the right of it to set time as required
Feb 06, 2008 | Neff B1641 Single circotherm super...
Neff B1641 Single circotherm super Electric Oven Logo
290 people viewed this question
Top Neff Ovens Experts
ashburton
Hjalmer Lamminen
Hjalmer Lamminen
Samyfam
Samyfam
Are you a Neff Oven Expert? Answer questions, earn points and help others
